STD Tuning Drivetrain 4 Speed Questions
4 Speed Questions
4 Speed Questions
w123love
Stockish
354
02-07-2012, 12:53 AM #1
This will be an ongoing thread with many questions...hopefully there are some answers out there.
This is for a 4 speed manual going into my 300TDT wagon....hopefully just a bolt on operation since the bell-housing is correct for the 3.0T
#1.....What bolts have people used to attach the pressure plate to the flywheel??? I’ve been trying to find pictures and specifics but have had no such luck. Anybody know?
The VEGEWGN
w123love
The VEGEWGN
02-07-2012, 05:31 AM #2
They are just plain allen bolts. Get them from the hardware store.
vstef_is
02-07-2012, 07:46 AM #3
(02-07-2012, 05:31 AM)aaa They are just plain allen bolts. Get them from the hardware store.
Just make sure they have some strength - I.e. get the 10.8 class not the softer 8.8 class.
vstef_is
w123love
Stockish
354
02-07-2012, 05:28 PM #4
Oh great thanks. I noticed most of the drivetrain bolts are 8.8. I.e. the six on the torque converter. Schweet.
#2. How do I make a square peg fit into a rectangular hole? The mechanical speedo on my wagon is a square peg, while the female entrance is a rectangular hole. Any simple solutions?
The VEGEWGN
w123love
The VEGEWGN
02-07-2012, 06:51 PM #5
Switch to the matching speedo cable. There was some switchover date, I think the one you want is the older style.
w123love
Stockish
354
02-07-2012, 11:26 PM #6
I scoped about a dozen different w123s, at the PaP yesterday, with no such luck. That was my original plan. I found a w123 with a 4 speed still intact, but it had a later all aluminum manual. Wrong cable yet again.
I will continue to scope, but at the same time I will start formulating a plan of action.
The VEGEWGN
w123love
The VEGEWGN
02-08-2012, 12:53 AM #7
Wow I'm lucky if I find one or two w123's at the local PaP lol, we'll see how they are this trip though
vstef_is
02-08-2012, 01:49 AM #8
It's gonna work anyway - speedo cable wise.
If not here's a 'trick' - take a beer can, drink beer first, cut a small patch, fold it in two, and place the square in the fold. Mount speedo cable with said mod.
Naturally the best route would be to order the correct speedo cable (they're not very expensive)
vstef_is
w123love
Stockish
354
02-08-2012, 02:40 PM #9
Ooooo good call on ordering the right speedo cable. I will look into that. Meanwhile I will prepare for whatever by drinking that beer. Better to be prepared than not.
The VEGEWGN
w123love
The VEGEWGN
02-08-2012, 06:55 PM #10
(02-07-2012, 05:28 PM)w123love Oh great thanks. I noticed most of the drivetrain bolts are 8.8. I.e. the six on the torque converter. Schweet.
I doubt you can go backwards as easily, but I made the rectangular peg fit in the square hole by grinding and shaping it down.
maybe you could try jbwelding or straight spot welding some tabs to the side of the square connector, and filing it down. Square folded patch like mentioned above would probably work better
Best option is go find another speedo cable that matches, but it would be interesting to see what rigged solution might work great.
My ground down speedo cable never had a single problem
This post was last modified: 02-08-2012, 06:56 PM by JB3.
w123love
Stockish
354
02-08-2012, 11:23 PM #11
(02-08-2012, 06:55 PM)dropnosky My ground down speedo cable never had a single problem
I’d much rather be in your situation. Taking metal away rather than adding to it. I’ll have to look again at the PaP.
I looked at only the top ends that connect to the odometer/speedometer. Maybe that fitting is always square? Does anyone know?
Anywho i’ll go down and cut off one end of a square one to mock up a modification to it.
Just a note...I called the dealer and a older style cable is $105 new. Bugger.
The VEGEWGN
w123love
The VEGEWGN
vstef_is
02-09-2012, 03:26 AM #12
A lot of cars here just work with the beer can trick. Not a problem...
vstef_is
w123love
Stockish
354
02-09-2012, 02:31 PM #13
Shhhhh....(don’t tell my dad....but i’m going to do the beer can trick!) lol
The VEGEWGN
w123love
The VEGEWGN
vstef_is
02-09-2012, 04:03 PM #14
(02-08-2012, 11:23 PM)w123love I looked at only the top ends that connect to the odometer/speedometer. Maybe that fitting is always square? Does anyone know?
Yup, on the speedo end they're always square.
vstef_is
02-10-2012, 08:32 AM #15
check out this thread, lots of measurements in it-
http://www.superturbodiesel.com/std/Thre...four-speed
w123love
Stockish
354
02-18-2012, 11:33 PM #16
Question #3 I think...
Does anyone know of a good write up for wiring the reverse lights to the 4-speed shifter?
The VEGEWGN
w123love
The VEGEWGN
02-19-2012, 02:15 PM #17
(02-18-2012, 11:33 PM)w123love Question #3 I think...
Easy, 4 wires going to the auto transmission that you pull back inside the car. Wire the violet and white and solid violet to your neutral safety swich on the pedal (or together to bypass not in park safety switch), and the other two wires (forget the color) are the reverse switch lights, wire directly to the swith on your shifter
w123love
Stockish
354
02-19-2012, 09:37 PM #18
(02-19-2012, 02:15 PM)dropnosky
Thanks for the clarification. I ended up pulling a OEM pigtail off of a 240 that was at the PaP this morning. Plugged right in like the NSS. Then it plugged into the shifter plunge switch.
Bittersweet day today, got everything installed.
Two problems though:
#1--> Managed to break a shifter linkage while trying to lengthen it. Probably will be able to find another one tomorrow.
#2--> The clutch is not engaging. When I push the clutch in, it actuates the slave cylinder, but nothing happens beyond that. With the clutch in, the wheels will start moving if the car is shifted into first. I will post a more in depth question on W123love's TDT
Thanks
The VEGEWGN
w123love
Thanks
The VEGEWGN
fte
02-19-2012, 10:05 PM #19
Sounds like you have air in the line, if you blead the system then it most likely is a bad slave or master.
fte
w123love
Stockish
354
02-19-2012, 11:43 PM #20
See that is the problem. I bleed the system. Fluid would fly out of the slave’s bleeding nipple when the clutch pedal was depressed. With the nipple closed, the the slave cylinder would push its rod. So now the problem is inside the transmission. (I believe)
Just a note: When I was connecting all the clutch lines, the brake fluid would flow very easily. (Just gravity fed) I would make a connection, and then 2 minutes later the fluid would start dripping out the open end. This happened all the way to the slave cylinder. Then it started dripping out of the slave. I bleed it a little bit, but more and more fluid was coming out so I called it good.
The VEGEWGN
w123love
The VEGEWGN
 15 Guest(s)
 15 Guest(s)
