STD Other Open electronic boost gauge vs altitude
05-21-2012, 07:46 PM #1
I bought a depo digital boost gauge
http://www.ebay.com/itm/60mm-Depo-Racing...7e&vxp=mtr
I got it but because I live at 5000ft altitude and it was calibrated at sea level it reads -6inHG not zero and reads low boost
the signal from the sensor should be 0-3.5v but its lower because it's set to absolute pressure and at 5k we are about 5-6 less than that
0v= -14.9psi
1v= 0
2v= 14.9 psi
3v= 29psi
Is there a good way to intercept the low signal and boost it by .3 of a volt all the way up the spectrum? in a linear way?
This post was last modified: 05-21-2012, 08:09 PM by willbhere4u.
0v= -14.9psi
1v= 0
2v= 14.9 psi
3v= 29psi
05-21-2012, 10:48 PM #2
I would throw some resistors at it!
This post was last modified: 05-21-2012, 10:48 PM by Captain America.
05-22-2012, 04:53 AM #3
What it should be doing is have it's own ambient pressure sensor to automatically calibrate itself. Would be annoying to have to recalibrate it all the time.
You can build that with a second sensor and some kind of circuit connecting it to the first to automatically take care of the offset.
05-22-2012, 10:42 AM #4
I was thinking Arduino board??? and just let it take the input value and add a set amount to it and send it as an output to the gauge! But I haven't messed around with this stuff yet
I like your Idea more it would calibrate for altitudes changes witch I encounter a lot when driving in the Rocky's
I live at 5k and drive up to 8k pretty often and the occasional 14k trips
This post was last modified: 05-22-2012, 11:24 AM by willbhere4u.
05-22-2012, 02:57 PM #5
It would be simpler than an arduino. Probably just a few zeners and resistors, that's all it'd take to combine two voltages together.
05-22-2012, 08:47 PM #6
My boost gauge is mechanical, but I have the same problem. It reads -1inHG when the car isn't running, so I guess that means it is reading about 1psi lower than it actually is once boost builds up
05-22-2012, 08:48 PM #7
(05-22-2012, 08:47 PM)sassparilla_kid My boost gauge is mechanical, but I have the same problem. It reads -1inHG when the car isn't running, so I guess that means it is reading about 1psi lower than it actually is once boost builds up
-6inhg is = 2.9 psi so probably only about 1/2 psi off that's not to bad
05-22-2012, 08:56 PM #8
Oh well then, I guess its not that bad at all lol
05-23-2012, 09:44 AM #9
I read somewhere that there might be an adjustment on the back of the gauge under a sticker so I'll check that out this weekend before I get carried away
05-30-2012, 12:12 PM #10
I found a tiny Allen screw pot on the back of the boost gauge and turned it all the way over and now it at -2 not -6 so that's close enough for meBig Grin
