STD Tuning Engine 606A with mechanical IP question..
huseyin55amg
02-14-2012, 03:20 PM #1
hi there. i have question i was hoping to get an answer from you guys. i recently fitted a 606a to my g wagen . i had a mechanical IP fitted and was told that i had to change the toothed gear that adjusts the timing. it runs off the timing chain infront of the pump. is the original toothed gear for timing fitted to the 606a really different ?
i think my mechanic is trying to con me !!!
rgds hus.
huseyin55amg
rgds hus.
EDH_Performance
02-14-2012, 05:58 PM #2
(02-14-2012, 03:20 PM)huseyin55amg hi there. i have question i was hoping to get an answer from you guys. i recently fitted a 606a to my g wagen . i had a mechanical IP fitted and was told that i had to change the toothed gear that adjusts the timing. it runs off the timing chain infront of the pump. is the original toothed gear for timing fitted to the 606a really different ?
rgds hus.
If the original pump was an turbo ip(electric), i don`t know. But the mechanical om603.910/962 and om606.910 has the same toothed gear in the front.
The only thing i can think of, is maybe the electrical IP doesn`t have the timing guveoner that is fitted to the that toothed gear.
I have a stock om606.910 (the same as om603) fitted to my 606 turboSmile
EDH_Performance
rgds hus.
huseyin55amg
02-14-2012, 11:39 PM #3
(02-14-2012, 05:58 PM)EDH_Performance
rgds hus.
thanks for the reply. iwill carry on investigating...Cool
huseyin55amg
rgds hus.
erling66
SuperDieselVan
294
02-15-2012, 04:03 AM #4
I don't think they are different(I have not noticed any difference) and for sure you can use any of them. Remember that both the 606.962 and the 603 has mechanical pumps, it is just the rack that is electronically controlled on the 606, and that has nothing to do with timing.
HuhCoolTongue
erling66
HuhCoolTongue
huseyin55amg
02-15-2012, 09:57 AM #5
(02-15-2012, 04:03 AM)erling66 I don't think they are different(I have not noticed any difference) and for sure you can use any of them. Remember that both the 606.962 and the 603 has mechanical pumps, it is just the rack that is electronically controlled on the 606, and that has nothing to do with timing.
hmm,,,i slowly seem to be seeing the light ....!
thx
rgds hus
huseyin55amg
thx
rgds hus
E300TSC
Turbo-Supercharged
321
02-17-2012, 06:57 AM #6
If the pump came and gear came from an OM603, the vacuum drive is different. Also, the original gear from your engine will be compatible with the older pump.
Basically what I'm saying is that the gear will have to match the engine because of the vacuum pump drive. The gear will fit any of the pumps so no worries there.
E300TSC
huseyin55amg
02-17-2012, 03:08 PM #7
(02-17-2012, 06:57 AM)E300TSC If the pump came and gear came from an OM603, the vacuum drive is different. Also, the original gear from your engine will be compatible with the older pump.
hi there. thanks for the reply. so what you mean to say is that the original gear on a 606a is compatible with the 603 mechanical IP right ? so there is no need to change it at all .
rgds hus
huseyin55amg
rgds hus
E300TSC
Turbo-Supercharged
321
02-17-2012, 07:07 PM #8
Correct. The gears will interchange on OM601, OM602, OM603, OM604, OM605, OM606 injection pump. BUT, the gear must match the vacuum pump drive coupling for the particular engine.
Another way to say it is that the original injection pump gear stays with the engine regardless of which injection pump you use.
This post was last modified: 02-17-2012, 07:08 PM by E300TSC.
E300TSC
