what parts will i need for front suspension?
Hey guys
I want to redo the front suspension and im not sure exactly what ill need.
I know ill need the control arms and ball joints (how many btw?)
steering dampeners
what else am i missing?
i plan to order everything from parts geek.
Upper control arms (left & right), 2 lower ball joints, bushings for the sway bar( 2pairs iirc, you need 4pieces total) , strut rod bushings (2 kits) , strut rod mounts (2) , 1 steering dampener. For the lower control arms get the bushings for a w126. You will need two if these.
Then if your tie rods are ok you can re-use them. Also the center link if it is ok you can re-use. If the boots are ripped you should just replace the ends or the whole tie rod/center link.
I think that is everything... On my phone so typing is kinda weird. Autohausaz will tell you how many of each item you need so you can always go there and put in your make/model and it will tell you how many to buy.
(04-04-2012, 10:45 AM)capflya Upper control arms (left & right), 2 lower ball joints, bushings for the sway bar( 2pairs iirc, you need 4pieces total) , strut rod bushings (2 kits) , strut rod mounts (2) , 1 steering dampener. For the lower control arms get the bushings for a w126. You will need two if these.
It ain't cheap! Haha... If you need somebody to press in the ball joints let me know. I got the tool to press them in when I did mine and I've done a few pairs for some buddies of mine here in town. All the shops wanted to charge about $120 to press them in so I just bought the tool instead.
Pm me if you don't have a local shop to press them in for a "reasonable" rate. It only takes about 15 to remove the old ball joints and press the new ones in, and that is for both sides. Shops charging an hour labor for 15min of work isn't right IMO.
(04-01-2012, 06:19 PM)Purplecomputer Hey guys
steering dampeners
steering dampeners
If you're going to do all that, replace the front shocks too. Bilstein HD's FTW
I bought everything from fastlane, see my car thread for a total list if you like
Might be a dumb question but I am just getting into these car, why do you need to replace the whole upper A-arm?
They don't sell UCA bushings or upper ball joints, it comes as one whole upper control arm. And they're only 45 a piece or so so its not outrageous
(04-04-2012, 04:23 PM)dropnosky(04-01-2012, 06:19 PM)Purplecomputer Hey guys
steering dampeners
Just an FYI, be aware of these guys return policy. If you get the wrong part, you will have to ship it back your cost, and buy another one, and god forbid you want to talk to someone, it aint gonna happen. They have a lot of stuff, but id go in eyes wide open, there are plenty of other companies out there that have the same stuff and ten times better service.
I almost always order stuff from buymbparts.biz, or autohausaz, or fastlane over on peachparts.
these three companies have excellent customer service
(04-04-2012, 09:02 PM)led-panzer If you're going to do all that, replace the front shocks too. Bilstein HD's FTW
steering dampeners
Are the sway bar bushings different? From what I can tell there's an inner and outer? My dad just went to get his car aligned and they said they couldn't do it because the driver's side ball joints were shot, so I'm guessing we need an inner/outer sway bar bushing/s, upper control arm, and a lower ball joint? They said the passenger side looked really good, which means the PO was probably feeling cheap and only got one side worked on, which would explain why the car is pulling way to the left
Is all of this correct? I drive about 200 miles a day doing service calls for my job (diesel is paid for by the boss )
So the front suspension is all weak, wobbly, every time I go over bumps The car jolts either to the left or right, not to mention It sounds like the whole car is going to fall apart
