STD Tuning Engine EATON M112 AND ????? TURBO
mantahead
09-05-2012, 05:26 PM #1
Hi,
for my new drift car i would like at least 500bhp, i am going to force feed the turbo intake with the eaton m112 and then use a bypass valve when the blower runs out of steam. This is the om606 engine.
I like the holset hx35 i used before(OM605), although it was slow to spool. It will be too small now anyway.
I want it to spool as fast as possible, the question is: what turbo?
Is a hx55 too big?
This post was last modified: 09-05-2012, 05:31 PM by mantahead.
mantahead
Hi,
Is a hx55 too big?
Siekkinen
09-06-2012, 03:14 PM #2
Hx52 pro is fine.
w124 300 STD/daily driver
w202 250 TDT
w201 2.6E
Siekkinen
Hx52 pro is fine.
w202 250 TDT
w201 2.6E
mantahead
09-06-2012, 04:11 PM #3
hi,
is there many different exhaust housings?
what size of housing?
(09-06-2012, 03:14 PM)Siekkinen Hx52 pro is fine.
mantahead
hi,
mantahead
11-14-2012, 05:29 PM #4
hi,
can't get a hold of a hx52 at the right money, what about a garret Gt4088 with a 1.06 AR exhaust housing.
mantahead
hi,
Turbo
11-14-2012, 06:28 PM #5
Pekka Herlevi suggested for me hx 50 compressor 63mm and exhaust 73mm exhaust housing size 14-16cm3, but spool was not impressive at all
(11-14-2012, 05:29 PM)mantahead hi,
Turbo
mantahead
11-14-2012, 06:39 PM #6
(11-14-2012, 06:28 PM)Turbo Pekka Herlevi suggested for me hx 50 compressor 63mm and exhaust 73mm exhaust housing size 14-16cm3, but spool was not impressive at all
what kinda power would the hx50 make?
the charger should speed up the spool up hopefully.
mantahead
Turbo
11-15-2012, 04:25 PM #7
I ask for a turbo suggestions for +600hk and Pekka gave that suggestion, I never tried it since I am retuning and building the engine for higher purpose
quote='mantahead' pid='45982' dateline='1352936351']
[/quote]
Turbo
[/quote]
EDH_Performance
11-16-2012, 09:10 AM #8
I am going to use a hx52 with billet wheel and 16cm2 exhousing in a compound setup on mye engineBig Grin
EDH_Performance
Siekkinen
11-17-2012, 04:08 PM #9
hx50 can make more than 500 horsepower. Don't know how much more but 600 horsepower could be possible with it.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
