STD Other Projects super 'g' extra lwb g wagen pickup
  • 2 Vote(s) - 3.5 Average
axel606
08-12-2012, 04:19 PM #1
new project ,just started building a super 'g' 3428mm wheelbase pickup g wagen.
i have taken a sound 280 swb petrol g wagen with no motor and trans i have taken the body off and cut the chassis in half and added a section to make it 3428mm wheelbase (super g ) i then cut the body in half and shortened it to make a 2+2 cab leaving enough room for an 8 ft flatbed to take a demountable camper giving a multipurpose g pickup with 605a power and a 6 speed manual box same as the one in my lwb g which has a 606a .
the pickup has promise as it seems very light maybe 500kg lighter so the 605 should fly it along .
i have just got a 716.651 manual 6 speeder from clk 220 cdi with flywheel and complete clutch and i already have a musso inj pump that has been maxxed ,i will intercool it with an iveco van unit and a 12psi pressure operated wastegate actuator with egr delete and a degutted inlet plenum,with big bore 61 exhaust pipe with single straight through silencer (same as my 606a g) this g is half its weight so it should fly with 605a power and have the potential to be eco if required.
the cab is a challenge as the plums who had it were gradually cutting it to pieces for body panels for other vehicles so i had to rectify what they had done before i could proceed with my plans ,it is taking along time to do this but it is starting to take shape as a shrunken g wagen .
let the grinding ,welding and metal bashing commence...
axel606
08-12-2012, 11:29 PM #2
That is cool!
That is cool!
08-13-2012, 02:00 PM #3
That looks awesome!
That looks awesome!
08-13-2012, 09:46 PM #4
That is gonna be awesome!!!!!!
huseyin55amg
08-14-2012, 09:54 AM #5
look forward to the end result mike.
but here on STD 300 horses are the minimum !!
rgds hus
huseyin55amg
rgds hus
08-14-2012, 11:56 AM #6
Glad to see you use the same green rollaround that I do Big Grin
axel606
08-14-2012, 04:11 PM #7
(08-14-2012, 11:56 AM)Simpler=Better Glad to see you use the same green rollaround that I do Big Grin
thanks for all your comments! it is very satisfying building this as it will give us alot of pleasure when it has its camper back on and it should be a hoot to drive solo with a feisty 605 a under the hood .
i will put up some pictures of the 6 speed and 605a that i will use.
the welding continues onwards i am waiting for another door to de-skin for the other side ,its making the two sides the same as each other thats going to be the real challenge. i have reused all the good steel from the amputated body to make the repair pieces so its all good for the old recycling! i might get the pump built with 6 mm elements and maxxed to try for 200 with boost etc ,sorry huss but iam not in the 300 club,but i do have an bmw z3m roadster that is and i have done the jump from casino royale in it at millbrook, is that ok?? -mike
axel606
axel606
08-27-2012, 11:28 AM #8
(08-12-2012, 11:29 PM)Captain America That is cool!
a bit of progress made with body and engine drivetrain parts in no particular order: musso turbo pump all maxxed out ready for low mileage 605a,c220 cdi 6 speed box and flywheel clutch (240mm) combo and my white cat mr.foose and various metal bashing pictures.
axel606
08-27-2012, 02:13 PM #9
Great progress, are you having custom glass cut for the rear windows?
axel606
08-27-2012, 02:30 PM #10
(08-27-2012, 02:13 PM)Simpler=Better Great progress, are you having custom glass cut for the rear windows?
yes, the side windows will have mdf templates made and reproduced in a cab glass shop in bristol nearby, they will be installed with the generic cut to length type rubber seal with bead type expander.
the back window is of course half the old factory back door so the glass will go back in giving me rear wash wipe and heated rear screen ,i am just about to fit the rear body mounts into the chassis ,i cannot decide if i should give a minor (15mm) bodylift or not ,my friend tony has done it to his and it just makes brake pipe access and pressure washing lots easier, so might just go 15mm or so, nothing extreme as it is really tall already i know the engine etc has to go in but it will not take it down that much, it towers over my lwb 460 with 606a like a monster truck.
This post was last modified: 08-27-2012, 02:33 PM by axel606.
axel606
08-27-2012, 02:48 PM #11
I'd go for it, 15mm is pretty minor. I don't think you'll be taking this thing on race tracks Smile
axel606
08-27-2012, 02:53 PM #12
(08-27-2012, 02:48 PM)Simpler=Better I'd go for it, 15mm is pretty minor. I don't think you'll be taking this thing on race tracks Smile
no i suppose not! thats what i have these for !
axel606
axel606
10-07-2012, 03:53 PM #13
bit more progress on the super g
in no particular order !
glow plug unit fitted and wired to petrol powered wiring loom /glow light on dash typical merc the holes are already there on a gas powered truck nice!
rear spring/shock mounts cut off and replaced with new (the only bad bit on the whole truck)
flywheel has tabs trimmed to give 3 pulses per rev to trigger the 280 ge tacho.
hall sensor shimmed up by 1 mm to get airgap correct as they can rub or jam on the flywheel tabs when swapping a manual f/w from a flex plate worth checking if you do this swap ,this is the 2nd time i have found this.
low miles 605a fitted with f/w and 6 speeder (716.651) from c220cdi
crankshaft boss ground back a little to allow f/w to sit down flat as they do not pull down on to the crank face ,i have checked with a vernier caliper for depth and it does not meet the face by about 1.5 mm ?? strange ,but true.
axel606
w123star
10-07-2012, 05:25 PM #14
What a great project! Ive got a w461 pick up, and have had many thoughts building a "x-cab" like you did.... I will follow your progress !! :-)
w123star
Ksteen2
11-27-2012, 08:18 AM #15
how is the progress on this prodjekt??
its fun too watch something unusual Wink
Ksteen2
fha772
01-01-2013, 03:14 PM #16
I love this project, I'm just getting started on my dad's abandoned 280GE, M117 5.0 V8 powered, 6x6, pick up conversion, it's been sat for about 10 years in a barn.Confused
I'll be watching this build with great interestWink
fha772
axel606
04-19-2016, 05:10 PM #17
super G is finished !
 605a with dieselmeken tuned 6mm pump @90cc
 standard garrett turbo with 15 psi wg with lots of preload (i get 18psi )
 6 speed manual box with a 7th gear 22% drop with an inline overdrive in the rear propshaft (proxy center-bearing )
  in 7th gear i can cruise at 70 mph @ 2500 rpm (bad photo!)
  sadly i cannot seem to upload any pictures of the truck  -very frustrating ((
axel606
axel606
04-19-2016, 05:13 PM #18
sorry the picture is huge ! i cannot seem to edit it and it refuses to upload any pictures of the truck itself - ((
axel606
Dark Hawk
04-25-2016, 11:25 PM #19
MORE PICTURES!!!!!!!!
1984 300d 132k restormod project in the works
1985 300td 300k $600 off road adventure project
1999 land cruiser  235k, 33" mud tires, off road, towing, hauler
Dark Hawk
axel606
04-27-2016, 04:16 PM #20
I have tried in vain to upload the pictures of my finished super G with 7 speed manual box etc and 605a power .
    Sadly the site will not upload them despite many attempts and re sizing of the files .
   I am really sorry .
  I have a link to our G wagen register forum where e you can see them /it's free to join .
     http://www.gwagenregister.com/phpbb/view...p?f=7&t=82
axel606
   I am really sorry .
MrHope
10-03-2016, 01:12 AM #21
Nice build!
i have done almoast the same engine setup in my G
605, 6mm , stock turbo, but 5-speed 250TDT gearbox.
W124 300D 1985 (daily driver)
MrHope
Nice build!
 10 Guest(s)
 10 Guest(s)
