(10-03-2011, 03:21 PM)dropnosky This weekend removed subframe, engine and tranny from recently sourced parts van.
(10-03-2011, 07:14 PM)DeliveryValve Now that is useful when giving these things a tuneup! I hate changing the air cleaning and plugs on these year vans.
(10-05-2011, 04:37 PM)dropnosky .......
So overall, the subframe needs to be rebuilt, especially the driver side, which is about 3 times as bad as the passenger side. Ive dropped the whole thing off at a local rust repair place, who will be rebuilding the bad passenger lower control arm support, patching and reinforcing the holes, and then rust proofing the interior parts and undercoating the outside.
(10-05-2011, 06:43 PM)DeliveryValve Or I can box one up for you..... Just joking.
what kind of turbo will you be using on the 240D engine and how will you prevent it the turbo from ruining the engine? willbhere4u told me 10psi is the safest maximum load that wont cause damage to the engine, will you be doing the same?
(10-05-2011, 07:33 PM)dropnosky ..
lol, you don't want and try and break your record? I estimate a box for one of these subframes would be at least 80-100 lbs, and 5 feet by 6 feet by 2 feet.
Its not overly heavy, but its certainly awkward. After the double front fender box, should be childs play since its only one unit
(10-06-2011, 10:40 AM)Purplecomputer what kind of turbo will you be using on the 240D engine and how will you prevent it the turbo from ruining the engine? willbhere4u told me 10psi is the safest maximum load that wont cause damage to the engine, will you be doing the same?
(10-06-2011, 10:48 AM)DeliveryValve Actually, it would be best to bubble and shrink wrap it and have no box. Then it shipped out that way. I know Greyhound would take bubble wrap parts. Not sure if they would take a 5x6x2 part though...
(10-06-2011, 10:54 AM)dropnosky ...
Lol, I was just joking, don't even consider it! You would have to completely break down the subframe to make it realistically quasi-mobile, removing all steering and suspension as well as the motor and ect ect. Unless you happened to find one standing against a van, no way it would be worth it, and even then, probably not
yard would probably charge me 1000 bucks in labor just to strip it down. Guy here is thinking about 400 bucks to fix it and paint it.
I am actually taking your idea of the custom manifolds and doing the same thing to my 240D. I am actually pretty eager to see you put the turbo on and give us some results on performance and any issues you may have. for me i have to wait until i replace the shocks
(10-06-2011, 05:46 PM)Purplecomputer I am actually taking your idea of the custom manifolds and doing the same thing to my 240D. I am actually pretty eager to see you put the turbo on and give us some results on performance and any issues you may have. for me i have to wait until i replace the shocks
I had an IHI turbo off of a ford probe on mt 240 engine & it worked pretty nice. It was in a Sammy with 6WD. Never had a boost gague or EGT, but it's still running at the salvage yard I worked at 6 years ago. I had Cush (our guyannan mechanic) twist screws in the pump & it sure made a difference. It also was on WVO & gasoline blend (Floriduh weather).
Ed
exciting developments-
1- Transmission is FINALLY ready. So it turned out that the 1990 AstroRS T5 that I originally sourced is a single year variant of that gearbox. We were striking out finding any T5 that would accept the shifter, tailcone, and bell housing from the wrecked astro trans. It had to be a T5 from exactly the same year, and from a limited number of vehicles, IE, some of the S-10s, and some of the camaros, but not all.
However, in a stroke of luck, the trans shop guy eventually managed to find a T5 gearbox out of a 90 S-10 that worked for the right price! So now I have a complete rebuilt gearbox for this project.
Everything works, it even has the right splines so I can order a clutch kit for a 1990 astroRS. (which ive done, should be in end of the week)
2- Subframe rust repair is complete, and the whole thing has been undercoated. I may try and spray some rustcheck or some such up in the internal areas of the frame, but its ready for the engine and trans to be test fitted. Once I get the clutch, I can start trying to put this together.
Next big hurdle is finding replacement clutch hydraulic parts. Every auto parts store ive called cannot find a slave or master cylinder for a 90 RS van, ill be going to the dealer to figure this out. Im sure it cross references with something else. I HAVE been able to find rebuild kits though, so I might have to go that route. I have a bad set, so they can probably get me some matching part numbers hopefully.
The progress is looking good so far. Are you going to be using the gasser engine on this until you wait for it to become of age so you can use the 616?
(10-25-2011, 10:38 AM)Purplecomputer The progress is looking good so far. Are you going to be using the gasser engine on this until you wait for it to become of age so you can use the 616?
rockauto.com lists a slave for a 90 astro witht eh V6 as being $15.31, part # S0401
master is part #M0401 $27.79
(10-25-2011, 03:26 PM)300D50 rockauto.com lists a slave for a 90 astro witht eh V6 as being $15.31, part # S0401
Those were the middle-of-the-road priced ones, they had Sachs for more and Kelsey-Hayes for less.
Heres another bunch of pics
The clutch showed up, so I got to put the engine and gearbox together using the 4x4 lab kit, and boy, Im definitely of the opinion that that kit was worth it. Just went together so nice, and finish quality is great.
Heres the flywheel bolted up, I was mistaken, i did not need to block it off the crank shaft, the tolerances are about 2mm behind the flywheel
The new clutch I got was effectively the same as the one I purchased way back for a K-1500 except for the splines and a different pilot bearing. heres a pic of the MB to Chevy pilot bearing adapter from 4x4 labs. I ended up using the actual bearing that came in the 1500 kit, and not the bushing that came in the new kit.
Bearing adapter goes through the new flywheel into the crank, and seats nicely with the new pilot bearing in. I really was pleased with how they rigged this up
Clutch installed, shift fork and release bearing installed- (i need the GM boot for the shift fork, and I might need to weld slave cylinder seating point for the shift fork, its slightly cracked)
Bolted up the gearbox, and here are a few pics of the 616 and the T5 next to the stock Astro 4.3 and auto-
Here is the new motor laying in the subframe. I used the rear transmission mount point to locate where it should be, and there is good news and maybe possible bad news.
Good news is that the engine won't interfere with the steering apparatus as I was expecting, and there should be more than enough room up front for choosing a radiator.
Bad news it that its awful high, and might hit the top of the hatch. I might get real lucky though, I measured the 4.3 and the 616 and with the air cleaner on the 4.3, they are close in height, plus a little working room. Just have to see how it fits when the time comes and make adjustments then.
Also, draining the oil might be a pain, maybe ill change the drain location on the pan to the front
Time to build motor mounts, passenger side should be a straight shot, drive side will have to come forward a bit. On the fence about using stock GM or MB mounts, any thoughts? The GM mounts are WAY easier to change. Also, should I rig up a bracket to include the engine shock?
pass side-
driver side-
Look'n good! Love it!
Couple of notes.
1) How are you going to do a routine valve adjustment?
2) I'd use the stock Chevy mounts.
3) What is the clutch size of the new flywheel assembly. The stock w123 size for a 616/617 is 215mm and the M110 is 228mm with the 300GD also 228mm.
(10-28-2011, 09:01 PM)DeliveryValve Look'n good! Love it!
Couple of notes.
(10-28-2011, 09:01 PM)DeliveryValve 1) How are you going to do a routine valve adjustment?
Couple of notes.
Your welcome! I just know how much a pain in the arse that engine bay is to work in!
Lowering the engine more is probably the best way to deal with that. Another would be to make a custom valve cover in which the upper portion can slide to towards the rear right off. (Calling Walt!) But I still wonder how much room you'll have to put the wrench in if you don't drop the engine more.
Modifying the subframe to lower the engine will definitely cause the oil pan to hit the steering linkages if your going to keep the engine at the same location. Perhaps you can drop the linkages down? Possibly have the steering box go lower and have the two idler arms mount lower also? Or if you can't lower the box, then make a custom bent connecting rod between the box and the relay arm working in conjunction with the lowered idler arms.
And if you can't get the steering to work out, then maybe an entirely different suspension is needed.... Like a custom Mustang II supension with "rear" steering rack and pinion or a Plymouth Volare suspension type subframe swap. I don't know, just throwing stuff out there.
all good ideas!
here are some pics of the stock steering bars-
If I cut into the subframe to lower the engine, I will definitely hit the steering as you say, if I go too far down
Still might be possible. Also if I dare to cut the subframe, I will possibly be playing a dangerous game with the lower control arm mounting point structural integrity.
You can see in this pic those holes in the subframe on either side of the motor? the lower control arm front pivot slides inside the subframe there and in sandwiched.
Since the engine is way over on the passenger side (still needs to be levelled) any cuts would be awfully close to exactly where that critical junction is
Maybe I should go 300D50's route and modify the stock oil pickup so I can have a shallower pan. I would have a lot less potential issues if I could rig up a way to have that valve cover open like a clamshell as two pieces off to the side. maybe thats possible.
can you modify the firewall and move the whole thing back 6" and drop it down a bit
(10-29-2011, 11:09 AM)willbhere4u can you modify the firewall and move the whole thing back 6" and drop it down a bit
Shelby Cobra shifter!
What about using a rack & pinion steering setup ? I searched & found http://www.astrosafarivans.com/bb2/viewt...f=5&t=1190
Ed
(10-31-2011, 03:15 PM)yankneck696 What about using a rack & pinion steering setup ? I searched & found http://www.astrosafarivans.com/bb2/viewt...f=5&t=1190
Ed
Ed
(10-31-2011, 03:32 PM)dropnosky(10-31-2011, 03:15 PM)yankneck696 What about using a rack & pinion steering setup ? I searched & found http://www.astrosafarivans.com/bb2/viewt...f=5&t=1190
Ed
thats an interesting read that would be a good solution. thanks for the link!
Ill get the cut made, and the engine in position, and see what I might have to do
Ed
committed now.
its off being welded again, the cardboard in the background will be a steel reinforcement that will go on the back side of the cross member.
Rear side steering would require alot of fabricating to get the Ackerman angle right.
Ed
lol, well the guy went a little nuts with my statement "make it strong"
I had almost 3/4 of an inch gap on all sides, he threw so much steel on there that its awful close on the passenger side. however, he did an impressive job making it about as indestructible as you can get.
heres from above-
couple other pics-
heres with the engine. Think it will sit a bit higher to clear the passenger side. actually not touching in the pic, but its definitely gonna be close unless I raise it a bit-
woah, progress is coming along quickly! Keep posting those pictures
Not the skidplate! haha
(10-28-2011, 08:41 PM)dropnosky Time to build motor mounts, passenger side should be a straight shot, drive side will have to come forward a bit. On the fence about using stock GM or MB mounts, any thoughts? The GM mounts are WAY easier to change. Also, should I rig up a bracket to include the engine shock?
Talk to me about that oil filter!
im very very seriously considering sidetracking this motor into my volvo wagon, and going 5cyl in this van next year instead.
The wagon is also an 89, but inspected with a 2014 sticker end date, so would be past 25 years by the time it comes back around to be done, so I could start swapping whenever I want.
(06-15-2012, 10:06 AM)JB3 im very very seriously considering sidetracking this motor into my volvo wagon, and going 5cyl in this van next year instead.
(06-15-2012, 10:34 AM)Purplecomputer(06-15-2012, 10:06 AM)JB3 im very very seriously considering sidetracking this motor into my volvo wagon, and going 5cyl in this van next year instead.
if you like giving up and being a quitter
JK! swapping a turbo 616 into anything is cool !
(06-15-2012, 02:12 PM)JB3(06-15-2012, 10:34 AM)Purplecomputer(06-15-2012, 10:06 AM)JB3 im very very seriously considering sidetracking this motor into my volvo wagon, and going 5cyl in this van next year instead.
here are my thoughts-
EGTs.
Its all about EGTs, and what those will do to this 616. Not only am is waiting forever getting to be a real bother, but ive become increasingly concerned about EGT issues with the 616 motor putting it in this van as I really look at how I use it.
Here are some pics that demonstrate what I do with this van all the time-
pulling a taurus-
pulling another van-
pulling various VWs-
On top of that, I dont have pics but this van has towed my 115, my GFs 123, my friends Jeep, ect.
This is just private use, not counting the 30-40 times Ive rented double axle trailers from uhaul ect for job sites out in the hilly boonies. I use the shit out of this thing.
So basically, when I really consider what I do with this van, the question is am I being foolhardy thinking that putting a 616 in it with a turbo conversion where EGTs are a concern, and where most of my activities are guaranteed to drive up EGTs. Will the engine last a week? and why wouldn't I just put in a turbo 5cyl 617 for twice the HP, designed for the turbo, and use the same adapter?
These are the questions running through my mind. At the same time, my volvo wagon is both lighter than the 123 chassis, and never destined to tow, so it might be a better platform.
EGTs.
pulling a taurus-
(06-15-2012, 05:14 PM)Purplecomputer It would have been a cool project but I did always wonder if the turbo 616 would live long if you used it for towing.
I think the wagon is a better idea.
(06-27-2012, 11:21 AM)aaa EGTs would go down when you turbo it...
Why did you go 616 to begin with?
If you're worried about EGTs get yourself:
A cheap EGT gauge ($65, probe included)
A cheap intercooler
A modern variable vane turbo (Dropped my EGTs ~80°F
A straight pipe (dropped my EGTs ~100°F)
Maybe put in an oversized oil cooler as well?
If you go with a 2056V I have a print of my adapter somewhere on PP, print it out 1:1 and start drilling.
(06-27-2012, 11:40 AM)aaa I would assume you wouldn't boost it as hard a stock 617 is boosted. Additional air with not much additional fuel would go a long way towards cooling things down. Assuming you can live with 62hp.
(06-27-2012, 01:36 PM)Simpler=Better If you're worried about EGTs get yourself:
A cheap intercooler
A cheap intercooler
exciting development. Windshield Kaput.
Exciting because in the process of getting it replaced, im gonna lose the current inspection sticker. I was under the impression that I had to go ahead and get another sticker that ended the same time based on vin, but ive discovered that if its totally gone, I just pay 30 bucks, and get a new 2 year inspection sticker, and boom, I can start my conversion. Anything I get now will be till 2014, which is 25 years old
What im waiting on now is some rust repair on the windshield mount area, and then its off to be inspected.
also, staying with the 616 after sleeping on it
Great!
The 616 will be nice and light, and you can always turn the pump up
some updates-
Put this van in the air, and I thought it was in good shape for rust, but notice how the subframe is hanging on one side here-
driver side super rusty, not attached anymore-
4.3 ready to be dropped-
from inside-
dropped-
all the mount locations are rusty unfortunately-
after the engine was out, whipped up a jig to control stock ride height for the replacement drivetrain
with engine removed-
have some rust on the body to deal with, only part though, apart from some rust in the rocker that can be resolved after the subframe is put back up-
Using that jig, I set up the new modified subframe, and got the correct engine height for the diesel
working on motor mounts now.
Good news on the throttle, I should be able to use the stock cable throttle on the diesel without incident. Interesting, it circles around the entire engine bay, and comes around to the driver side of the engine from the passenger side. thing is about 8 feet long-
big issues to work out not resolved yet, steering and oil filter. lots of room for a remote oil filter here though, where the stock fuel filter was-
starter fits perfectly though. I was worried about the location in relation to the lower control arm on the passenger side
Engine is at the correct height using the jig, motor mounts look good, passenger side lines up perfect, driver side a little, ill be using the bracket off the 4.3 and adding to it.
driver-
passenger-
ive got a whole pile of parts ready to go to the powdercoater from the 89 subframe.
In taking it apart, I was amazed to discover that my 89 delivery van with over 200k on it still has the original chevy riveted upper ball joints. Goes to show what a grease nipple can do for you, all this vehicle does in go through potholes on deliveries for years, and they are still good.
question, ive got to source another swaybar, the front sway bar is split heavily on the ends, what sort of finish should be appropriate on a sway bar?
I was going to send whatever I found off to the powdercoater, but should powdercoat be used on something designed to flex? maybe just quality paint?
Im powdercoating-
-bumper brackets
-brake line brackets
-sway bar bushing brackets
-upper control arms
-lower control arms
-upper control arm attachment things. (some kind of large rod with -threaded holes that the control arm bolts to)
-debating on the knuckles, not rusty, and if I leave them alone I don't have to take apart the brake and wheel bearing, plus they are way easier to get off later on if I want to
Both this and the parts van show that the upper control arms, especially on the driver side rust really bad where they attach to the subframe. Was just going to paint them, but what the hell.
