STD Tuning Body Mods Will they fit?
Will they fit?
Will they fit?
83300d
05-22-2012, 09:53 PM #1
Found a set of what I believe are 8 hole rims and winter tires off a 2000 C230 for a couple hundred dollars, I have seen similar rims put on members W123s so before they come home with me I wonder what it takes to make them fit.
Thanks for reading this, and I hope someone has some input on the subject.
This post was last modified: 05-22-2012, 09:53 PM by 83300d.
83300d
05-23-2012, 04:52 AM #2
Probably would need spacers. Check what the offsets are.
05-23-2012, 11:15 AM #3
I think the offset on those 8 hole wheels is ET37.
You will need a least a 10mm spacer and longer lug bolts to make it work.
10mm is pretty thick, so I suggest using a hubcentric type of spacer to minimize vibrations.
83300d
05-29-2012, 03:46 AM #4
Ok next rim question - looking on kijiji and found these
http://lethbridge.kijiji.ca/c-cars-vehic...Z378575682
http://lethbridge.kijiji.ca/c-cars-vehic...Z376824001
not crazy about the blue but could always paint em
This post was last modified: 05-29-2012, 03:48 AM by 83300d.
83300d
05-29-2012, 11:02 PM #5
(05-29-2012, 03:46 AM)83300d Ok next rim question - looking on kijiji and found these
Yuck
Yuck
05-29-2012, 11:38 PM #6
The latter set is definitely better
83300d
05-30-2012, 12:04 AM #7
Seems like the rims I really want keep slipping between my fingers - both sets were removed from ebay before the bidding ended. Not sure how I feel about them so will mull it over while away from home working.
Just not a big fan of the 14" stockers and maybe too anxious to be done with them! Will 17" fit even?
This post was last modified: 05-30-2012, 12:05 AM by 83300d.
83300d
05-30-2012, 12:13 AM #8
I'm gonna put some 16X6.5" (not sure of the offset) wheels on my car, as soon as I get enough money to get them sandblasted and powder coated, and buy new tires haha.
83300d
06-20-2012, 11:21 PM #9
So still looking for a set of rims and tires to replace my Bundts, and came across a guy selling these Mandrus 17" off a 1999 CLK 320.
http://i914.photobucket.com/albums/ac347...rus172.jpg
Now from what I could see off the Mandrus website these are the Millenium rims with a 32mm offset, but the owner isnt 100% sure. I have asked him to take some pictures of the back of the rims in the hope that they will have some offset info stamped on them.
Heading up to take a look at them next week so any input on the company and or fitment is appreciated THANKS
ALSO why cant I get the HTML link from my Photobucket account to work?????Huh
This post was last modified: 06-20-2012, 11:24 PM by 83300d.
83300d
83300d
06-21-2012, 10:29 PM #10
From what I can see they are ET32 - so 17X8J ET 32 will fit on my 83 300d? Probably need spacers from what info I can find
83300d
led-panzer
06-22-2012, 12:15 PM #11
My 17's are ET 37 and fit without spacers, just needed longer lug bolts. It's a rim by rim type thing, they all fit different
1985 300D 280,000 miles RIP
led-panzer
83300d
06-22-2012, 07:31 PM #12
Thanks Led. Guess I will buy them and give them a try.
83300d
06-27-2012, 09:53 AM #13
you could buy my bastardized VW ATF rims that look like ronals, and spend money making an adapter.......Big Grin
pics located here with adapter info I found.
http://www.superturbodiesel.com/std/thread-3700.html
They are currently on Ebay for cheap. rims, mounted good tires, balanced....
and no one wants them.
http://www.ebay.com/itm/221057530875?ssP...1555.l2649
83300d
06-27-2012, 05:55 PM #14
Already bought the Mandrus set sorry.
83300d
83300d
09-23-2012, 11:09 AM #15
Found another set of rims that tweaked my interest.
Carlsson 19inch with a 40 offset so I assume they will DEFINATELY need spacers?
[Image: carlsson_zps7c4419fc.jpg]
Its still for a 1983 300d
WOW must yet another set found on the same day. Think these would fit alot easier.
[Image: borbet_zps518c1a54.jpg]
Getting these painted flat black might be the way to go. Big Grin
This post was last modified: 09-23-2012, 11:14 AM by 83300d.
83300d
09-25-2012, 01:04 PM #16
(09-23-2012, 11:09 AM)83300d Found another set of rims that tweaked my interest.
personally, I like the carlsson ones better. they second set just remind me of rims you find on new toyotas.
83300d
09-25-2012, 01:29 PM #17
the 19s will fit on there without too much hassle?
83300d
 15 Guest(s)
 15 Guest(s)
