Oil cooler hose issues
Changing the injection pump sucks, there is no nice way about it. Fuel and oil go everywhere, the oil filter housing has to come off to remove the MW-pump, etc etc
I embarked on this task today, but I had the unfortunate luck of the lower oil cooler fitting stripping as it came off.
Compare to the normal fitting.
This is the fate all faulty parts deserve.
Anyways.
The MW has an oil supply line that must be blocked. I made my own as I couldn't find any metric threaded plugs.
If it weren't for the cooler fitting I would have finished. So, this is how it sits right now until new hoses get here. There is a 300SD in the yards I'll grab the fittings from.
(06-22-2009, 04:38 AM)ForcedInduction I embarked on this task today, but I had the unfortunate luck of the lower oil cooler fitting stripping as it came off.
Humm, good hydraulic hose would be even easier. Its nearly a straight shot from the filter to the cooler bends and there is a Parker store near by. I need to go there for the steering return hose anyways. I have been using their blue high temperature hydraulic hose for my turbo's oil feed line without any issues for 3 years. Even sitting near the exhaust manifold has caused no problems. I'd bet 8' of their 1/2" hose and 4 or 8 fittings would come in under the $120 two new cooler hoses would cost. Thanks for the idea SurfRodder!
de nada... if i ever get off my ass Ill post some pics of my earls lines!
did the exact same thing for the 617's in my boat..
except mine are metric on one end and SAE on the other
( to attach to the marine oil cooler )
What a coincidence, there was a 76 300D in the junkyard today and I noticed its oil cooler hoses happened to be a straight shot to the cooler. None of that under the engine mount nonsense.
oel_brenner, did your fittings go directly into the filter housing or use the stock flare fittings?
I got this picture from one of your videos, do you have a better shot? I'm not sure if I can do straight fittings or if I'll need them to have a 45* at the filter housing.
(06-23-2009, 08:42 PM)ForcedInduction What a coincidence, there was a 76 300D in the junkyard today and I noticed its oil cooler hoses happened to be a straight shot to the cooler. None of that under the engine mount nonsense.Wondered when I first saw the setup & what was involved in replacing the hoses/lines, why they went that route, but figured there musta been some or a good reason...
(06-23-2009, 01:05 AM)SurfRodder de nada... if i ever get off my ass Ill post some pics of my earls lines!
Never mind. I talked with Tom Judd and he has convinced me that installing new OEM hoses, that are proven to last 20y/200k+, is the better option. It will give me a reason to replace my soft engine mounts, remove the last bits of A/C and I will have 2 less hoses in my way around the injection pump. Besides, these fabrication/custom jobs rarely work out as nicely as they do in my head.
(06-25-2009, 11:20 AM)ForcedInduction Never mind. I talked with Tom Judd and he has convinced me that installing new OEM hoses, that are proven to last 20y/200k+, is the better option.
Well, schisse. According to both the local dealers the oil cooler hoses are discontinued.
Looks like I'm going to the Parker Store after all.
(06-27-2009, 11:47 AM)85-300Dt What size are the fittings?
Quote:your best bet is to pull the fittings from the oil cooler and from the filter housing of a junkerThe fitting size/type on the oil cooler and filter housing are the same. The housing fittings take a thin 24mm wrench and cooler hose takes 27mm. (15/16" and 1-1/16"). I don't doubt they will have something to fit the filter's fitting hole but we'll see if they can match the outer end. I may end up having to resuse the cooler hose ends with the new hose.
I'll find out monday.
Thats all over with.
New problem: When cold it will only idle at 1/2 throttle, after a minute it will idle about 600rpm and tops out at a very low power 4000rpm. Fresh oil, prefilled the IP with oil to the spill port level, timing 26*BTDC verified with drip tube and no unusual combustion sounds.
One odd thing though; when in P/N, revving the engine will try to slightly roll the car forward but not enough to actually move it. R/D/S/L work normal (just lacking any power).
Any ideas? I'm going to try adjusting the idle screw first.
Well 3/4CCW on the screw seems to have taken care of the idle RPM, though the engine is fully warm now. We'll see if it sticks after it sits overnight.
Power was the linkage adjustment, I had to change the alignment of the main thorttle shaft. It scoots pretty well now.
The real pisser? #5 STILL nails. It is a combustion issue, cracking the injector line causes misfire and no more sound.
(07-01-2009, 12:30 AM)Motorhead What do you think is wrong with #5, injector?
I dared fate and took my camera into the junkyard for some pictures before I removed the hoses.
It took an extra trip to the Parker Store once I discovered the lower hose uses a smaller diameter (1/2") than the upper (5/8"). Subtract the A/C compressor, add the new metal lines, add some double clamping and the results are quite satisfying.
The bottom radiator fitting is a short straight piece instead of the neck like on the upper. No reason you couldn't use the angled fitting and keep the A/C though. In my case it was motivation to remove that 20lbs of useless metal for good.
I also got some replacement hose for that leaky old steering return.
There's something creepy about trusting the life of the engine to worm clamps... If an oil cooler hose goes, you have what.. 15-20 seconds to get it shut down before the oil is gone? I'd try to get some beefy T-Bolt clamps or something like that. I'm sure double clamping with worm clamps is okay, but it's just such a critical part, you know?
(07-01-2009, 07:41 AM)GREASY_BEAST There's something creepy about trusting the life of the engine to worm clamps.
(07-01-2009, 03:33 PM)ForcedInduction(07-01-2009, 07:41 AM)GREASY_BEAST There's something creepy about trusting the life of the engine to worm clamps.
No more risky than trusting the compression of a metal crimp fitting except that a worm clam can be replaced or retightened.
Quote:the problem with the worm gear clamps is that they strip after a certain point. I could never get them tight enough on any kind of lines that have high pressure.as well as there being discussion of other clamping options.
Quote:If you are going to replace any of these hoses with brand new ones, then to remove the old hoses without ruining the threads on the male part, use a dremel with a little mini metal cut-off wheel to cut into the outer female fitting (screw collar?), perpendicular to the threads. You can cut right down into the threads on the male barb, but be careful to go no deeper than the threads. Then just take a flat screw driver and pry open the screw collar....even if you dont cut too deep and the threads on the screw collar are still connected, these will snap when you pry open, and the collar will easily unscrew with no further damage to male threads.
Two things to be careful about:
1. Dont cut any deeper than the threads on the male threaded barb, or you will cause structural weakening of the barb, and
2. Especially be careful not to cut into the sealing surface of the male threaded barb, or else it is toast.
Quote:the inside of the oil cooler, i think it comes soldered from the factory? so i did a inside chase you could call it, then turned a brass elbow into it
very very very risky cos if the end\opening of the cooler would crack i would be crying cos that will cost money to fix
when my IC and all is done im gona post a bunch of pics
