STD Maintenance General 617 valve lash
617 valve lash
617 valve lash
11-21-2011, 04:34 PM #1
I may have asked this before but don't know if I got any valuable responses.
Adjusted my valves the other day because I thought the motor sounded kinda clacky.
I cannot have been 10,000 since I was last in there and yet every one of the exhaust valves was tight as could be against the cam. While every intake valve was right where it should be.
It this is how it pretty well always goes for me. That the exhausts are tight and intakes need no adjusting.
What does that tell you? Nothing? I guess I need valve adjust every 5k or 8k cause 10k is way too long.
Hercules
11-21-2011, 07:45 PM #2
Higher exhaust temps. could cause exhaust valve stretch.Higher rpm usage could also do same,and cause seats to beat -in. Valve adj. to be set cold,but below freezing to increase clearance. Nothing wrong with increasing clearance a small amount,and or adj.at less mileage.
Hercules
dieselboy
Rotatin 5500 times a minute
680
11-21-2011, 07:50 PM #3
Mine were all in spec after 10k and I rev the piss out of my car with some decent egts.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
Hercules
11-22-2011, 03:03 AM #4
You"re Question; What does tight exhaust (only) Say.IF each time only exhaust are tight. Not a normal condition! Almost always serviceable. Will be ok inless you run out of valve adj. thread. Why? tight. Valves stretching,valve seat area sinking in or both. No other possible reasons!
Quality, mileage,age ,temp.stress all plays a part. Soft cylinder heads do occur even on Mbz. (been there).
Why only exhaust side,++ add heat!
Keep those valves adjusted,---Roll On.
Hercules
11-22-2011, 05:36 AM #5
Time to get the FMIC on and help cool it off Wink
and figure out this whole drip timing mystery.
11-22-2011, 04:53 PM #6
(11-21-2011, 07:45 PM)Hercules Higher exhaust temps. could cause exhaust valve stretch.Higher rpm usage could also do same,and cause seats to beat -in. Valve adj. to be set cold,but below freezing to increase clearance. Nothing wrong with increasing clearance a small amount,and or adj.at less mileage.
I have read that low RPM High load is what causes seats to wear more? Something like there is more pressure closing against the valve than when there is a higher RPM.
I read that in a Mercedes Tech manual
Hercules
11-22-2011, 10:12 PM #7
Yes, lugging the engine High heat, high stress. Called severe operating conditions,(adjust valves more often). This condition usually found on trucks, buses, heavy laden vehicles. Higher, normal rpms will be less wear.
Hercules
