STD Maintenance General Can't open my trunk.... Help?
dieselsmoke300d
To many things I say: Bah Humbug!
65
10-04-2012, 03:24 PM #1
So basically my central locking system is crapping out and the trunk lock refuses to unlock... I've read that there's some kind of release cable somewhere but I don't know. I need to fix my vacuum system anyway...but anybody got any tips on how I could get it open?
Matt.
'85 300SD Turbo
'92 Subaru SVX
'83 Pontiac Firebird S/E
'88 Pontiac Firebird
dieselsmoke300d
Matt.
'85 300SD Turbo
'92 Subaru SVX
10-04-2012, 04:11 PM #2
Use the vacuum hoses under the floormats. Find the trunk ones and vacuum it open.
10-04-2012, 05:35 PM #3
Those go under the passenger side mats.
dieselsmoke300d
65
10-05-2012, 02:10 AM #4
Ok thanks. I have an idea though. I have a vacuum pump for a dental porcelain furnace (from my dad's business), I was thinking about hooking that up to the main line and going around the car and listening for leaks. It's stronger than the car's pump too so it may work to unlock the trunk. I'm hoping it isn't a bad line I'll have to replace, I'm thinking the passenger lock actuator could be shot. I've heard a high pitched hissing sound from that door a few times.
Matt.
'85 300SD Turbo
'92 Subaru SVX
dieselsmoke300d
Matt.
'85 300SD Turbo
'92 Subaru SVX
SurfRodder
Jackass Extraordinaire
611
11-17-2012, 04:44 AM #5
do you only have the valet key? the master key should unlock it at the trunk button...i've never had the vacuum locks working on my car and never had trouble unlocking the trunk... I got two keys when I bought it, one that opens everything and one that doesnt work for the trunk(valet).
OBK# 62
SurfRodder
OBK# 62
11-17-2012, 11:52 PM #6
Search on peachparts, there's a method to go through the first aid box with a broom handle
11-18-2012, 06:10 AM #7
I've also heard about hitting the area under the trunk lid where the license plate is with a 2x4 or somethin, not sure how that works though
11-18-2012, 08:50 AM #8
Howdy,
I actually have real world experience on this one. I recently bought a car, w123 sedan where the PO "forgot" to mention that the rear trunk lock was busted. It was actually drilled out and really screwed up. The "Thump" method will work and a modified "Thump" method worked for me. I took a screw driver where the the PO drilled out the cylinder and hit that screw driver a few times, not super hard, and the trunk lid popped right open. So, if you don't have a destroyed cylinder or lock already, I would try the Thump method. You will need 2 people, and it worked for me. I did this about 2 weeks ago.
Howdy,
dieselsmoke300d
65
02-22-2013, 06:05 PM #9
Well it's been a while since I posted this. But I ended up finding the vacuum line junctions under the plastic trim underneath the passenger door. Tried a couple lines with a crappy pump I bought and no luck. But the very last tube I tried was it. Sucked the air out and click! The trunk was open! The central locking system is pretty messed up so I ended up just capping off the main line to the locks.
Matt.
'85 300SD Turbo
'92 Subaru SVX
dieselsmoke300d
Matt.
'85 300SD Turbo
'92 Subaru SVX
