Diff. Ring gear sizes?
hello all,
does anyone know the ring gear size in a 240D diff.? 115 or 123, should be the same I'd think.
or a late model 560 SEL?
I'm trying to figure out if my 240D has a big enough gearset to take the torque from the 560's motor
Thanks much.
-Erik
(06-24-2009, 06:10 PM)2.5-10 I'm trying to figure out if my 240D has a big enough gearset to take the torque from the 560's motor
The V8s use bigger flanges and flex discs. That V8 would be screaming down the highway with a 3.69! It would get to 120 real quick though.
(06-24-2009, 07:30 PM)winmutt(06-24-2009, 06:10 PM)2.5-10 I'm trying to figure out if my 240D has a big enough gearset to take the torque from the 560's motor
No, you will need the bigger drivetrain. The most immediate failure with the 240 setup would be the flex disks.
(06-24-2009, 08:09 PM)ForcedInduction The V8s use bigger flanges and flex discs. That V8 would be screaming down the highway with a 3.69! It would get to 120 real quick though.
anyone know the ring gear size? is the 300D diff stronger? will a W201 diff bolt up, will my late model W126 diff bolt up?
I need it to take about 350LB/FT torque
the ring gear size is 185mm... the one in your 560 is 210mm... if you want to swap to the larger one, I know that an early(pre-1985) w126 diff will bolt up to the ass-end of the w123... and by leaving it with the 3.69, it will have better off the line performance, but not have as much top end potential, which also means not as good mileage potential... the good news is that the gear ratio in the 560 is 'used to' is probably the same one the early w126 v8s used, 2.47...
all that said, I doubt that you'd bust that 185mm diff unless you were doing power launches all the time, i.e. drag racing, but I do understand the urge to make sure it'll hold up...350lbf is a bit, but probably well within the capacity of the 185mm(~7.3") diff, now if you were looking to modify that engine for more power, def. go with the larger one.
anyway, if you want to hit up the yards, look for 1985 and older w126s with a v8 and crawl underneath and check the ratio that is stamped on the housing(flat spot on the bottom left edge of the face where the diff cover bolts on) it should be 2.47:1 which I think is still what they were running in the later models, either way, the v8 will have more than adequate power to push it...and if you have looked at enough diffs, youll notice right away that it is a bit larger than the w123...
the 300D will have the same diff, just numerically lower (taller) gears...201 and late model diffs wont bolt up, it may be possible to modify a later 126 rear subframe to fit the 123, and then the later 126 diff will work(let me know if you do that!) you can also swap the guts of the same size diffs around, but youll likely need a shop to set it up for you (apparently MB diffs are really difficult to set up properly w/o the right tools... im still gonna try it anyway)
I knew the W126 gasser diffs were 210mm sets, I was just unclear if the 85 and earlier were actually different mounting. good to know if and when I blow up the diff.
do I stll use the W115 axles with the 201mm diff?
Yes use the w115 axles. Just make sure you have the correct spacer in the diff.
You have many other options besides the 123 or 126 if you can find one that suites your needs. Any differential from a 107, 114, 115, 116, 123 and 126 would swap, up to 9/85.
(06-26-2009, 02:56 PM)DeliveryValve Any differential from a 107, 114, 115, 116, 123 and 126 would swap, up to 9/85.
(06-26-2009, 02:56 PM)2.5-10 also, does anyone know if the motor mount spacing in the W114/W115 is the same as the W123?
(06-26-2009, 02:56 PM)DeliveryValve Yes use the w115 axles. Just make sure you have the correct spacer in the diff.
(06-27-2009, 01:49 PM)SurfRodder(06-26-2009, 02:56 PM)DeliveryValve Any differential from a 107, 114, 115, 116, 123 and 126 would swap, up to 9/85.
thats really good to know... which ones of those had the 210mm gear? i wanna keep an eye out for certain ratios...
im not sure... someone else prolly does.
(06-26-2009, 09:48 AM)SurfRodder the 300D will have the same diff, just numerically lower (taller) gears...201 and late model diffs wont bolt up, it may be possible to modify a later 126 rear subframe to fit the 123, and then the later 126 diff will work(let me know if you do that!) you can also swap the guts of the same size diffs around, but youll likely need a shop to set it up for you (apparently MB diffs are really difficult to set up properly w/o the right tools... im still gonna try it anyway)
if I start with the 115 (123) diff, will I need to get a new custom drive shaft to mate up with the 85 or before V8 126 diff?
(06-28-2009, 01:52 PM)2.5-10(06-27-2009, 01:49 PM)SurfRodder(06-26-2009, 02:56 PM)DeliveryValve Any differential from a 107, 114, 115, 116, 123 and 126 would swap, up to 9/85.
I would think only the V8 versions of those chassis would have the 210mm gears.
(06-28-2009, 05:17 PM)2.5-10 if I start with the 115 (123) diff, will I need to get a new custom drive shaft to mate up with the 85 or before V8 126 diff?
I just popped under the car, and I must say I am confused looking at the axles, the CV boots and mounts look very strange, hex bolts?
do they still pull straight out like they do on my toyota?
are you referring to how to disconnect the axles? If so, you need to drain the diff and pop the back cover off. then you rotate the axles until you can see a C-clip, which will have a little ear that you can grab with some pliers and pull out. As for the outboard end, theres a standard hex bolt (10mm head, me thinks) that you need to take out.. then you should have enough wiggle room to get 'em out...
also note: before you remove the drain plug on the diff, ensure that you can fill it (remove the fill plug on top first)
(07-15-2009, 05:27 PM)SurfRodder are you referring to how to disconnect the axles? If so, you need to drain the diff and pop the back cover off. then you rotate the axles until you can see a C-clip, which will have a little ear that you can grab with some pliers and pull out. As for the outboard end, theres a standard hex bolt (10mm head, me thinks) that you need to take out.. then you should have enough wiggle room to get 'em out...
(07-15-2009, 06:02 PM)winmutt 13mm on the outside.
(07-15-2009, 09:56 AM)2.5-10 I just popped under the car, and I must say I am confused looking at the axles, the CV boots and mounts look very strange, hex bolts?
my 560 has annular for sure which is no surprise as its post 86, I havent looked at my /8 but I would guess it has the other type.
if I were to ever need to upgrade to a 85 gasser diff from a 126, would I need to get a new drive shaft? is the diff. casing the same width on the 183, and the 210 gearsets?
could I use the /8 183mm axles with a 85 126 gasser diff? what about my custom driveshaft?
(07-16-2009, 12:07 AM)2.5-10 if I were to ever need to upgrade to a 85 gasser diff from a 126, would I need to get a new drive shaft? is the diff. casing the same width on the 183, and the 210 gearsets?no, but you would need to swap input flanges on the diff in that case
(07-16-2009, 12:07 AM)2.5-10 could I use the /8 183mm axles with a 85 126 gasser diff? what about my custom driveshaft?the axles that came with the car you are putting the diff into should be what you need...
(07-16-2009, 01:15 AM)SurfRodder(07-16-2009, 12:07 AM)2.5-10 if I were to ever need to upgrade to a 85 gasser diff from a 126, would I need to get a new drive shaft? is the diff. casing the same width on the 183, and the 210 gearsets?no, but you would need to swap input flanges on the diff in that case
yes, the 185 and 210mm diff casings are same width
input flange is different on the 183mm diff than it is in the 85 gasser diff? do swap that, I would assume I would have to partiall disassemble both differentials correct?
what custom driveshaft? /specs?
(07-16-2009, 12:07 AM)2.5-10 ....
if I were to ever need to upgrade to a 85 gasser diff from a 126, would I need to get a new drive shaft? .... what about my custom driveshaft?
I'll be getting one made if I cant find a MB one that fits properly, the flex discs are hardly any bigger on the 560, very weird
(07-16-2009, 05:14 PM)2.5-10 I'll be getting one made if I cant find a MB one that fits properly, the flex discs are hardly any bigger on the 560, very weird
