STD Tuning Engine parts list needed for superturbo conversion
brianmccourt
10-11-2012, 12:15 PM #1
as above i know i need a
intercooler
om603 intake with 6th cut off?
good lift pump
uprated diesel injection pump
hx30-35
clutch not sure what one yet
any other bits?
brianmccourt
intercooler
good lift pump
hx30-35
any other bits?
mantahead
10-11-2012, 02:34 PM #2
hi,
depends how much power you want.
you will also need exhaust manifold and some sort of wastegate.
dual mass flywheel will hold 385bhp
mantahead
hi,
brianmccourt
10-11-2012, 03:46 PM #3
only after 250-300 was going to make a up pipe for the turbo and get one with a internal wastegate?
brianmccourt
mantahead
10-11-2012, 04:49 PM #4
(10-11-2012, 03:46 PM)brianmccourt only after 250-300 was going to make a up pipe for the turbo and get one with a internal wastegate?
ok lad, i run 385bhp with Dieselmeken pump and hx35 fitted to uppipe and uprated clutch and pressure plate. Standard clutch give up at 266bhp.
mantahead
10-11-2012, 09:23 PM #5
What clutch are you running manta?
To OP, what engine do you have? 602?
mantahead
10-12-2012, 03:17 AM #6
[quote='winmutt' pid='45086' dateline='1350008583']
It was a clutch i got made in England for 1998 w202 c250td, it was the strongest pressure plate he had, it was 5 puck paddle. can't remember company name but can find out.
[Image: SU1HMDA4NzktMjAxMjA0MDctMTI0OS5qcGc.jpg]
[Image: SU1HMDA4ODAtMjAxMjA0MDctMTI0OS5qcGc.jpg]
This is after it has done some work.
mantahead
brianmccourt
10-12-2012, 03:21 AM #7
its a deasent looking clutch how much? what boost you running mantahead?
any parts for sale????
brianmccourt
mantahead
10-12-2012, 04:21 AM #8
(10-12-2012, 03:21 AM)brianmccourt its a deasent looking clutch how much? what boost you running mantahead?
was running 3.3 bar at one time with 12cm housing, no wastegate, and only run about 2.6 or 2.7 bar with 18.5cm housing. Clutch was about £400 or so. Not much left, all sold to fund new project. I have welded diff for c250, c250 manual box, some e300 bits as well, also holset hx35 with two different exhaust housings.
mantahead
brianmccourt
10-12-2012, 11:53 AM #9
alri how much for the hx? prob be bit big for my one would it ?
brianmccourt
mantahead
10-12-2012, 12:14 PM #10
hi,
i sent you pm.
mantahead
hi,
i sent you pm.
