STD Tuning Engine w202 om605
w202 om605
w202 om605
bigricknl
01-04-2012, 08:56 AM #1
Hi i"m rick from the Netherlands.
i was lurking for ever on the forum to get info about the om605 becaus i have a w202 om605 and want to have some more Hp.
After searching i still have some questions about the Turbo, chip ect.
I asked dieselmeken on youtube if he can make my electronic pump produce more fuel , that was no problem he said,actual quote "Yes I do EDC pumps also, for that purpose you need bigger elements, and a nice turbo + a remapping of your ECU". Are there known re-mappers for the w202 om605 ?
could not find usefull info, only chip tuners.
And what kind of a turbo do i need ? i was thinking about a garret gt 25 or a holset hx30 or some turbo brand that's equal,
a fast spool up would be great, i dont want to revv the engine to 3000rpm evertytime i am at a stoplight.
I was hoping to get 100 a 150 hp extra ,
Some input would be great.
Greetz from the Netherlands
This post was last modified: 01-04-2012, 08:58 AM by bigricknl.
bigricknl
bad3gakk
om605 - kkk27 - w124
52
01-06-2012, 03:29 PM #2
Turbo size depends on the amount of diesel you will be giving it... Hy35 hx30 etc doesn't sound wrong..
bad3gakk
bigricknl
01-06-2012, 06:02 PM #3
(01-06-2012, 03:29 PM)bad3gakk Turbo size depends on the amount of diesel you will be giving it... Hy35 hx30 etc doesn't sound wrong..
The pump will go to dieselmeken (if he wants to do it) and he probably knows what to do with the pump.
Like i said i dont want it to be a 5000+ rpm engine. just want to have more Hp and torq in the normal rpm range.
What i had in mind was a KKD motorsport jeemu style om605 exhaust with a holset hx30 turbo,
and ofcourse a built pump, 3" exhaust, larger intercooler ect.
But realy want to know if i can daily drive with the setup above and when the turbo is going to spool aprox.
This post was last modified: 01-06-2012, 06:06 PM by bigricknl.
bigricknl
bigricknl
01-09-2012, 06:09 AM #4
Nobody ?
bigricknl
Nobody ?
dieselmeken
01-09-2012, 02:34 PM #5
(01-09-2012, 06:09 AM)bigricknl Nobody ?
Of course, take a pm to INC here on std, I made a 605 EDC pump to him with tomniks element, It worked out perfect with the standard ecu, now he is going to remap it so that he get most power out of it.
I will help you with your pump if you want me to.
dieselmeken
bigricknl
01-12-2012, 10:42 AM #6
(01-09-2012, 02:34 PM)dieselmeken
After allot of more reading and thinking, i think it's smarter if i use a om602 pump, that way i can make my car stock again with the original parts if needed.
nevertheless the om602 pump needs to be adjusted too , so i will contact you some time soon.!
I'm planning to oder a Holset Hx30 At an local Holset dealer, but i need to have the code thats stamped on the metal plate of the turbo, ( he said that there are 20+ HX30 turbo's but all diverent) but sinds i dont have a holset hx30 i dont "the"code, is there some one that has a code of an Holset hx30
Or a list with codes for a Holset hx30 ?
Greetz from the netherlands
This post was last modified: 01-12-2012, 10:47 AM by bigricknl.
bigricknl
