STD Tuning Engine Stupid question - VNT-turbo install - M21D24(BMW)
Diesel-Wiking
03-13-2012, 07:20 AM #1
Hello guys.
I've bought an VNT-turbo from 220cdi W211, since my original turbo is singing on its last phrase.
I have questions about the steering of VNT.
My question is stupid, but I want to give it a try:
-What happens if I weld the "WG-rod", or pressure steering rod, in locked position, or lock the vacuum intake-line? Will it be driveable? it will propably give very high turbo pressure and the vnt-system want be able to be controlled, but still, will it work?!
*1984 Mercedes S123 300TD turbodiesel*
*1993 BMW 525tdsT*
*1990 BMW 524 turbodiesel*
*1983 BMW 745iA e23*
*1969 BMW 3.0csl racecar*
Diesel-Wiking
Hello guys.
*1993 BMW 525tdsT*
03-13-2012, 09:02 AM #2
You can lock it into one specific place, you will have to monitor your boost levels to find the sweet spot for the actuator. I had my GT2056 setup so that it would still make 8psi on the highway when vacuum was removed.
Diesel-Wiking
03-13-2012, 09:06 AM #3
(03-13-2012, 09:02 AM)Simpler=Better You can lock it into one specific place, you will have to monitor your boost levels to find the sweet spot for the actuator. I had my GT2056 setup so that it would still make 8psi on the highway when vacuum was removed.
Thanks, I will give it a trySmile
*1993 BMW 525tdsT*
Diesel-Wiking
*1993 BMW 525tdsT*
led-panzer
03-13-2012, 09:14 AM #4
Get a second gauge for backpressure if you're going to do that.
1985 300D 280,000 miles RIP
led-panzer
Diesel-Wiking
03-13-2012, 09:19 AM #5
(03-13-2012, 09:14 AM)led-panzer Get a second gauge for backpressure if you're going to do that.
You think it will be a problem? or just to controll the backpressure?
*1993 BMW 525tdsT*
Diesel-Wiking
*1993 BMW 525tdsT*
Alastair E
Moderator?--Nah...
266
03-13-2012, 12:29 PM #6
(03-13-2012, 09:19 AM)Diesel-Wiking
It could well cause a problem.
Too much exhaust back-pressure can completely bog-down the engine, so it will make less power than a N/A engine and make LOTS of smoke!
The trick is to get the boost high and the back-pressure as low as possible,--Not easy!....
[Image: 300TDnoplate.jpg]
Alastair E
Diesel-Wiking
03-13-2012, 01:42 PM #7
(03-13-2012, 12:29 PM)Alastair E
The turbo is much bigger than the stock turbo and with bigger exhaust it might reduce the back pressure a bit, or?
I will give it a try, both with open and closed actuator, and then try to adjust it both up and down, to see if I make it work...
*1993 BMW 525tdsT*
Diesel-Wiking
*1993 BMW 525tdsT*
03-13-2012, 01:45 PM #8
For what it's worth, when I first ran my 2056V I had the actuator in backwards...The turbo spooled instantly , but wouldn't let me go beyond 2,000repm.
