STD Maintenance General 617. Engine junk?
617. Engine junk?
617. Engine junk?
jkstehn
05-30-2009, 03:44 PM #1
So I was taking apart my junkyard 617 while trying to get things a bit cleaner and while I was trying to get the bolts out of the main crank pulley the engine turned. Put a 27 mm socket on it and I can turn it by hand. Glow plugs and injector have not been removed. I expect that this means the engine really is junk, with no compression. Am I right? Huh
jkstehn
05-30-2009, 04:12 PM #2
Only an actual compression test can tell you that.
Syncro_G
0-60 in 29 sec
280
05-31-2009, 04:12 PM #3
(05-30-2009, 03:44 PM)jkstehn Put a 27 mm socket on it and I can turn it by hand.......I expect that this means the engine really is junk, with no compression.
I can turn mine by hand without much trouble - I do have to put a little weight on the wrench every 144 degrees to get past a compression peak.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
jkstehn
05-31-2009, 05:15 PM #4
(05-31-2009, 04:12 PM)Syncro_G
Well there is hope then. I am waiting to get hold of a compression tester. Should be next week.
Is it possible to check compression without spinning it by starter?
Anyone ever hooked up the starter and spun one of these on an engine stand. I could hook up the engine crane to the top for extra safety margin but I am still really leery of trying to turn it over while attached to an engine stand.
jkstehn
SurfRodder
Jackass Extraordinaire
611
06-01-2009, 03:01 AM #5
(05-31-2009, 05:15 PM)jkstehn I am still really leery of trying to turn it over while attached to an engine stand.
i wouldnt worry about it... somehow running it on the stand might be a little hairy, but turning it over shouldnt be a prob as long as everything is clear of the moving components...
OBK# 62
SurfRodder
OBK# 62
tantank79
T3-45
109
06-01-2009, 10:56 AM #6
You can definitely run one on the floor (or the middle of a field, in my case)!
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
06-01-2009, 01:37 PM #7
do not let the engine side on the oil pan. running or not.
GileadGarage
07-09-2009, 11:34 PM #8
At first I thought you meant you could spin the socket with your hand, with no ratchet!
GileadGarage
