STD Tuning Engine M75 Floyd elements
M75 Floyd elements
M75 Floyd elements
tomnik
03-10-2010, 01:09 AM #51
3 sets of MW65 are in progress (matching the plunger).
I might be able to have them in my hands on Friday.
Tom
(03-09-2010, 10:45 PM)kmaser Has there been any progress with the MW65 elements ?
Kurtis
tomnik
Tom
Kurtis
constantproject
03-11-2010, 03:22 PM #52
can someone send/show me a cutaway of one of these pumps, i want to tweak for power but i am new to diesels. i have a 617.915 if that helps, i am working on getting the engine back into spec and if i have to take things apart i might as well upgrade at the same time right? just small things for now but the pump upgrades seem to be the biggest issue trying to make power...i like power lol
constantproject
kmaser
Turbocharged G-Wagen
125
03-11-2010, 11:54 PM #53
Are they spoken for or would I be able to reserve a set?
(03-10-2010, 01:09 AM)tomnik 3 sets of MW65 are in progress (matching the plunger).
Tom
Kurtis
kmaser
Tom
Kurtis
Biohazard
Smokin like a champ!
376
03-12-2010, 09:53 PM #54
Hi all,
I'm also anxiously awaiting a set of the MW65 elements as well. Next weekend (20th) is currently scheduled to be my intercooler install day, along with other goodness if I can swing the time. Smile
Biohazard
Hi all,
tomnik
03-13-2010, 02:05 AM #55
Kurtis and Brian are noted for a set of MW65 Holly elements.
I'll let you know when they are on my table.
Thanks,
Tom
tomnik
Thanks,
Tom
95e300dez
95E300td
89
03-25-2010, 11:50 PM #56
So I have my turbo installed on my 95 and getting my egt and intercooler just wondering about the elements and if there are any updates on them like if they have been tried. Very interested because I have found a used pump from myna 603 with alda. My goal is max 300 hp so these would be perfect and I am getting ready for the pump modds.[Image: 100_3166.jpg]
95e300dez
tomnik
03-26-2010, 12:32 AM #57
David is in the bench shop today where Rudolf's IP is in progress to get an update.
I would like to see the results before I start to send the next elements.
Tom
tomnik
Tom
Jtn190D
MERCEDES DIESEL POWER!
192
03-30-2010, 10:08 AM #58
Any updates?
Jtn190D
Any updates?
Rudolf_Diesel
Ask me if I care...
03-31-2010, 07:17 AM #59
(03-30-2010, 10:08 AM)Jtn190D Any updates?
Waiting patiently for my pump to be completedBig Grin.......
This post was last modified: 03-31-2010, 09:55 AM by Rudolf_Diesel.
Rudolf_Diesel
GeertDB
03-31-2010, 08:51 AM #60
[quote='95e300dez' pid='11690' dateline='1269579027']
This looks like a N/A om606 with stock intake manifold. Am I correct or was it already a turbo engine ?
GeertDB
95e300dez
95E300td
89
03-31-2010, 11:18 PM #61
Yes it is a stock 95 NA606 that I put a HX35 with a 12 cm exhaust housing works real can't wait to turn up the pump.Here is a link to some pics.http://s108.photobucket.com/albums/n1/2benchanted/Mercedes%20606%20turbo/
95e300dez
GeertDB
04-01-2010, 08:06 AM #62
The pics look great, however I was told that the N/A engines are not so good on handling the extra power. I have one myself that I left untouched for this reason. How much psi is the turbo running ? The N/A engines have much higher compression ratio than the turbo engines, so how did you manage that ? Or the head gasket is going to fly very soon.
I am curious to see how long the engine will last.
GeertDB
95e300dez
95E300td
89
04-01-2010, 11:56 PM #63
I have not heard these are that sensitive. I know these are a little high in comp. but diesel are high anyway. I am only running 15lbs and will hold it lower because I know it has weaker rods and doesn't have the piston skirts the turbo motors have. What have you heard besides the compression that made you hold off the guys in Finland are modding these motors to 300hp on stock internals.
95e300dez
GeertDB
04-02-2010, 08:16 AM #64
The only reason was the strength of the internals. A mercedes long time mechanic told me that on more then one occasion they even had some om603 turbo's comming in with pistons blown trough the engine. When I asked him if it was possible to rebuild my N/A to a stock kkk turbo ( only 147 hp ) he said big NO. anyway mechanics dont necessarily know everything that has been proven. I know mercedes engines are very durable and as you have already rebuild yours only time will tell. I hope it holds up, you even have a 24v (multivalve they called it here) turbo in a W124... nice Big Grin
GeertDB
gsxr
Gone to the M119 dark side
103
04-02-2010, 09:48 PM #65
I thought the NA606 motor had the oil squirters for the pistons, same as the turbo 606, and that the NA606 would tolerate a mild turbo treatment...?
Also, the NA and turbo OM60x have the same compression ratio. The turbo engine does NOT have a lower ratio. The OM606.962 has a 22.0:1 compression ratio, exactly the same as the OM606.910
The Finns have been pushing the 603 turbo to 450hp with stock internals and no blown pistons. I'm not sure what that mechanic was talking about. I wouldn't worry much about pushing a NA603 to a measly 147hp, but I don't think I'd go past that. Better to get a proper turbo engine to start with.
Dave M.
Boise, ID, USA
1997 E420 - 149kmi (Bugeyes)
1994 E420 - 136kmi (Blondie)
1994 E500 - 116kmi (Q-ship)
1992 500E - 179kmi (Mach 5)
Click here for my website!
gsxr
Dave M.
Boise, ID, USA
Tymbrymi
Klatta Klatta
185
04-05-2010, 01:05 PM #66
(04-02-2010, 09:48 PM)gsxr I thought the NA606 motor had the oil squirters for the pistons, same as the turbo 606, and that the NA606 would tolerate a mild turbo treatment...?
The NA606 has oil squirters, but it doesn't have an oil galley in the piston like the turbo's do.
John Robbins
Tymbrymi
John Robbins
Rudolf_Diesel
Ask me if I care...
04-10-2010, 09:18 AM #67
I just got an email last night that the pump was on the bench and it is putting out 4 TIMES more fuel than stock and 3 Times the amount of fuel from where I had it tunedBig GrinBig GrinBig Grin
I can't wait to get it back and in the car!!!!!
Rudolf_Diesel
gsxr
103
04-10-2010, 09:26 AM #68
(04-10-2010, 09:18 AM)Rudolf_Diesel I just got an email last night that the pump was on the bench and it is putting out 4 TIMES more fuel than stock and 3 Times the amount of fuel from where I had it tunedBig GrinBig GrinBig Grin
Remind me again... is this on an M pump or MW pump? OM61x or OM60x....? Got any "cc" numbers from the test bench?
Smile
Dave M.
Boise, ID, USA
gsxr
Smile
Dave M.
Boise, ID, USA
Rudolf_Diesel
Ask me if I care...
04-10-2010, 10:03 AM #69
(04-10-2010, 09:26 AM)gsxr
Smile
This is an M-pump from a NA OM61x, I don't have numbers yet, just got an email at 1:30 AM EST that said, "I should be prepared to be happy". I should be getting some more information later today
This post was last modified: 04-10-2010, 10:04 AM by Rudolf_Diesel.
Rudolf_Diesel
Smile
04-10-2010, 10:20 AM #70
sweet take some videos/pics when you get it
Jtn190D
192
04-21-2010, 05:00 PM #71
Any progress guys? I can't wait!!!!
Jtn190D
Rudolf_Diesel
Ask me if I care...
04-22-2010, 12:41 AM #72
Waiting patientlySmile
Rudolf_Diesel
Jtn190D
192
05-08-2010, 07:37 PM #73
Any thing new?
Jtn190D
Any thing new?
Rudolf_Diesel
Ask me if I care...
05-09-2010, 08:06 AM #74
If all goes well I should have the pump toward the end of the week or the begining of next week.
Rudolf_Diesel
Jtn190D
192
06-03-2010, 07:56 PM #75
Are these ready for production yet?
Jtn190D
tomnik
xgroundel
12-15-2012, 01:45 PM #77
(01-23-2010, 01:26 PM)tomnik Hi,
one element is 60 EUR.
The final cost for the swap and adjustments will be more clear after the first IP is done.
Tom
(01-21-2010, 07:37 PM)squirrelmaster So what is the price tag to buy and have you guys setup a pump with the m75 elements?
[edited for ridiculous use of cap lock]
Hi, Tomnik can you email me at emilpetrov946@gmail.com to send you an adress where can you send the elements and ask you something Smile Waiting for your reply
xgroundel
Tom
frea
12-19-2012, 04:48 PM #78
Hi Tomnik,
Would you give me your advice.
I have G klass and two years headache with it too. I put 117 engine but I took it and then I put in G klass an engine 606, 177 ps, but I have some problems with electronics in diesel pump. In the engine 606 there is a chip / around 200-210 ps/
I read in forum that it is successful to take a pump from 603 , 147 ps. - how do you think? If i put the pump 603- how does engine work and what is necessary for start working?
I saw that you have made improved items for pump 603.
With which item I can receive more Nm in the low level with?
I'm waiting for your response and thank you in advance
frea
Hi Tomnik,
Volker407
naturally aspirated
157
12-19-2012, 05:16 PM #79
Tomnik is tied with stuff at the moment. I don´t know if he can answer you soon.
Basically, if you have Pasi from PPDiesel set a OM603 pump for you with Tomniks´ M75 Floyd elements, you have got what you most probably desire.
Maybe even a little more power. Wink
You can ask Pasi directly, he is also a member here.
Gruß
Volker
Volker407
Gruß
Volker
xgroundel
12-24-2012, 10:53 AM #80
Is the block on the 606na and 606 turbo the same,so you can swap the turbo pistons for more strenght?
xgroundel
Ksteen2
12-28-2012, 07:27 AM #81
its different crank rods and pistons after what I've read Sad in NA an Turbos
Ksteen2
Austincarnut
12-28-2012, 09:32 AM #82
Are you referring to the 617 MW pump elements? I am very interested as several of us are about to attempt to develop our own. If you have already found an alternative.
JM
Tom
Kurtis
Austincarnut
JM
Tom
Kurtis
wagonfreak
12-28-2012, 12:05 PM #83
Ditto I really want a mw65 elements so I don't have to hunt down a m pump and hard lines
1982 300tdt the tinker toy from hell
Mods garret 55 trim turbo, alda full adjustment, oil filter relocated
wagonfreak
OM616
10mm MW
572
12-28-2012, 04:10 PM #84
(12-28-2012, 09:32 AM)Austincarnut Are you referring to the 617 MW pump elements? I am very interested as several of us are about to attempt to develop our own. If you have already found an alternative.
JM
Tom only had a few MW element sets done a couple of years ago and they have all been sold. The USA market is the only one that really has a MW majority, and he has had bad experience with having them installed over here.
From our conversations, I can tell everyone that he is not interested in selling elements to the general public any more. He is supplying PP D with his elements as they can install them properly, no headaches.
OM616
JM
Volker407
naturally aspirated
157
12-28-2012, 04:34 PM #85
So, how many elements are we talking about?
approximately 20-25 elements? (I would take 1 set for storage)
Although OM616 is right that Tomnik doesn´t sell elements to the public anymore.
Gruß
Volker
This post was last modified: 12-28-2012, 04:36 PM by Volker407.
Volker407
Gruß
Volker
Austincarnut
12-28-2012, 06:04 PM #86
PPD?, I wouldn't consider myself the general public as I do this for a living, I have a local pump guy willing to install and work out any kinks in the process for a flat fee. The following of willing collaborators has us convinced this needs to be done for our US market cars.
(12-28-2012, 04:10 PM)OM616
JM
This post was last modified: 12-28-2012, 06:09 PM by Austincarnut.
Austincarnut
JM
wagonfreak
12-28-2012, 06:21 PM #87
I'm in up here in gatlinburg TN there is jack when it comes to anything helpful for a mercedes diesel
wagonfreak
Austincarnut
12-28-2012, 06:37 PM #88
if you need any help/advice let me know. If we could make our own pumps here, we'd be all set.
(12-28-2012, 06:21 PM)wagonfreak I'm in up here in gatlinburg TN there is jack when it comes to anything helpful for a mercedes diesel
Austincarnut
wagonfreak
12-29-2012, 12:14 AM #89
Well Austincarnut if the pump guy can get good results from a modded mw pump with any mm elements ill start pulling my pump and saving some $$$ heck maybe $$ cant be as bad as shipping it over seas heck tried to get my dad to take it over there once he loves to travel
wagonfreak
kmaser
125
01-05-2013, 03:27 PM #90
I have a set of MW65 elements in my pump that was done in the US, I have been running it for about a year now with no issues. I believe with the increase in element size being so close to stock that it made the set up much easier for the pump shop. I think the further you get from stock the more complicated things get when relating element size, DV's, gov. Adj. etc.... That is where it just pays to get a pump built from shop with vast experience getting exactly what your looking for out of your pump. The reason nobody does it cheaply is the money and time they have in R&D to get to where they are.
kmaser
Ksteen2
01-14-2013, 03:51 AM #91
Hi tom,
I wounder if you sell elements and how much do you take for them??
I have accsess to a bench and I want to do my own pump, so I can say all's "home made"
I also talk with Erling666 who I bougt a 606 from, that you are making a 8,5mm element, if so, what are the price tag for those??
I'm sorry for my baaad english, I live in norway Wink
I would really want a sett of 6 8,5mm'ers Wink
Ksteen2
Hi tom,
Austincarnut
01-14-2013, 07:39 PM #92
C'mon Tom, we want to buy your elements!
(01-14-2013, 03:51 AM)Ksteen2 Hi tom,
Austincarnut
bruno_pinho
01-15-2013, 08:39 AM #93
home made projects are increasingly difficult to do ...
in my case, for example, can not buy element's because those who have them do not want to sell without mounting ... Tom was the one who knew what he did and what I see left to do.
bruno_pinho
Alastair E
Moderator?--Nah...
266
01-15-2013, 08:53 AM #94
(01-14-2013, 07:39 PM)Austincarnut C'mon Tom, we want to buy your elements!
Tom isnt supplying out elements for the MW.--He made a FEW EXPERIMENTAL sets ONLY!
Limit on physical size for M type is around 8mm due to wall thickness anyway.
Tom supplies his 7.5 Floyd to PPD, he isnt interested in selling to the Public.....
--Maybe PPD will supply you with 7.5mm M type....
--Maybe Dieselmeken will supply you with his 7mm M type....
[Image: 300TDnoplate.jpg]
Alastair E
Austincarnut
01-15-2013, 10:22 PM #95
Ok, where's Tom?
(01-15-2013, 08:53 AM)Alastair E
Austincarnut
Ok, where's Tom?
BakRob
01-16-2013, 04:28 AM #96
Dear Tomnik!
I'm building an OM606 and I'd like to buy a set of your elements, but as I read previously you stop selling to the crowd.
So my question is: where and how could I buy some nice 7-7.5mm elements (I don't want a knocking idle smoking high consumption engine). I'm from Hungary and here is no opportunity to have premium quality elements (only from Dieselkontor, but as I heard those are china elements). One of my friend is runnig a Bosch mechanic shop with really good results so the calibration is not a problem.
Sorry for my english but my german is much worse!
Mit freundliche Grüßen:
Robert
BakRob
Dear Tomnik!
Robert
Volker407
naturally aspirated
157
01-16-2013, 11:14 AM #97
(01-15-2013, 10:22 PM)Austincarnut Ok, where's Tom?
Hello,
I have talked to Tom yesterday and he told me that he is not a member of "superturbodiesel.com" anymore.
So you have to stick to Pasi from PP Diesel as he has a large number of Tomnik´s elements in stock.
Gruß
Volker
Volker407
Hello,
Gruß
Volker
Alastair E
Moderator?--Nah...
266
01-16-2013, 04:00 PM #98
(01-16-2013, 11:14 AM)Volker407 Hello,
Gruß
Volker
Ah--Thats a shame, Always found him a great source of info and a great guy...
I'm guessing he just got fed up being pestered!
Alastair E
Gruß
Volker
BakRob
01-17-2013, 12:41 AM #99
Hello,
Gruß
Volker
Danke, Volker!
So, I have to search Pasi. Tomnik quit? - DAMN!
BakRob
Hello,
Gruß
Volker
Danke, Volker!
bruno_pinho
01-17-2013, 03:49 AM #100
pasi of the ppd also told me that not selling the items separately, only sells mounting the pump
bruno_pinho
 12 Guest(s)
 12 Guest(s)
