STD Other Projects 1984 300td (drift project)
  • 1 Vote(s) - 5 Average
Theturbodave
05-15-2012, 06:25 AM #1
Hello I'm Turbodave.
I saw this 1984 300td in a impound lot earlier this year. It didn't run, it didn't have a back window and busted ignition cylinder. Well let's just say i got the car because i was the only one who would bid on it.
Some may not like what I have done. But keep in mind I got it to race,drift whatever.
I didn't buy this car to restore it or fix it up it was bought to use for drifting first and every thing else second. I know there are some different parts that could be used for this project but i like to use what I have on hand to keep cost down.
Here is what I started with.
This post was last modified: 05-15-2012, 11:35 PM by Theturbodave.
Theturbodave
Theturbodave
05-15-2012, 10:31 PM #2
Sorry pics not in order.
I did a base line run on dyno every thing stock it did have a exhaust leak at flex pipe but not bad. It did 81.5 hp and 159 tq automatic to the wheels bone stock w/factory exhaust and air cleaner box.
I then removed exhaust from down pipe back, put 3"cold air intake to k&n filter, deleted egr, adjusted throttle linkage to make sure going wot and deleted all vacuum lines from injector pump it did 101 hp and 197 tq to the tire.
I remove bumpers and changed to some wheels I had. I cut factory coil springs to lower it.(I changed this out later)
I picked up a extra injector pump for $200 at a junk yard.
I'm doing a turbo upgrade (I find out later this turbo has wayyyyy to much lag) he351 Dodge Cummings turbo(thanks led-panzer for correct number and yr).
While i was doing the turbo upgrade i did some intake manifold upgrading also.
Time for more dyno runs before getting to the fuel system.
This post was last modified: 05-16-2012, 11:51 PM by Theturbodave.
Theturbodave
SurfRodder
Jackass Extraordinaire
611
05-16-2012, 02:26 PM #3
nice work man! welcome to the forum... I dont think youll hear anybodu complaining about modifying the car here... there are other places for restoration minded people...
OBK# 62
SurfRodder
OBK# 62
05-16-2012, 03:43 PM #4
Cool stuff keep us posted!
tantank79
T3-45
109
05-16-2012, 06:35 PM #5
This is freakin' sweet Dave!!!! We need more details on all of this stuff.... (and please don't sell it, keep building it!)
Drift modified,
Coil overs (JIC rear coil overs w10k spring on custom made mounts )
Modified knuckles,
Welded diff,
Diesel om617engine 5cyl with twin compound turbos (primary turbo t3 50trim .61 a/r custom built, secondary turbo t4 57trim .96 a/r),
Will foot brake to 25psi. Instant boost No turbo lag.
Modified injector pump (rack limiter removed, 5800rev limited ect)
larger delivery valve,
larger injectors.
Adjustable fuel pressure regulator
High pressure fuel pump
4in exhaust system w/5in tip.
Makes 35 to 40psi.300hp/400tq.( Cut and modified DV's. Not idle happy, you can street drive it but very rough idle and OMG Smoke out the cars behind you.)
30ish on stock DV's (125hp260tq)
23mpg on med DV's (200hp300tq)
Takes about 20mins to change out Delivery Valves in injector pump.
Cold A/C, and has power steering.
Has full interior.
Daily driven.
Asking $5000 obo trades okay.
More here at the bottom of page
http://www.theturbodave.com/The_Build_page.php
http://atlanta.craigslist.org/atl/cto/2984019234.html
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
Drift modified,
Modified knuckles,
Welded diff,
larger injectors.
Has full interior.
Daily driven.
-Brian
1983 300TD
1982 240D
1981 280TE
led-panzer
05-16-2012, 08:27 PM #6
That holset is an HE351, comes on the 04.5 to 07 cummins. Same compressor as an HX40.
What turbos do you use for your compound setup?
1985 300D 280,000 miles RIP
led-panzer
iheartboost
05-16-2012, 08:49 PM #7
wow! thats awesome.
00 Mustang gt drift car
iheartboost
wow! thats awesome.
Theturbodave
05-16-2012, 09:49 PM #8
I'm trying to remember the order i did everything ???. I think I did the rack limiter delete, increased the rpm limit speed and max the what was it called alda (more fuel at take off). I can tell you this every injector pump is different (like someone on this form said the adjustment need to be done in small fine adjustment and telling someone to turn this 2turns doesn't mean it will work on all pumps, it is a 50 50.) I did one adjustment at a time and them tryed it out first before going to another.
THE BAD NEWS (like you could have problems when you are learning/messing with the injector pump's internal parts)
I put the the pump back on hook everything up hit the starter it cranked right up and instantly went to 5800rpm I snatched the fuel supply line to injector pump off (still at 5800rpm)and then went to snatch cold air intake pipe off wouldn't come off ,grabbed a nut drive to loosen clamp and stuck my magnetic bolt holder on inlet of turbo and it died. I would say atleast a 1 to 2 min at 5800. I'm looking around for what went wrong what the hell did I do wrong. Then I see it ,no spring on bottom throttle arm and linkage was bound up.
So I fixed that went to crank it sounds like no compression on atleast two cylinders. I'm at this point calling myself a dumba## and thinking it bent the valves from revving so high for that long. I just had to walk away for a while I pulled the valve cover to check for bent valves. I pulled cover and checked valve lash haaaa there is none, All of the lash adjusters had unscrewed hold almost all the valves open. I adjusted every one back to spec and started the wagon it runs better now than when I got it.
At this point I love this car.
This time on the dyno it has way to much fuel for factory turbo it made 125hp and 240tq waste gate held shut ?on how much boost , it looses power and tq bad on top end 4000rpm still rolling smoke. I'm turning it to 5700rpms. At this point I know it needs more airflow.
I put holset turbo on and i did intake manifold and just ran a 4" downpipe with no exhaust. This turbo is to big for a auto can't brake boost it and it creeps to 22psi. Dyno 145hp and 220tq hits 15psi at like 4600 rpm and 22 at 5600 and it hasn't got enought fuel from around 3600 and up. I know I need some fuel on the mid to top end and a little bit smaller turbo.
I have gone of the deep end now UPGRADES.
I got another set of injectors from junk yark and ordered new injector nozzles ( I think they were dnosd303 or 306) I will look for my paper work and get number. I put a 320lph (aftermarket mustang) fuel pump on deleted factory fuel pressure regulator and mechanical pump and put a adjustable fuel regulator w/ boost/vac line on and ran new fuel lines. I also did DV mod not full cut but milled lip to a tapper. Now this thing got some fuel.
I think the key is getting rid of factory pump and regulator. You can now run what ever fuel pressure you want and it increases fuel pressure with the boost level. I run 25/28 psi at idle and at 18 psi it makes 50psi.
I had a stage 2 turbo form a Buick Grand National that I had upgraded for 62-1 turbo and know it was a good one but it had the 3bolt mounting flange and .90 a/r exhaust. I milled a Garrett T3 exhaust housing with a .60 a/r to fit the 58mm exducer wheel and tappered mill the inlet houseing to fit a 3 1/2 inlet pipe. I tig welded a 3" v-band on exhaust housing for the down pipe. I drilled out the exhaust manifold to weld a 38mm wastegate. I ran wastegate dump back into the down pipe. I ran 3" down to 4" exhaust all the way out the back by rear axle.
Lets just say this turbo is the sh#t it will foot brake to what ever waste gate is. I set waste gate at 18psi. This turbo is bad as#. Instant boost you don't have to brake boost to spin the tires just nail it and instant cotton rolling from the tire 1st and 2nd gear Tries to blow through 3rd gear.
I will upload more pictures one these mods.
This post was last modified: 05-16-2012, 11:45 PM by Theturbodave.
Theturbodave
Theturbodave
05-16-2012, 11:42 PM #9
WERE DO YOU PUT AN INTERCOOLER ON THESE CARS. There is no room anywere and I'm not mounting outside the body(just not me).
I was thinking I could build an intercooler that looks like the grill and remove the factory one, but I don't think it will look right not being on the hood when you open it. I also thought of moving radiator to rear floor board and put intercooler were radiator was.
any help would be COOL.
Theturbodave
05-17-2012, 12:43 AM #10
First off, welcome to this forum. I saw your craigslist ad and link to your build, and was hoping to get more details on this wagon. Thanks for sharing your info!
The best fitting intercooler are the Air/Water type. If your not using your SLS pump, then you can remove the reservoir and put in an A/W intercooler in that area like this.
[Image: attachment.php?aid=207]
Then put the intercooler radiator in front of the engine's radiator.
Hercules
05-17-2012, 01:26 AM #11
Looking real good! Don"t think there would be enough air flow if radiator on rear floor board,plus mud,dirt,road stuff. There are posts on here what others
have done for intercooler,usually small units if inside. Water inj.is another option,pre-turbo should work well,cools incoming air plus allows air in turbo to be further compressed . Volvo states the compressor wheel should last 200 thousand miles.
Question: What is the Adj. fuel regulator w/boost/vac line from?
Hercules
05-17-2012, 02:01 AM #12
Hells yea man
Hells yea man
05-17-2012, 02:25 AM #13
Awesome, I want my car to drift one day, even if its just to show people the potential that diesel Mercedes like these have
05-17-2012, 08:22 AM #14
(05-16-2012, 02:26 PM)SurfRodder nice work man! welcome to the forum... I dont think youll hear anybodu complaining about modifying the car here... there are other places for restoration minded people...
Incorrect. Those are not the stock tires, and what hes doing with this car is not supported by the mercedes factory, plus, drifting will throw around his set of golf clubs and bottle of Perrier-Jouet with crystal stemware. For shame.
Big GrinBig Grin
Big GrinBig Grin
Theturbodave
05-17-2012, 08:29 AM #15
http://jalopnik.com/5907052/for-5000-get-my-drift
Found this i guess doing something different will get you noticed.
I think it is all good i won the vote and had 19,000 views on it.
Theturbodave
SurfRodder
611
05-17-2012, 11:18 AM #16
(05-17-2012, 08:22 AM)dropnosky Incorrect. Those are not the stock tires, and what hes doing with this car is not supported by the mercedes factory, plus, drifting will throw around his set of golf clubs and bottle of Perrier-Jouet with crystal stemware. For shame.
Big GrinBig Grin
I should've known that someone who hasn't modified very much would call me out on that!
Big GrinTongue
This post was last modified: 05-17-2012, 11:19 AM by SurfRodder.
OBK# 62
SurfRodder
Big GrinBig Grin
Big GrinTongue
OBK# 62
Kozuka
I'm_Badass
334
05-17-2012, 11:33 AM #17
You make me want to weld my diff and rock cut DV's for shits and giggles. I do have a spare IP...
Kozuka
erling66
SuperDieselVan
294
05-18-2012, 02:28 PM #18
Can someone please explain to me why cut DV's gives more HP? The elements are pushing the volume they are pushing so why does DV's has anything to do with that? Are the stock ones a restriction? I don't get it, maybe my brain is not working today?
HuhCoolTongue
erling66
HuhCoolTongue
05-18-2012, 04:52 PM #19
(05-18-2012, 02:28 PM)erling66 Can someone please explain to me why cut DV's gives more HP? The elements are pushing the volume they are pushing so why does DV's has anything to do with that? Are the stock ones a restriction? I don't get it, maybe my brain is not working today?
We're in the same boat! I am soo confused Huh
Kozuka
I'm_Badass
334
05-18-2012, 05:56 PM #20
(05-18-2012, 04:52 PM)sassparilla_kid
Well, the end-of-cycle is created by the collar below the seat on the delivery valve by cutting this you allow more fuel to seep by creating higher pressures in the injector lines causing more fuel to be delivered. but it's not so precise with the injectors opening at there pop pressure earlier beause of more fuel at higher pressures in the injector lines and lasting longer then the normal injection cycle.
Basicly, its a ghetto way of getting more fuel. It idles like shit, doesn't really have even power till about 15psi, touchy throttle, and has really high EGT's. It's defiantly like playing with fire. There was one guy that didn't remove the collar completely and said egts we're below the melting stuff zone, but still has the other issues. DieselMenkin says there is no way to overcome these issues thats why everyone 'recommends' you get a pump modified with bigger elements for more power.
This post was last modified: 05-20-2012, 03:22 PM by Kozuka.
Kozuka
Theturbodave
05-18-2012, 10:03 PM #21
Your right on poor man's fuel. If you have the money do it the right way get your pump and injectors done by a good injector pump shop.
I like to find other ways around cost. The cut Dv's are not for everyone. I did them three different ways, cut small knotchs, tapper cut and full cut. The tapper cut were the best all around with a good single turbo.
The problem is idle and egt vs boost with the cut Dv's (I have seen and read your posts on this and wanted to see what i could do with it).
If you have to much fuel you just add boost. Egts and boost(airflow) work together if you understand it that way you can make alot of power.
Example; alot of black smoke=high egt's = you need more boost or remove some fuel for that boost level.
A perfect setup is at your max boost level you have a slight black smoke out the pipe. You should be able to see through it easly. If you are rollin coal you egt are going to rise quickly.
I have spent alot of time on the dyno to see what does what.
This is why i did the compound setup. You will not be able to do cut Dv's if you can't supply the boost for the entire rpm range. The egt's are just to high. My set up does instant 12psi when you just touch the throttle in gear and then at 2200 is 28psi by 2800 its at 35psi. That's how it works
You can't get a single to work that way. Small turbo good at the bottom end, okay in mid, nothing on top end. Med frame turbo okay bottom, good mid , okay top. Big turbo never going to happen ,bottom end nothing ,mid range getting there, top end okay egt's are out there.
The idle( i have almost got the fixed w/some vacuum valves and fuel pressure control). I don't have it perfect yet put almost. When I do this forum will be the first to know.
This post was last modified: 05-18-2012, 10:49 PM by Theturbodave.
Theturbodave
05-18-2012, 11:35 PM #22
(05-18-2012, 10:03 PM)Theturbodave My set up does instant 12psi when you just touch the throttle in gear and then at 2200 is 28psi by 2800 its at 35psi. That's how it works
Fuuuuuuuuuuuuu................... That's a LOT of boost!!!!! I barely get 12psi after a while at full throttle, you get it instantly with just a touch!!! Man am I jealous right now lol
erling66
SuperDieselVan
294
05-19-2012, 03:06 AM #23
Thank you guys for info, I get it nowSmile
I can see that there is a ca 1mm spacing between the collar and the seat. the collar is obviously needed for the idle but if it could be moved closer to the seat, less fuel will be returned by the DV.
I have a theory how to do thisSmile You need a good lathe. Cut the collar and make a new one where the seat is and make a new seat on top of it. there should be metal enough below the spring seat. Maybe you need to take some of the spring seat but it should be strong enough.
It would be very interesting to hear if someone try this. My lathe is from 1930 and not exactly what you would call precise Tongue
Keep up the good work Dave, I really respect guys that gets power without just buying expensive parts.
Do you have some good photos of your compound set up?
HuhCoolTongue
erling66
HuhCoolTongue
Theturbodave
05-19-2012, 07:45 AM #24
I just slapped the compound setup together in two days to see if it would even work. Now that i know it does I'm going to build a nice refined system alittle more compact.
Theturbodave
Hotrodbenz
Boost and roost baby let's do some coke
46
05-19-2012, 02:37 PM #25
Pics of your compounds every said it wouldn't work I've got the stuff and it's going on my om603 in my 123 with the 6mm or 7 mm elements the bottom turbo is a h1c off a cummins it has a 18cm housing with no wg
Hotrodbenz
Hotrodbenz
46
05-21-2012, 10:38 PM #26
Hey turbodave think you would kindly post some pics of your compounds please
Hotrodbenz
05-22-2012, 08:55 PM #27
and some drifting videos! I wana see this beast in action!
Theturbodave
05-22-2012, 11:11 PM #28
I will post pictures and vids I have(I think i have vids of every stage on dyno). I just have alot of work I'm doing with twin turbo's kits on the 2010 Camaro's right now. I'll try get something uploaded at work (I can't upload them from my ipad).
This post was last modified: 05-23-2012, 06:23 AM by Theturbodave.
Theturbodave
Hotrodbenz
46
05-23-2012, 11:22 AM #29
What waste gates are u using would the stock ones not work? My h1c is not waste gated but I'm very interested in your piping if you are rebuilding it: )
Hotrodbenz
Hotrodbenz
46
05-23-2012, 01:38 PM #30
And what turbos are those
Hotrodbenz
dieselmerc
05-30-2012, 11:49 AM #31
nice! compund turbos is the shit! I have it too on a om606 with 8mm pump! garret t03 fed by holset hx52! works great instant spool and above 500hp!
dieselmerc
300SD_KY
super turbo diesel
121
08-27-2012, 06:53 PM #32
DieselMerc, can you post a youtube video (link) with a little commentary about your car?
(05-30-2012, 11:49 AM)dieselmerc nice! compund turbos is the shit! I have it too on a om606 with 8mm pump! garret t03 fed by holset hx52! works great instant spool and above 500hp!
quite jealous of your twin turbo.Exclamation
would love to compound turbo my 617
300SD_KY
08-27-2012, 11:31 PM #33
That wagon is bitchin
mike-81-240d
more like mike-84-300d now
427
09-03-2012, 04:06 PM #34
How have I never seen this... Simply awesome.
mike-81-240d
bigshrek
11-01-2012, 05:58 PM #35
What intakes manifold did you switch over to?
Thanks, Carl.
bigshrek
Thanks, Carl.
11-01-2012, 06:44 PM #36
Looked like a W115 or a custom job
CJP28
EX '79 300SD Owner.
45
11-20-2012, 05:41 PM #37
This is one badass wagon!!!!
CJP28
atypicalguy
03-03-2015, 05:26 PM #38
Was this real or a hoax?
atypicalguy
led-panzer
03-03-2015, 05:47 PM #39
I believe it was real. But the idea that he had 300hp with 5.5 elements is laughable
led-panzer
03-03-2015, 10:10 PM #40
I thought the same thing led, and how is the stock automatic trans holding that supposed power?
atypicalguy
03-16-2015, 06:26 PM #41
I asked mark from sun valley about the tranny and he said the stock auto would hold 250hp pretty reliably.
atypicalguy
mike-81-240d
427
03-18-2015, 03:49 AM #42
(03-16-2015, 06:26 PM)atypicalguy I asked mark from sun valley about the tranny and he said the stock auto would hold 250hp pretty reliably.
Maybe if you crank up the line pressure, and make the shifts earth shatteringly stiff.
mike-81-240d
atypicalguy
03-18-2015, 08:17 AM #43
250hp with a fresh auto trans is a rare combo.
atypicalguy
mike-81-240d
427
03-18-2015, 03:14 PM #44
(03-18-2015, 08:17 AM)atypicalguy 250hp with a fresh auto trans is a rare combo.
I've had two fresh autos go out at stock horsepower. One was rebuilt with paperwork. The other was brand new OEM mercedes, not rebuilt.
I don't see 250hp being a reality, unless you start dicking with line pressure and or adding in extra clutches when being rebuilt.
mike-81-240d
atypicalguy
03-18-2015, 05:44 PM #45
Bummer. But it sounds like high HP was not the culprit then?
atypicalguy
03-18-2015, 09:30 PM #46
I got the line pressure jacked on my car, it's a little jerky, but not too bad
atypicalguy
06-15-2015, 03:01 PM #47
(03-03-2015, 05:47 PM)led-panzer I believe it was real. But the idea that he had 300hp with 5.5 elements is laughable
I better call this guy up. When I run calculations I need like 4atm absolute to burn 120cc of fuel and I am still not at 300hp.
atypicalguy
atypicalguy
06-16-2015, 03:47 PM #48
Can anybody figure out what two turbos he ended up using? Is the .63 a/r housing on the primary turbo?
atypicalguy
Theturbodave
09-27-2015, 01:11 AM #49
Sorry it's been awhile. I had sold my wagon awhile bk. I have missed the wagon ever since.
Well I just picked up a new one a 1985 300td wagon that has a spare motor and I had already picked up a motor to start building a new compound turbo setup on and I'm using a R154 transmission with an adapter I'm building.
I want to see how much you can make without it coming apart and still be usable on street/track.
On this one I will do a cleaner setup (old one was just kinda thrown together)
I will also keep you updated on were / what I'm doing to make it all work.
Theturbodave
Bigpanda16
02-20-2016, 10:28 PM #50
Dave, you should do an om603 or 606 and forget about the old 617. That would be more your style with better volumetric efficiency and power potential
78 300D, 87 190D, 94 E320, 95 E300D
Bigpanda16
 15 Guest(s)
 15 Guest(s)
