STD Other FS / WTB / Buying guides OM617 to AX-15 Adapter
06-12-2012, 08:34 AM #1
I bought this adapter from a guy on CL down here, and I wound up driving 6 hours total to pick the PITA up.
My plans have changed, I'm not using an AX-15 anymore.
Looking for $150 shipped, gets you a homemade plate and a drilled/pinned flywheel.
I'll toss up some photos tonight.
NO_SPRK
06-12-2012, 12:55 PM #2
im interested but cash is low so dont get excited. have had a om617a sitting for my 72 jeep commando but ive between running a 4spd with a samurai T-case or a adapter
66 MBZ 200D 4spd floor-shift 170k
83 MBZ 300D 4spd EURO N/A 190k
84 MBZ 300D 4spd EURO *FOR SALE*
91 Dodge W350 SRW 6BT 4x4 5spd 340k
82 Chevy C30 CC LB DRW Banks 6.2L 4spd 270k
86 Ford F350 ATS 6.9L 5spd 17' Jerr-dan rollback 360k
NO_SPRK
NO_SPRK
06-14-2012, 06:06 PM #3
(06-12-2012, 08:34 AM)Simpler=Better I bought this adapter from a guy on CL down here, and I wound up driving 6 hours total to pick the PITA up.
what flywheel comes with it?
NO_SPRK
06-14-2012, 09:55 PM #4
The guy I bought it from said it was the stock AX-15. The stock holes have been pinned and 6 holes have been drilled to fit the Merc crank.
NO_SPRK
06-16-2012, 07:59 PM #5
(06-14-2012, 09:55 PM)Simpler=Better The guy I bought it from said it was the stock AX-15. The stock holes have been pinned and 6 holes have been drilled to fit the Merc crank.
uhh i just noticed "home made".. ill think about it but i may pass on it
NO_SPRK
06-16-2012, 08:48 PM #6
Yeah I was going to make my own and this one popped up, so I nabbed it. Then a different vintage jeep came along for almost no money, and I jumped on it. It's all homemade work...and I never had an AX-15 to bolt it up to. Just going on faith that it will work.
Secondaries
06-18-2012, 12:56 PM #7
Just a heads up to anyone who may be interested.
This adapter can be used to run a R154 gearbox by removing the stock bell housing and using the AX15 front section/input shaft. This is the gearbox in the 86-92 Supra Turbo 5-speed, and is much stronger than the AX15. Similar transmissions can be found in 4WD Toyotas from the mid 80's to late 90's.
Secondaries
MTUPower
288
06-18-2012, 06:53 PM #8
So what is this good for? Pics?
MTUPower
Secondaries
06-18-2012, 07:47 PM #9
(06-18-2012, 06:53 PM)MTUPower
This will allow an OM engine to be mated to an AX15 transmission. These came in Jeep and Dodge trucks in the 80s to 90s in 2wd and 4wd models. It is a 5sp manual and this adapter is presumably for swapping an OM engine into another 4wd vehicle.
Secondaries
06-19-2012, 10:02 AM #10
(06-18-2012, 07:47 PM)Secondaries
Bingo! I've been crazy busy, I haven't had time to take photos. It's literally a 1/4" aluminum plate with a bunch of holes drilled in it and a Jeep Flywheel with 6 holes to match the merc pattern.
MTUPower
288
06-19-2012, 04:06 PM #11
(06-19-2012, 10:02 AM)Simpler=Better Bingo! I've been crazy busy, I haven't had time to take photos. It's literally a 1/4" aluminum plate with a bunch of holes drilled in it and a Jeep Flywheel with 6 holes to match the merc pattern.
Could you then put that tranny into a w123?
MTUPower
Secondaries
06-19-2012, 04:43 PM #12
(06-19-2012, 04:06 PM)MTUPower
You'd need to make sure of a few things, such as that there's physically room to fit the transmission in the tunnel, and that the shift lever locates through the stock floorpan hole. That is, unless you plan on doing any cutting/hammering. After that, it's as simple as modifying the stock crossmember to fit or fabbing a new one, and making a driveshaft that will work (u-joint in front, guibo in rear).
Secondaries
06-20-2012, 11:42 AM #13
Probably not without major modifications. The AX-15 has a top-mounted shifter and is prettty long (the shiny one):
[Image: oldnewunits9.jpg]
 8 Guest(s)
 8 Guest(s)
