89 XJ Cherokee Jeep with 99 606 engine
Nice. What are the plans with the jeep?
(01-29-2012, 01:56 PM)dieselboy Nice. What are the plans with the jeep?
(01-29-2012, 08:01 PM)dust What exactly is the reason for the extension? I know that it is for the sump, but what about the sump is the problem?
(01-29-2012, 04:48 PM)zeeman I myself live off the grid in the Northwest, shop runs on a multifuel military generator. Shop is heated with a heater that runs Biodiesel and the air compressor is diesel powered and runs on Biodiesel.
(01-30-2012, 03:28 AM)sassparilla_kid(01-29-2012, 04:48 PM)zeeman I myself live off the grid in the Northwest, shop runs on a multifuel military generator. Shop is heated with a heater that runs Biodiesel and the air compressor is diesel powered and runs on Biodiesel.
That's pretty awesome, my friend and I are currently working on a concentrated solar project to make steam to power generators so we can try to get off the grid
(01-30-2012, 12:28 PM)erling66 Why don't you move the sump to the back of the pan? It is not that difficult, just a little welding
You have mounted the engine in a backward angle so the oil will collect there too.
That looks pretty cool. I notice the airflow meter installed. Are you running on the original management system? If so any tips around using the electronic control - I'm trying to do the same thing but just starting to trawl through wiring diagrams. I want to get rid of the security stuff and that horrible electronic Mercedes key.
(01-30-2012, 06:21 PM)gn3dr That looks pretty cool. I notice the airflow meter installed. Are you running on the original management system? If so any tips around using the electronic control - I'm trying to do the same thing but just starting to trawl through wiring diagrams. I want to get rid of the security stuff and that horrible electronic Mercedes key.
(01-30-2012, 08:55 PM)zeeman(01-30-2012, 06:21 PM)gn3dr That looks pretty cool. I notice the airflow meter installed. Are you running on the original management system? If so any tips around using the electronic control - I'm trying to do the same thing but just starting to trawl through wiring diagrams. I want to get rid of the security stuff and that horrible electronic Mercedes key.
Funny you should ask that, I have had this engine for 8 years and was going to use it in a street rod but ended up selling the car recently. So now it is going in a jeep Cherokee project. I never got into the electonics until now after buying a new computer harness and the electronic throttle and everything to make it work new from Mercedes for lots of dollars. I never thought the computer was going to be a problem until I talked to Oliver from Speedtuning USA the other day. He says that computer is impossible to get into to delete things to install it in a non Mercedes car. I have seen some people on this forum install them in earlier Mercedes with some success being they had the componets already on the car to make it work. But it seems the cure in other installations is to use a 603 mechanical IP pump to get away from the electronics. The only problem is the plunger size in the 603 IP is 5.5mm compaired to 6.0mm in the 606 pump these can be swapped to keep the original H.P. I hope this helps.
hell yea!!! captain needs to get on this!
Cool project but I'm not a fan of the engine being so far forward. You want as much weight behind the front axle as possible... I would have extended the wheelbase, which is needed when going with any tire over a 33" anyway. I dunno if an inch or 2 would have solved the pan issue or not but that's the way I would try to do it.
There better be some videos of this thing, and I hope that the Dana 35 isn't still in the rear because you can kiss that thing goodbye. Better go with a Chrysler 8.25 or a Dana 44 at least!
Goodluck with this!!
(01-31-2012, 03:17 AM)gn3dr(01-30-2012, 08:55 PM)zeeman(01-30-2012, 06:21 PM)gn3dr That looks pretty cool. I notice the airflow meter installed. Are you running on the original management system? If so any tips around using the electronic control - I'm trying to do the same thing but just starting to trawl through wiring diagrams. I want to get rid of the security stuff and that horrible electronic Mercedes key.
OK Thanks
I have the complete donor car so I can get it running but it just means transplanting everything (well a lot of stuff like ABS controllers etc.) over and I'd like to engineer out as much unreliability as I can. If I was just able to get rid of the steering lock / electronic key part that would help. There's probably no easy way to get rid of the ABS controller as I want to use the 722.6 gearbox and that will need speed signals as well as needing to talk to the engine ECU over the CAN BUS.
It's apity ther seems to be so little info out there (on the web anyway) about reprogramming the ECU. It has to be possible.
(01-31-2012, 12:05 PM)Captain America Cool project but I'm not a fan of the engine being so far forward. You want as much weight behind the front axle as possible... I would have extended the wheelbase, which is needed when going with any tire over a 33" anyway. I dunno if an inch or 2 would have solved the pan issue or not but that's the way I would try to do it.
OK Thanks
(01-31-2012, 04:01 PM)zeeman Thanks for the comments, after a lot of research moving the engine a little forward seemed to be the best solution. The frame is a unibody and I didn't want to change the wheel base or fender opening. The engine is really not that far from were the stock engine was, most of the fender extension is to clear the Mec engine fan and radiator an inner cooler. The stock engine had a offset idler fan for clearence. This is going to be more of a all terrain survival rig then an all out offroad 4x4. Will get a video up when futher along. Thanks
OK Thanks
OK Thanks
Nice Handy work there, I like it. Once its painted it will look factory!
(07-01-2012, 11:47 AM)Freefuel For Computer programing to remove the imobilizer key feature, you might want to ask Jeff over at Rocketchip.com, I remember him mentioning doing a tune on a MB in passing. When I whas having an update done to my VW TDI.
Hell yeah! Spintech Sportsman 3000! or at least thats whats on mine. I dunno about back pressure behind the turbo though....
Spintech is about 15 miles from my house
