STD Tuning Engine holset 35 super vs masterpower (4449-2 or 545-2)
offroadbakos
12-20-2011, 07:00 AM #1
ok i need your input !!!Big Grin
so far i have
1 X om605 turbo engine
1 X om606 turbo engine
kkd manifold (to order)
myna pump (to order)
goal is 280hp min -350 hp max
torque ?? as much as possible as low as possible
the car wdb 461.336 (G wagen '99)
wich of the following turbochargers would be the better choice since they are at a similar price range
thank you all for your input Big Grin
offroadbakos
so far i have
jeemu
457
12-22-2011, 10:36 AM #2
How about between those two Master Powers?
R474-3
jeemu
R474-3
offroadbakos
12-22-2011, 01:52 PM #3
(12-22-2011, 10:36 AM)jeemu How about between those two Master Powers?
R474-3
i hear you Big Grin thanks for your input .
is this a turbo i can use with both engines?
sorry for being apain in the ..... Rolleyes but i ask because i intend to run both engines with similar set up (myna ip & kkd manifold)
thanks again
offroadbakos
R474-3
thanks again
jeemu
457
12-23-2011, 09:16 AM #4
Hi. Of cource you can.
jeemu
antonmies
Go MPR
59
12-23-2011, 10:10 AM #5
I would say 474-3 is OK for both engines, but in OM605 it would spool a bit later. Ask Kalle for 38mm runners for better response (I think it's a default).
antonmies
offroadbakos
12-24-2011, 08:06 AM #6
(12-23-2011, 10:10 AM)antonmies I would say 474-3 is OK for both engines, but in OM605 it would spool a bit later. Ask Kalle for 38mm runners for better response (I think it's a default).
hi Anton i have one more question on your site it describes the turbos as watercooled does this mean i have to route engine coolant or can i use the oil cooling like with the original turbo?
offroadbakos
antonmies
Go MPR
59
12-27-2011, 06:00 AM #7
(12-24-2011, 08:06 AM)offroadbakos
It's recommended to use the watercooling. It greatly reduces oil clogging due to high temperature afer shutdown.
Easiest way to do this is to take the water from cabin heater's water hoses for example. I have necessary banjo bolts and push lock fittings for the turbo.
Without the water in the jacket, the air within acts as heat insulation reducing the radiation from the bearing housing surface.
antonmies
offroadbakos
12-27-2011, 09:23 AM #8
(12-27-2011, 06:00 AM)antonmies
thanks Anton i stay in touch for details since i never seen a watercooled turbo you will have to provide me with all the necesary fittings and shematics
offroadbakos
antonmies
Go MPR
59
12-27-2011, 09:30 AM #9
(12-27-2011, 09:23 AM)offroadbakos
(12-24-2011, 08:06 AM)offroadbakos hi Anton i have one more question on your site it describes the turbos as watercooled does this mean i have to route engine coolant or can i use the oil cooling like with the original turbo?
I will do that for you!
antonmies
offroadbakos
12-27-2011, 09:34 AM #10
(12-27-2011, 09:30 AM)antonmies
(12-27-2011, 06:00 AM)antonmies It's recommended to use the watercooling. It greatly reduces oil clogging due to high temperature afer shutdown.
you really are fast ...i am impressedBig Grin i will contact you after holidays for details on email happy new year!!!
offroadbakos
antonmies
Go MPR
59
12-27-2011, 10:23 AM #11
Happy new year to you too! Actually, happy new year to everybody!
[Image: xmas_english.jpg]
antonmies
offroadbakos
09-27-2013, 06:29 AM #12
After a long stand still , due to the situation at home , I am getting ready to continue.
A Big thanks to Anton for his help.
The input of Jeemu as always very helpfull.
turbocharger is here , what a sensation (my wife got a bit jealous of the way I was petting the turboBig Grin ).
KKD manifold ....Nice work Kalle , and the wastegate ,all finally here.
now I am waiting till mid oktober for the Myna ip.
pictures to follow.
offroadbakos
pictures to follow.
offroadbakos
09-27-2013, 11:29 AM #13
ok lets try to upload
offroadbakos
09-27-2013, 01:07 PM #14
Shiny and pretty.
Shiny and pretty.
antonmies
Go MPR
59
09-27-2013, 01:28 PM #15
Looking forward hearing about how this turbo performs with 606
antonmies
offroadbakos
09-28-2013, 03:58 PM #16
(09-27-2013, 01:28 PM)antonmies Looking forward hearing about how this turbo performs with 606
if you come to Austria next summer you can have a go with my Gwagen
offroadbakos
 12 Guest(s)
 12 Guest(s)
