STD Tuning Engine OM 642 + GTB 2260 VKLR
Pages (2): 1 2 Next
diesel2fast4u
12-27-2011, 08:15 AM #1
look what I got in the mail
[Image: 2260_2.JPG]
[Image: 2260_1.JPG]
now let's see what DPF removal, EGR blocking, GTB2260VKLR & a tuner with experience will get out off this diesel...
Grand cherokee WK (OM642)
diesel2fast4u
[Image: 2260_2.JPG]
[Image: 2260_1.JPG]
majesty78
12-27-2011, 10:29 AM #2
This is possibly one of the best small frame vnt turbos currently available! And the only ballbearing vnt at the moment....
Have fun with it, and please take some pictures without the caps ;-)
majesty78
Rub87
02-06-2012, 05:44 AM #3
So.. maybe we should open a new topic:
OM642 + Alternative Fuels: HCCI Combustion
Rub87
diesel2fast4u
02-06-2012, 01:39 PM #4
(02-06-2012, 05:44 AM)Rub87 So.. maybe we should open a new topic:
Don't you dare Smile
diesel2fast4u
Rub87
02-06-2012, 02:34 PM #5
It's magic Tongue
Rub87
It's magic Tongue
diesel2fast4u
02-06-2012, 05:08 PM #6
(02-06-2012, 02:34 PM)Rub87 It's magic Tongue
Brake cleaner 1
OM 642 0
diesel2fast4u
Brake cleaner 1
OM 642 0
nilsson
02-07-2012, 02:38 AM #7
Which car did that charger come from? Inducer diameter?
//Nilsson
This post was last modified: 02-07-2012, 02:39 AM by nilsson.
nilsson
//Nilsson
Rub87
02-07-2012, 02:41 AM #8
Inducer is same like other gtb2260vk, 44.5mm IIRC, comes from OM642LS, around 190kW stock
Rub87
majesty78
02-07-2012, 02:48 AM #9
Correct.
Turbo is from latest 350CDI Bluetec engine with 265hp.
Regards, Alex
majesty78
Correct.
Regards, Alex
parkles
02-11-2012, 10:13 AM #10
(02-07-2012, 02:48 AM)majesty78 Correct.
Regards, Alex
If you don't mind, where did you source this from i'm after one for a project on 1.9 GM cdti engine
thanks
parkles
Regards, Alex
thanks
diesel2fast4u
02-18-2012, 01:06 PM #11
It's not exactly plug & play ...
Turbo mount is different
New vs old, new turbo mount has a hole for the watercooling
[Image: IMAGE_709C726A-7715-42BF-A3F8-5D3888E0C218.JPG]
[Image: IMAGE_2C1E6903-23A3-4B95-A0CB-224239E3EC39.JPG]
Water outlet in the turbo
[Image: IMAGE_DB562811-8868-43D5-B448-87D1E3058B82.JPG]
Plugged the bottem water feed an tapped a new one in the turbo mount
[Image: IMAGE_CEF6DB9F-455F-4160-BBA2-C92B90993237.JPG]
Tapped into the block to feed water to the turbo
[Image: IMAGE_90181267-EDC9-4539-9162-AAB36F7C0802.JPG]
Blocked the EGR & It fits :
[Image: IMAGE_6E2D59A1-BFF2-440A-BB14-947719C5C91A.JPG]
This post was last modified: 02-18-2012, 01:09 PM by diesel2fast4u.
diesel2fast4u
diesel2fast4u
10-30-2012, 04:21 PM #12
Hi, so I finaly found a place where we can dyno without having any work done to the car.
It was not us but an employee from the place who was doing the pulls.
Out of 8 - 9 pulls we only had 4 good ones.
ESP was fully switched off.
First & 2nd pull, my tune wich I drive now for 30.000 km
Only in the first pull he could give full throttle without downshifting.
The computerscreen was calibrated till 210KW and it flat spotted from 3200 to 4200 rpm, so this would have been the best pull but I don't have a print out.
2nd pull was 205KW/3473RPM & 670NM/2541RPM (second page highest line)
Just a little haze out of the exhaust
Now we loaded standard map, no DPF, no cat (First page)
3th pull was 163KW/3811RPM & 429NM/2919RPM
Now I thought let's make a dyno queen so we added 10% more fuel
4th pull was 200KW/3568RPM & 665NM/2486RPM
Lots of smoke
This is where I was shure that the guy behind the wheel wasn't pushing full throttle.
Anyone know how we can avoid the downshifting?
.pdf
Doc - 30-okt.-2012 20-36.pdf
diesel2fast4u
Lots of smoke
.pdf
Turbo
10-31-2012, 01:34 PM #13
How do the boost level look like?
Turbo
diesel2fast4u
10-31-2012, 06:52 PM #14
(10-31-2012, 01:34 PM)Turbo How do the boost level look like?
1.6 bar only, we need a 4 bar map sensor and find the calibration in the ECU to achieve higher boost levels.
You can see in the original map, the dip in the dyno sheet is because the turbo spools faster then stock, it hits the boost limit & cuts down, then picks up again...
diesel2fast4u
Austincarnut
10-31-2012, 08:26 PM #15
I have one of those turbos w/ very low mileage, has a bad actuator if anyone is interested. 642's and biodiesel don't get along. MB put out a good document about how it really destroys these engines.
(10-31-2012, 06:52 PM)diesel2fast4u
Austincarnut
majesty78
11-01-2012, 04:48 AM #16
Also make sure to correct the open and closed loop boost mappings for achieving good boost control ;-)
majesty78
Turbo
11-01-2012, 03:38 PM #17
austincarnut I would be very interested of the turbo, please pm me if you still is interested in selling it
[quote='Austincarnut' pid='45537' dateline='1351733168']
diesel2fast4u do you have how the boost as function of rev is responding?
This post was last modified: 11-01-2012, 03:44 PM by Turbo.
Turbo
gaiex
11-28-2012, 07:42 PM #18
If possible and for a good information on this thread, and if anyone knows it, the teorical/real maximum values for:
-Injectors mm^3/hp
-mass air flow rate lb/min
-cylinder heads cfm's
-turbo boost BAR
etc...
I will do some measurements on air flow and injection soon and will post my results. If you have any please post. Wink
gaiex
-Injectors mm^3/hp
-turbo boost BAR
etc...
jaro4444
01-16-2013, 02:58 PM #19
(02-18-2012, 01:06 PM)diesel2fast4u It's not exactly plug & play ...
Hi guys!
I have a question about mounting GTB2260VKLR on the motor OM642.920.
I know that the flanges are identical as GT2056V. I know about part number A6420961145 - turbo mount, gasket A 6421420681 and A6421420981. I know how make water output from the turbo.
My question is how make the water inlet to the turbo? Just drill a hole as shown gasket A 6421420681 in motor block?
Thanks for your help
jaro4444
Hi guys!
Alastair E
Moderator?--Nah...
266
01-16-2013, 04:15 PM #20
(10-31-2012, 08:26 PM)Austincarnut I have one of those turbos w/ very low mileage, has a bad actuator if anyone is interested. 642's and biodiesel don't get along. MB put out a good document about how it really destroys these engines.
Yup--Its the DPF situation that causes most of the incompatability issues with BioDiesel....
Its pretty nice then that the OM.642 imported to the UK market--Doesnt Have that Nasty Device fitted, as far as I'm aware!
Here in the UK, DPF's cause more trouble than anything else on diesel-vehicles! 'Orrible bloody things! There's loads of Co's doing DPF deletes here!
[Image: 300TDnoplate.jpg]
Alastair E
majesty78
01-17-2013, 12:37 AM #21
(10-30-2012, 04:21 PM)diesel2fast4u Anyone know how we can avoid the downshifting?
On W211 there should be some "dyno mode" which can be activated over cluster menu.
majesty78
bqik
01-28-2013, 08:09 AM #22
(01-17-2013, 12:37 AM)majesty78
yes, there is a "secret menu" and there you will find a dyno mode submenu.
regards
bqik
regards
diesel2fast4u
09-24-2013, 07:53 AM #23
(01-28-2013, 08:09 AM)bqik
regards
It's in a jeep grand cherokee
(01-16-2013, 02:58 PM)jaro4444
Hi guys!
just take water before and after the radiator or do like I did, tapped the block and out into the reservoir
This post was last modified: 09-24-2013, 07:55 AM by diesel2fast4u.
diesel2fast4u
regards
Hi guys!
diesel2fast4u
04-07-2017, 06:33 AM #24
After I broke 400Hp and 900nm on my audi 3.0tdi I am picking up this project again.
Could anyone help me with:
- DAMOS file EDC16 OM642
- 4 bar Map (PNP if possible)
- 2000+ bar rail pressure sender
thanks
diesel2fast4u
thanks
starynovy
04-07-2017, 08:23 AM #25
You will find this 400kPa MAP on OM651, costs 20€ brand new BOSCH.
starynovy
Austincarnut
04-08-2017, 03:29 PM #26
(12-27-2011, 08:15 AM)diesel2fast4u look what I got in the mail
[Image: 2260_2.JPG]
[Image: 2260_1.JPG]
Do you guys see any aftermarket parts for main and rod bearings available in europe after machine work?  We can't get anything from what I've seen
Austincarnut
[Image: 2260_2.JPG]
[Image: 2260_1.JPG]
diesel2fast4u
04-08-2017, 08:34 PM #27
I can check for you, what do you need exactly?
diesel2fast4u
diesel2fast4u
04-08-2017, 08:35 PM #28
(04-07-2017, 08:23 AM)starynovy You will find this 400kPa MAP on OM651, costs 20€ brand new BOSCH.
thanks!!
Rail pressure sender pnp ? Smile
diesel2fast4u
thanks!!
WSchotty
04-16-2017, 10:22 AM #29
The part number for that 4 bar sensor is 0101537228.
The OM642LS rail pressure is higher on these by default, but only by 200 bar. The om651 uses 2000 bar, check this out:
http://ae-plus.com/features/mercedes-ben...sel/page:3
I haven't tried swapping the om651 sensor to the om642, not sure of the correct part number or if the threads are the same. Here are the om651 rail and sensor numbers I could find:
Fuel rail number:     A6510700495
Sensor number:     9307Z521A or 55PP22-01
The original CP3 on my wk has started to make some noise (A6420700301), I just ordered a pump for the LS engine (A6420701201). Will find out soon if it is plug and play. Over time I will slowly upgrade the whole fuel system to the later type. I also have a GTB2060V (same compressor as 2260, slightly larger exhaust turbine) from a w222 and a new pedestal that I am going to swap in using your above method when I do the oil cooler seals and EGR delete. Thank you for the inspiration! Looking forward to your next maps.
https://www.youtube.com/watch?v=oHexdNW_N0Y
WSchotty
Austincarnut
04-16-2017, 10:26 AM #30
(04-08-2017, 08:34 PM)diesel2fast4u I can check for you, what do you need exactly?
In general, We see 642's come in seized at the mains at 100K miles.  They don't seem to hold up well after an oil cooler but we've had more than a few that have seized with all maintenances done and no repairs to the engine.  I have a 2008 164 with one that I wish I could swap out with a 606.  I guess we'd like to know if anyone was supplying oversized mains, rod bearings.  Its crap that rods have to be replaced if loosened...
Austincarnut
Turbo
04-17-2017, 09:10 AM #31
(04-16-2017, 10:22 AM)WSchotty I also have a GTB2060V (same compressor as 2260, slightly larger exhaust turbine)
I suppose you mean smaller Wink
Turbo
WSchotty
04-17-2017, 10:30 AM #32
(04-17-2017, 09:10 AM)Turbo
That is right, not sure what I was thinking about there. Here are the sizes for each for future reference:
comparison between GTB2260VKLR and GTB2060VKLR:
stock power: ______265hp __________240/258hp
compressor (mm): _ 44,5/60 ________ 44,5/60
turbine (mm): _____ 50/46 _________ 47/44
turbine tip high: ____ca.8,5mm ______ca.8,5mm
VNT nozzle high: ___ 8,5mm ________ 7,5mm
WSchotty
04-17-2017, 03:04 PM #33
Sorry to interrupt, are those the ones with ball bearings?
04-17-2017, 03:05 PM #34
How many blades have the turbines?
diesel2fast4u
04-17-2017, 03:10 PM #35
yes ceramic ball bearing
diesel2fast4u
Turbo
04-22-2017, 01:16 AM #36
(04-17-2017, 03:05 PM)barrote How many blades have the turbines?
9 on gtb2260vklr
Turbo
9 on gtb2260vklr
diesel2fast4u
04-22-2017, 02:18 PM #37
(04-16-2017, 10:26 AM)Austincarnut
We see a lot of high mileage engines here and not so many reports of problems
diesel2fast4u
Turbo
04-22-2017, 02:52 PM #38
why not go up in viscosity grade on motor oil for better protection then?
Turbo
Turbo
04-22-2017, 02:52 PM #39
diesel2fast4u, how did it go with the boat engine with double GTB2056vl turbos?
Turbo
diesel2fast4u
04-24-2017, 02:22 AM #40
I took the dust of the project this weekend. I moved the whole company and that was a priority Smile
diesel2fast4u
Turbo
04-27-2017, 12:57 PM #41
Why has it been standing so long?
Turbo
diesel2fast4u
04-29-2017, 04:42 PM #42
business wise to busy.
I have a company that I moved to a new place.
And I was busy with my daily audi 3.0 tdi
[Image: CLMa92KLs3RDB3zQiXXv6gSxxhROq11GCUKtqOQ3...90-h666-no]
This post was last modified: 04-29-2017, 04:43 PM by diesel2fast4u.
diesel2fast4u
Turbo
04-29-2017, 04:47 PM #43
may I ask what you did with the turbos?
Turbo
diesel2fast4u
04-30-2017, 10:28 PM #44
I still have them why?
diesel2fast4u
Turbo
04-30-2017, 11:30 PM #45
I was thinking of what you did to the turbo to get 400 on your daily audi 3.0 tdi or you just turn them up?
Turbo
diesel2fast4u
05-01-2017, 05:32 PM #46
(04-30-2017, 11:30 PM)Turbo I was thinking of what you did to the turbo to get 400 on your daily audi 3.0 tdi or you just turn them up?
hybrid ball bearing turbo 51/49,  its a really light and efficient 9 blade design with small 'heart' looks like stock under the bonnet
This post was last modified: 05-01-2017, 05:33 PM by diesel2fast4u.
diesel2fast4u
Turbo
05-02-2017, 11:52 AM #47
ok, you must be rarfshore on tdiclub.com I guess then Wink
Turbo
Josht
06-11-2017, 11:00 AM #48
Anymore progress on this build?
Josht
diesel2fast4u
06-12-2017, 07:05 PM #49
(06-11-2017, 11:00 AM)Josht Anymore progress on this build?
yeah I received my new hybrid, will mount soon
diesel2fast4u
Josht
09-04-2017, 05:26 PM #50
Any update
Josht
Any update
Pages (2): 1 2 Next
 24 Guest(s)
 24 Guest(s)
