Where to buy racing plenum?
Don't ask such hard questions from me, ask the owner of the company.
He speaks English so it's not a problem if you can't make it in Finnish.
Boost wise it should hold anything depending how good it is welded, and (maybe) reinforced at some points. The plenum case halves are made of 4mm pressed alu sheets and the tapered tube is 3mm bended alu sheet.
Volumetric efficiency etc. is a good question, but the answer for it does not come from me. What I understand is that this is mainly universal plenum kit for 4-6cyl motors that "should" work better than OEM and make charge pipe routing alot more flow friendly than most OEM intakes. The tapered tube design seems quite good and should make close to equal flow and volume between first and last runner, because it tapers down near the last runners.
Also the intake design looks quite alot like in WRC cars...if that is a good thing or no, I don't know.
$20 for velocity stacks is cheap
(11-26-2012, 03:46 AM)maKe- Don't ask such hard questions from me, ask the owner of the company.
Also the intake design looks quite alot like in WRC cars...if that is a good thing or no, I don't know.![]()
I have e mail the owner, interesting to see what he respond
Is there a benefit to it choking down to such a small opening rather than having the boost hose connect to the large section?
(11-26-2012, 08:35 PM)300SD81 Is there a benefit to it choking down to such a small opening rather than having the boost hose connect to the large section?
(12-11-2012, 04:46 PM)Turbo somebody here have there phone number and fax number?
