STD Tuning Engine 200 hp out of om603.971
ontum
05-26-2012, 01:10 AM #1
Hello all,
I have an om 603.971 that is in need of a new turbo. So I thought this would the appropriate time to do what ever modifications I need to get more low end power.
I will be putting this engine in my G wagen and will be using this off road a bit.
What do I need to do to achieve 200 horsepower without going to expensive?
Thanks,
Craig
ontum
Hello all,
Thanks,
Craig
EDH_Performance
05-26-2012, 05:12 AM #2
(05-26-2012, 01:10 AM)ontum Hello all,
Thanks,
Craig
A pump with 6mm elements would do the trick, and a more effective turbo on standard turbomanifold...Then you would easy get 200hp+
EDH_Performance
Thanks,
Craig
kova
05-26-2012, 06:53 AM #3
What size turbo would do the trick? holset hx35w is way too big for that power or?
kova
EDH_Performance
05-26-2012, 07:18 AM #4
(05-26-2012, 06:53 AM)kova What size turbo would do the trick? holset hx35w is way too big for that power or?
If i had some money to spend, I would buy an presicion turbo or a Mastepower.. I have no experience with the holset turbos, but isn`t the hx35 quit small? I think it would do the trick!
Here are some candy for youSmile
http://www.superturbodiesel.com/std/thread-1603.html
This post was last modified: 05-26-2012, 07:23 AM by EDH_Performance.
EDH_Performance
Hotrodbenz
Boost and roost baby let's do some coke
46
05-26-2012, 11:26 AM #5
Says the fool with a twin charged 600hp 603 haha Ive herd the stock pump and a 60 trim will do 200
Hotrodbenz
ontum
05-28-2012, 12:16 AM #6
Does anyone know what the part number is for the 6mm elements, the part number, or where to get them?
Who can install them? I reside in Oregon and I think there may be some places in California that rebuild mercedes injection pumps.
The precision and masterpower turbos seem to run between 700-800$, which is a bit out of my price range. Is there an available turbo I could find used for cheaper? Or can I get a new cartridge for the turbo housing I have now?
Here is the condition of my current turbo.
[Image: 7218458978_f071d3dc8a_z.jpg]
ontum
05-28-2012, 08:02 PM #7
You get 6mm elements off a 98-99 electronic E300d pump. You go find a used one. Easier than figuring out Bosch part numbers and then wondering where to get them.
Unless you find a pump at a pick and pull for cheap, I'd prefer new 7.5mm elements or something, since new elements themselves are about the price of used 98 pump.
