ANYBODY IN L.A.? Help with timing the injection pump
Hello everyone,
I'm in trouble...today I removed the injection pump in order to replace the gasket between the pump and the engine block (was leaking oil really bad).
I put the pump back in the same position without moving the crankshaft or the pump shaft and as you guys warned me, the timing went to hell. Engine stars but runs bad, doesn't keep the idle and smokes.
No matter how much I looked I couldn't figure out how to do the timing properly - I guess my mechanic skills kind of suck.
In conclusion: I NEED HELP!
Is there any kind soul on this forum who knows how to do this and lives in or near Los Angeles?
If you are that person I would be willing to pay for your time and effort if you can help me. I can meet you at the garage where the car is (Santa Fe Springs / Norwalk area). You don't need to bring any tools, I have everything you need. And if you also know how to "trick" the injection pump in order to get a little more power out of the engine, I would be willing to pay for that too.
Forgot to mention, the engine is a '79 OM617 turbo.
If any of you lives in the area and is willing to help please PM me with your contact info and the best time to reach you.
Thank you,
Andy
We had the same problem happen to us. It's not your mechanical skills. These pumps are fussy.
Before you take the pump out again have the engine at TDC and make sure the timing marks are the pump are aligned before you reinstall. The gear on the IP has groove in it that should match a dimple on the pump housing.
I had taken mine in and out about 10 times in the course of 24hrs before I got it back in there on the right tooth.
Got pretty fast at taking it in and out, about 45min.
Keep us posted and you'll surely be successful.
(09-17-2012, 10:01 PM)Torkey We had the same problem happen to us. It's not your mechanical skills. These pumps are fussy.
(09-18-2012, 04:06 AM)larsalan I had taken mine in and out about 10 times in the course of 24hrs before I got it back in there on the right tooth.
(09-18-2012, 06:20 AM)winmutt(09-17-2012, 10:01 PM)Torkey We had the same problem happen to us. It's not your mechanical skills. These pumps are fussy.
What this guy said. Be aware that certain years had a bad run of pumps where the timing mark was off a few degrees. This is covered by the FSM.
Does your pump have the port on the driver side of it that is plugged with a large hex headed plug? If so, remove it, set your crank bolt to the correct degree marker (not sure of this number, check your manual), loosen the adjustment bolts on the pump, and rotate the pump back and forth until you see the horizontal mark line up with the center of the circle. This might be easier with a swiveling pen mirror.
The mark you are looking for is the little horizontal lug that snaps into place with the factory pump timing lock. See image. It's of an OM603 pump but the lug I believe looks the same.
did you ever fix this? Ill likely be up there for a day or two for turkey day...
