STD Tuning Drivetrain w210 diff change.
w210 diff change.
w210 diff change.
w210tdt
11-24-2012, 09:28 AM #1
diff question for you guys!
i`m planning to change the diff in my w210 e230 (om606-converted).
it has a 3,46 ratio ,and im trying get a hold of something lower.2,65/2,88.does anyone know if a w124 diff will fit in this car?
the 3,46 diff measures 22cm between the driveshaft flanges..
w210tdt
EDH_Performance
11-24-2012, 01:05 PM #2
(11-24-2012, 09:28 AM)w210tdt diff question for you guys!
I do not think it will be bolt on! The 210mm is very bigBig Grin Have one with 2,2 ratioSmile Planning to use in my 190d superturbo projectWink
EDH_Performance
w210tdt
11-24-2012, 01:35 PM #3
(11-24-2012, 01:05 PM)EDH_Performance
So the 210mm diffs Are the ones with low gear ratio?and my 3,46 is 185mm then?
2,20 sounds Nice ,planning to go 300km/h in your 190? Smile
This post was last modified: 11-24-2012, 01:41 PM by w210tdt.
w210tdt
EDH_Performance
11-24-2012, 01:58 PM #4
(11-24-2012, 01:35 PM)w210tdt
I think you can get it with high ratios as wellSmile Yes, theoretical top speed at 360km/h !!
EDH_Performance
