STD Other Projects my w124 606 962 Superturbodiesel
  • 3 Vote(s) - 4.67 Average
01-23-2012, 06:20 AM #51
716.654
hansebanger77
716.654
offroadbakos
01-29-2012, 02:54 AM #52
(09-02-2011, 01:10 PM)aaa Here's the NA 606 linkage:
@aaa hi do you have a part number on this intake manifold?
because mine , has the air charging inlet underneeth , instead of on top.
Thank you
offroadbakos
Thank you
01-29-2012, 07:45 AM #53
It's the nonturbo one. 6061400511/6061400712.
offroadbakos
01-29-2012, 06:00 PM #54
(01-29-2012, 07:45 AM)aaa It's the nonturbo one. 6061400511/6061400712.
Thanks @ aaa
offroadbakos
Thanks @ aaa
03-02-2012, 04:18 PM #55
Tested some 225 45 17
ShyCoolBig Grin
hansebanger77
ShyCoolBig Grin
George3soccer
03-03-2012, 04:24 PM #56
looks badass love it
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
03-07-2012, 07:56 AM #57
(03-03-2012, 04:24 PM)George3soccer looks badass love it
http://www.youtube.com/watch?v=laMfqwA-J...yO_JXN4HMa
hansebanger77
majesty78
03-07-2012, 08:30 AM #58
Sauprolet ^^
majesty78
Sauprolet ^^
EDH_Performance
03-11-2012, 05:53 PM #59
hi mate,
how much boost are you feeding your engine? and how many cc do your pump give?
EDH_Performance
hi mate,
dieselmerc
03-18-2012, 02:53 PM #60
hi, did you give it less timing advance on the second dyno run and got more hp? what timing are you running now? i will run 20 before tdc on 8mm mynä, so you earned power by giving it less advance? didn´t understand what you ment...
dieselmerc
04-03-2012, 10:18 AM #61
hi guys
sorry for the late post..
about 2.2 bar on higher rpm
120cc fuel max
i was on 19° marker with this merc LED tool. at the 2. run i dont know exaktly.. i rotate the pump minimal outside.. jutst for fun and see what hapenss Smile so it is about 20 or 20.5 deg
hansebanger77
hi guys
120cc fuel max
huseyin55amg
04-11-2012, 04:25 AM #62
great work my friend ! love the colour too , bornite metallic.
huseyin55amg
09-07-2012, 02:43 AM #64
Awesome!
Awesome!
Bangaway
606 Turbo > Porsche Turbo
129
10-18-2012, 04:26 PM #65
http://www.youtube.com/watch?v=ICqeREP8J...re=related
I like this one even more. 0-100 in 10 seconds.
Hansebanger77: Who did you injection pump work? How much cc?
Bangaway
10-19-2012, 08:30 AM #66
Bad weels bad shift. But better than big racing slik and broken something :-) 100-200 under 8 ;-) pp diesel make this nice 7mm pump about 120cc
hansebanger77
Ksteen2
11-28-2012, 07:02 AM #67
(11-23-2011, 07:05 AM)hansebanger77 i think not many people look in drivetrain topics so im sorry i ask here again.
it was a 717 433 bevore and i bougth the same again. now its broken again. every time the 3. gear is damaged... 1. and 2. gear always spinning tires sometimes 3. too. because long diff. if i get grip the 3rd it break.. Sad
any better boxes on mercedes secor?
if it is not absolutely necessary, then I would shift myself. So no automatic.
thx
what car is that from??
is it a 5 speed from 124??
Ksteen2
thx
EDH_Performance
11-28-2012, 09:21 AM #68
(11-28-2012, 07:02 AM)Ksteen2
thx
All 5-speed gearboxes from w201/124 is rubbish! 3rd gear will always break with a bigger dieselpump and turbo Big Grin
EDH_Performance
thx
erling66
SuperDieselVan
294
11-29-2012, 03:08 AM #69
Well, all the standard ones are but not the W201 2.3 16v getrag box and I heard that w124 300e 24v gasoline used a good getrag box too :o)
HuhCoolTongue
erling66
HuhCoolTongue
Ksteen2
11-30-2012, 07:48 AM #70
how's the 5speed cdi box contra the 6speed cdi???
Ksteen2
Ksteen2
03-22-2013, 08:28 AM #71
what feed pump are you using?
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
03-23-2013, 11:54 AM #72
(11-30-2012, 07:48 AM)Ksteen2 how's the 5speed cdi box contra the 6speed cdi???
Dont know. Only have the 6speed and that hold until now. 716.654
(03-22-2013, 08:28 AM)Ksteen2 what feed pump are you using?
WALBRO 250L/h 3bar
This post was last modified: 03-23-2013, 11:55 AM by hansebanger77.
hansebanger77
WALBRO 250L/h 3bar
Ksteen2
03-25-2013, 03:30 AM #73
okei, I will be using a 6 speed from CLK 230, I don't know if it handle's it, It has a different number ;o
okei, just in to the pump at the original inlet?
or have you used both inlet an return for inlet fuel??
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
03-25-2013, 06:48 AM #74
Just in the Stock inlet at the pump and deleted the lift pump. Put for big power goal you must change the filter because to lees flow in the stock one.
hansebanger77
HaavardPYA
03-25-2013, 02:40 PM #75
I like your project very much! Cool sleeper! 8-)
I put my pump in at 14degrees BTDC. Is this right or is this to little advance?
HaavardPYA
Ksteen2
03-26-2013, 03:23 AM #76
you would get hard engine knock, it must be 14degrees ATDC
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
HaavardPYA
03-26-2013, 03:30 AM #77
My bad. ATDC ofcourse
HaavardPYA
Ksteen2
03-26-2013, 03:57 AM #78
14 deg's ATDC would be good Wink
but, it depends on who made your pump, the man who build it will make his own ignition point, but almost every one is between 15-22deg's and thats where you wanna be close to Wink
This post was last modified: 03-26-2013, 03:59 AM by Ksteen2.
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
03-26-2013, 06:33 AM #79
(03-25-2013, 02:40 PM)HaavardPYA I like your project very much! Cool sleeper! 8-)
Thx.
I have no much expiriance with that superpump now. I'm on 15. Runs good. Nex dyno I can adjust to 13 14 16 17 and see what is better. At my old pump It was much more torque if I adjust 1degree later this was 19 to 20 best resault.
hansebanger77
Thx.
Ksteen2
03-27-2013, 09:29 AM #80
Have you shortened the bell housing? or are u using a dual mass flywheel??
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
03-29-2013, 04:42 PM #81
I still use the Dual.
hansebanger77
HaavardPYA
03-29-2013, 07:54 PM #82
Is your dual welded?
HaavardPYA
03-30-2013, 06:47 AM #83
No 1 Time broke. I thinker I weld it but then I go for a used one. And it work again.
hansebanger77
HaavardPYA
03-30-2013, 07:29 AM #84
I seeSmile Do you know if the 716.640 is a dual mass flywheel gearbox?
HaavardPYA
03-30-2013, 09:53 AM #85
Not sure but I think all 716 is dual flywheel
hansebanger77
mantahead
03-31-2013, 03:05 PM #86
hi,
my dual mass was holding 385bhp and over 400lb ft.
mantahead
hi,
Kozuka
I'm_Badass
334
04-01-2013, 04:01 PM #87
(03-31-2013, 03:05 PM)mantahead hi,
OEM clutch?
Kozuka
OEM clutch?
08-05-2013, 12:05 PM #88
hi guys back angain with my projekt.
get build the big IC
was not much room for it but it fit good now.
ooh and i have install a 7.5 pump from göran long ago Smile the resault was nice because it was not full adjusted and got 800NM (before i had about 730). But only a fiew hp more. there is somwhere a threat from me: What Turbo for over 500hp there i have spoken about this hx 40 is over his range..
if i get some time the next steps
# i want to cut and weld my intakemanifold with front inlet as big as the IC outlet. i use the 606 NA because its so nice to adjust pump. i think i will use it again to weld some box on it.
# i must figute out where and how i should mount a external WG for the KKD manifold Sad i dont know how because its twinscroll and not many room for 2 wastegates...
# whaiting for the new turbo
how can i upload photos more than 500 kilobytes? or how to get it samaler.
thx
hans
hansebanger77
thx
hans
HaavardPYA
08-05-2013, 03:18 PM #89
What turbo have you bought?
I use the orginal N/A manifold too, what do you think is max for this manifold?
My turbo is a PTE 6766 with A/R0,96 turbinehousing.
HaavardPYA
08-06-2013, 01:02 AM #90
(08-05-2013, 03:18 PM)HaavardPYA What turbo have you bought?
Dont know what is the max. I think it's important how the box or plenum is made. I wait for pt 6766 t4 0.84 twinscroll ;-) I think I made an adapter for the WG pipe because I don't want destroy the nice manifold.
hansebanger77
Ksteen2
08-06-2013, 01:52 AM #91
good to see that you are working you'r prodjekt again Wink
how much power are you aming for?
600+whp?
1#
Originaly a d24tic
6speed cdi box
Ksteen2
600+whp?
1#
Originaly a d24tic
6speed cdi box
08-06-2013, 03:25 AM #92
At first I would be happy with about 500 and good power at higher rpm. I think 600hp is not so easy to reach without headporting. (my 606 never opend yet) Also I get massive of torque and would be lot of stress for all other stuff :-)
hansebanger77
maxypriest
08-06-2013, 08:02 AM #93
I am using a 606 turbo manifold and have put the NA 606 throttle mech on top for ease of adjusting. I’m planning to make a plenum that sits under the manifold, so the compressed air from the intercooler rises vertically, enters the plenum from the base and then across into the engine. The path of the air will be very similar as the OE setup, just widened and optimised.
When I have access to a home computer I will upload some pictures!
PS Hansebanger - i love those youtube vids of yours!
This post was last modified: 08-06-2013, 08:02 AM by maxypriest.
maxypriest
HaavardPYA
08-06-2013, 09:37 AM #94
Aha! Is the trwinscroll 0,94 and not 0,96? I also a bit of the orginal crossoverpipe so the air is in the orginal "direction" for the plenum. Will post photos as soon as the cooler system comes home from powdercoating.
I want photos of your enginebay;-)
HaavardPYA
08-06-2013, 11:50 AM #95
Cant Upload bigger Fotos :-(
hansebanger77
Ksteen2
08-07-2013, 05:08 AM #96
are you using photobucket??
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
08-07-2013, 05:31 AM #97
(08-07-2013, 05:08 AM)Ksteen2 are you using photobucket??
No but I check this
(08-07-2013, 05:31 AM)hansebanger77
No but I check this
http://s1344.photobucket.com/albums/p647...edia_share
This post was last modified: 08-07-2013, 05:42 AM by hansebanger77.
hansebanger77
No but I check this
No but I check this
08-07-2013, 10:41 AM #98
That is a BIG intercooler. Very nice. Did you remove the a/c condenser?
08-07-2013, 11:23 AM #99
Yes all AC stuff is remved :-)
hansebanger77
jellydonut
1987 W124 250D
21
08-07-2013, 02:05 PM #100
(08-05-2013, 12:05 PM)hansebanger77 hi guys back angain with my projekt.
thx
hans
Use imgur.com for image uploads. It's definitely the best image service around now.
jellydonut
thx
hans
 27 Guest(s)
 27 Guest(s)
