603 Turbo Injection Pump
Hi,
I'm looking for a 603 turbo pump. Just to make sure, a pump out of the following is ideal for a 606.962 project?
OM603.961
OM603.960
OM603.970
OM603.971
Are all of these the same pump, or are there differences I should be aware of--or a preference. If you don't have one, do you know of a good place to look?
Thanks,
The .960 and .961 are '86/'87 603 3.0liter turbo pumps, most common and the one that I read MYNA has developed for their conversion. This pump is a perfect slide-in for the 3.0 as it has the correct 5100rpm high-idle setting.
The .970 and .971 are 603 turbo 3.5liter pumps, later emissions and bigger bore, lower horsepower and lower RPM setting. Installed on the '90-up 350SDL and SD, and SD 300. I prefer the .970 pump for modifications but it needs to be modified to match the 3.0L engine/transmission combination.
(01-03-2013, 12:05 AM)Bangaway What's your opinion of the 606.910 pump?
I have a pump from a 603.970 I don't know how many miles on this pump I'll sell as a core for $80. plus shipping
(01-30-2013, 08:16 PM)benzguy300 I have a pump from a 603.970 I don't know how many miles on this pump I'll sell as a core for $80. plus shipping
