STD Tuning Engine Audi 5cyl rotary pump
Motorhead
06-26-2009, 06:51 PM #1
I want to find the Audi 5cyl rotary pump. Plenty of upgrades for that line. and from what I have seen it has the same driveinterface.
MOD EDIT: This topic was started by Winmutt
This post was last modified: 07-05-2009, 09:11 AM by ForcedInduction.
Motorhead
Motorhead
07-02-2009, 05:03 PM #2
(07-01-2009, 09:28 PM)winmutt I want to find the Audi 5cyl rotary pump. Plenty of upgrades for that line. and from what I have seen it has the same driveinterface.
Is the Audi pump for a diesel or do the bosch mechanical F/I pumps work the same way as diesel I/P's do, who has the best pumps so far?
Motorhead
07-03-2009, 07:20 AM #3
Diesel Audi 5 cylinder. Pretty rare here.
dalek
07-04-2009, 12:28 AM #4
(07-03-2009, 07:20 AM)winmutt Diesel Audi 5 cylinder. Pretty rare here.
From Dalek
This post was last modified: 07-07-2009, 06:49 AM by winmutt.
dalek
From Dalek
GREASY_BEAST
07-04-2009, 10:19 AM #5
Will it clear the block? What do the splines look like?
GREASY_BEAST
Motorhead
07-04-2009, 11:09 AM #6
It looks like it is cog belt driven, it would not be a bad install. What is the fuel volume potiential, last question how much?
Motorhead
GREASY_BEAST
07-04-2009, 02:02 PM #7
(07-04-2009, 11:09 AM)Motorhead It looks like it is cog belt driven, it would not be a bad install.
Ah, I see now. Runs right off the timing belt. Sure, won't be a bad install as long as it clears the damn block on the back side. Could make a spacer to ensure that it clears the lip on the bottom, as long as it doesn't interfere with the oil cooler lines.. I guess you could give it its own cog and belt and hang it out from the block if it doesn't fit. Simple 2-bearing block, ball bearings, and an oil seal, run the IP oil return straight to the oil pan. Things are pretty tight around the IP on the 617.
GREASY_BEAST
07-04-2009, 03:09 PM #8
All you have to do is put the spline snout on the shaft and bolt it up. I dislike rotary pumps though, I wouldn't do it.
This post was last modified: 07-04-2009, 03:09 PM by ForcedInduction.
Telecommbrkr
Soon to be mod'ing......
97
07-04-2009, 11:23 PM #9
(07-04-2009, 03:09 PM)ForcedInduction I dislike rotary pumps though, I wouldn't do it.
What causes your dislike?
Mods are in the works...
Telecommbrkr
07-05-2009, 12:22 AM #10
Personal preference. I've always seen inline pumps as the better pumps.
Telecommbrkr
97
07-05-2009, 12:51 AM #11
This a gut feeling, or do you think mechanically that the rotary is a lesser unit? ie: longevity, adjustment, failure issues, etc.
I am just curious about these pumps, and if it would be an option that would allow easier tunability, plus the fact that there is an aftermarket parts availability for them.
Telecommbrkr
07-05-2009, 02:54 AM #12
(07-05-2009, 12:51 AM)Telecommbrkr This a gut feeling, or do you think mechanically that the rotary is a lesser unit? ie: longevity, adjustment, failure issues, etc.
A few things. Its lubed by fuel, it has only one plunger to pump all 5 cylinders (plunger float at high RPM?, like wheels driving over washboard) and fuel pressure is critical to its survival (too low and it can die) are what I can think of off the top of my head.
This post was last modified: 07-05-2009, 08:25 AM by ForcedInduction.
dalek
07-05-2009, 08:14 AM #13
ForcedInduction said he would not do it. I am not here to disagree with him. He knows much more about diesel pumps in his little finger I would ever know in a lifetime.
dalek
07-05-2009, 08:27 AM #14
(07-05-2009, 08:14 AM)dalek ForcedInduction said he would not do it.
Thats no reason NOT to do it. VO "conversions" are one thing, but when it comes to performance improvement I don't mind being proven wrong.
If that rotary pump turns out to work well, it could prove a reasonable Myna-alternative.
dalek
07-05-2009, 08:49 AM #15
I am just here to lurk and maybe ask a few questions. The last thing I want to do here is to prove anyone wrong. I just thought someone would want to see the Audi pump; if that was seen as stepping on people's heads, I do apologize.
This post was last modified: 07-05-2009, 08:52 AM by dalek.
I am not here to make waves; Sois jeune et tais toi
dalek
07-05-2009, 08:59 AM #16
(07-05-2009, 08:49 AM)dalek I just thought someone would want to see the Audi pump; if that was seen as stepping on people's heads...
Not in the least. Please post more detailed pictures if you have them, I would like to see the idea progress rather than die in the middle of a thread. This place is all about learning from each other's adventures.
Motorhead
07-05-2009, 10:12 AM #17
I guess if you wanted to mount it where the stock I/P goes you could make a drive that connects to the stock location and have your cog pulley drive the pump off the side, this would keep the cog belt away from alot of road debris.
Motorhead
GREASY_BEAST
07-05-2009, 01:48 PM #18
PartsPlace Inc seems to have a lot of VW/ Audi diesel stuff for sale. Their sales dept. phone number is (248) 373 2300. From their website:
http://www.partsplaceinc.com/
This post was last modified: 07-05-2009, 01:48 PM by GREASY_BEAST.
GREASY_BEAST
606Power
07-06-2009, 01:22 PM #19
The drive is a tapered 17mm OD shaft and a respective woodruff key with the drive pulley held in place with a nut. The flange is a similar 3 bolt style to the inline pump. A machine shop might be able to help spline the driveshaft provided there is material that could be removed.
Alternately, a Gilmer belt sprocket could be salvaged as a bushing with splines machined into it, so the 617 sprocket would fit. I am not sure of the ID of the 617 sprocket, however.
The audi based pump can be fitted with a 12mm diameter plunger/head from stock bosch parts, and there are custom 14mm diameter plungers available as well. With a suitable cam plate, the pump will yield about 75% more fuel compared to the stock plunger ( I last recall it is 10mm in diameter ) and well over 100%
with the 12mm and 14mm plungers respectively.
Many cam plates are available too, and the stock cam plate is very benign. A higher lift cam plate gives more fuel as well, so a combination of a larger diameter plunger and the cam plate is what you would want.
The 617's timing advance would need to be disabled, or retain it, and keep the inline pump's sprocket timing advance fixed. I would consider trying the latter, which allows you to tune the timing via the VE pump.
Stronger plunger springs can be fitted to keep cam plate float in check for over 6K rpm operation easily. Indeed, no oil feed is needed for the VE type pumps.
606Power
07-06-2009, 01:58 PM #20
Interesting the audi pump I saw had the same as the inline pumps.
Motorhead
07-06-2009, 05:53 PM #21
So there is a timing advance in the 617 pumps, how much and at what rpm?
Motorhead
07-06-2009, 06:03 PM #22
(07-06-2009, 05:53 PM)Motorhead So there is a timing advance in the 617 pumps, how much and at what rpm?
7.5* advance via the timing device (the sprocket the chain drives and the vacuum pump rides on). At what RPM and under what conditions it advances, I don't know.
This post was last modified: 07-06-2009, 06:04 PM by ForcedInduction.
Motorhead
07-06-2009, 10:43 PM #23
Is the advance device in the I/P or the front cover?
Motorhead
07-06-2009, 10:48 PM #24
In the engine. The timing chain directly drives it.
Telecommbrkr
97
07-06-2009, 11:17 PM #25
Great info 606Power
What year(s)/model(s) of audi did these pumps come in?
Is the pump Volvo uses for it's 5cyl diesels a rotary as well?
Telecommbrkr
Great info 606Power
GileadGarage
07-06-2009, 11:42 PM #26
I'm pretty sure all the Volvo diesel's used VE rotory pumps, for automotive applications anyway. I know the 6cyl diesel was made by VW, not sure about the 5. I still do not see why one would want to swap over to a VE, but who knows, it'd be interesting to see it happen.
I believe some Duetz 5cyl used a variation of the VE too.
On ebay, there were some new 5cyl Bosch VE pumps from some weird generator application (maybe Duetz, didn't say) The place also had a 4cyl Onan VE pump which I installed in my Samurai, turned out to be a Cummins 4BT 12MM pump brand new for 140 bucks! It had many differences from the automotive version, but I got it sorted out and it's working well on the Samurai - had to turn it way down though - it would smoke truck pull style when I first installed it!
(07-06-2009, 11:17 PM)Telecommbrkr Great info 606Power
GileadGarage
606Power
07-07-2009, 10:37 AM #27
Sure, anytime.
I do not recall the years exactly, but perhaps 83-84. An NA pump would be fine as well, since you can get the turbo/aneroid/LDA top cover, and fit it onto the NA pump.
If you cannot get the aneroid top cover, the pump can still be tuned similarly for power, but will have less off boost smoke control. The aneroid is limited anyway when it comes to increasing the plunger diameter.
VW did use the VE mechanical pumps in their euro 2.5L engines as well, which could be another source for parts/pumps.
Volvo 240s did use the same NA 5 cyl engine as was used in the Audi 5000, but in Europe as far as I know, and was designated the D20.
606Power
Sure, anytime.
 15 Guest(s)
 15 Guest(s)
