STD Tuning Engine Ram/Cold Air intake
Ram/Cold Air intake
Ram/Cold Air intake
thegooch27
10-13-2012, 06:23 PM #1
I was able to put this together for around $85.00. It's a K&N Apollo universal intake. I also had to buy a 60 Degree silicone reducer elbow and I also run the prefilter. There is a more turbo noise with this setup but I like it!
thegooch27
10-14-2012, 10:19 AM #2
I like it Smile
I like it Smile
cho
10-15-2012, 04:50 AM #3
looks good Smile
looks small Sad
what's the CFM?
cho
looks good Smile
looks small Sad
what's the CFM?
thegooch27
10-15-2012, 11:05 AM #4
(10-15-2012, 04:50 AM)cho .
looks good Smile
looks small Sad
what's the CFM?
http://www.knfilters.com/universal/apollo.htm
Good for up to 350BHP...
thegooch27
looks good Smile
looks small Sad
what's the CFM?
cho
10-16-2012, 06:03 AM #5
(10-15-2012, 11:05 AM)thegooch27
looks good Smile
looks small Sad
what's the CFM?
in that case:
good job good job Big Grin
cho
looks good Smile
looks small Sad
what's the CFM?
in that case:
10-21-2012, 02:53 PM #6
This looks awesome, and I was thinking about doing it to my car. You said you had about $85 in it? The cheapest filter i have found is $99. Cool ideaBig Grin
DirtDiesel
10-21-2012, 08:24 PM #7
I dont know if you like AFE filters but you can build your own for roughly $50 just my input
DirtDiesel
don
08-22-2017, 02:37 PM #8
I'm looking into building a snorkel setup for my OM617 into the Land Rover 110 and thinking of using this as the air filter as it is an inline setup.
Does anyone have any insight into it since 2012?
Thanks!
don
Thanks!
NZScott
HX30W 73/44mm
398
08-22-2017, 11:34 PM #9
First time for me seeing this thread and first impression is it's rather tiny for a diesel. 350 hp might be plucked out of thin air for a petrol engine which doesn't need as much air mass per hp as our IDIs do. And did I mention K&N filters are shit? Lol
This post was last modified: 08-22-2017, 11:35 PM by NZScott.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
ross
08-23-2017, 05:24 AM #10
(08-22-2017, 11:34 PM)NZScott First time for me seeing this thread and first impression is it's rather tiny for a diesel. 350 hp might be plucked out of thin air for a petrol engine which doesn't need as much air mass per hp as our IDIs do. And did I mention K&N filters are shit? Lol
This!!
Why on earth you'd want to fit one is beyond me. Especially in a land rover type vehicle, they just let allllll the crap through.
ross
This!!
don
08-23-2017, 11:25 AM #11
(08-23-2017, 05:24 AM)ross
This!!
Thanks - haha glad I brought the thread back up then before I made a purchase!
What I thought was slick was the enclosed design where I could run the tubing from the snorkel to one side and then exit out to the turbo inlet.
I could always make something out of sheet aluminum but I'm so sick of fabrication work (been taking me ages to get the HX30 installed) that something "off the shelf" would make it easier for me.
If you guys have any suggestions please let me know - I would really appreciate it!
don
This!!
Alec300SD
08-23-2017, 01:49 PM #12
Do you have an existing air box that fits, like a PHB102510, that you can waterproof?
Alec300SD
ross
08-24-2017, 07:44 AM #13
(08-23-2017, 11:25 AM)don
This!!
Most Land Rover air boxes are probably all too small, BUT the defender v8 one is huge and should be plenty big enough!
This post was last modified: 08-24-2017, 07:45 AM by ross.
ross
This!!
don
08-24-2017, 08:50 AM #14
(08-23-2017, 01:49 PM)Alec300SD Do you have an existing air box that fits, like a PHB102510, that you can waterproof?
I don't - I can see if anyone in the US has one tho.
don
don
08-24-2017, 08:51 AM #15
(08-24-2017, 07:44 AM)ross Most Land Rover air boxes are probably all too small, BUT the defender v8 one is huge and should be plenty big enough!
My brother in law has a parts RRC. I'll see if that has anything worthwhile. If it's made of steel I can modify it as I have a welder.
don
Alec300SD
08-24-2017, 09:37 AM #16
Depending on your available room you may be able to fit a stock MB fender mounted air box.
It should give adequate airflow.
One from a 85 W126 300SD recently has been mounted on my 83 W126 300SD.
This frees up space to install my non-EGR exhaust manifold and the longrunner W115 intake manifold.
Alec300SD
ross
08-24-2017, 09:52 AM #17
(08-24-2017, 08:51 AM)don My brother in law has a parts RRC.  I'll see if that has anything worthwhile.  If it's made of steel I can modify it as I have a welder.
From memory the RRC ones are quite small, but should work Smile
ross
don
08-25-2017, 09:25 AM #18
(08-24-2017, 09:52 AM)ross
If I can get a freebie one from my brother in law I might get a second one on eBay and seam weld them together to make something where a good size filter will fit.
don
don
08-25-2017, 09:29 AM #19
(08-24-2017, 09:37 AM)Alec300SD Depending on your available room you may be able to fit a stock MB fender mounted air box.
Thanks - I might just do a cylinder style so air filter R&R will be (or should be) easier.
I like the different ideas tho!
don
 11 Guest(s)
 11 Guest(s)
