STD Tuning Engine Prechamber Mod "Flame" Front
  • 6 Vote(s) - 4.33 Average
Pages (8): Previous 1 4 5 6 7 8 Next
Turbo
12-27-2012, 03:08 AM #251
Jeemu is a very nice Guy, but love secrets Smile
(12-26-2012, 11:22 PM)OM616
(12-26-2012, 07:30 PM)Turbo OM616
Do you know if Jeemu posted some numbers of the bigger injectors and the change of the nozzle hole for the prechamber?
As far as posting actual hole sizes, not that I know of. I have spoken with him privately though. He is a very nice fellow. I do not feel at liberty to share specifically what we talked about though, as he has not posted it for a reason I suppose.
They are very competitive with these engines over there so any technical advantage is a benefit, so very little will ever be posted for all to see.
This post was last modified: 12-30-2012, 12:04 PM by Turbo.
Turbo
12-27-2012, 06:12 PM #252
(12-26-2012, 06:11 PM)OM616
(12-24-2012, 05:42 PM)MFSuper90 How did you go about enlarging the injector seat? And what is the purpose of doing this?
I have an extra head laying around so I think I will try out some modded PC's also. Sounds like a cheap and worthwhile mod Big Grin
I used my lathe and a boring bar. You do not want to use a drill!!! You will hit the ball!!!
I imagine the larger area helps clear out the injector tip with fresh air. MB says to do this to help reduce smoke, and it is standard on 85 models I think.
I don't have a boring bar small enough to do that, so maybe I'll just skip that step.
Our lathe is a hendley that was used in WWII, good lathe but its much too big for something as small as a prechamber Tongue
OM616
10mm MW
572
12-27-2012, 09:43 PM #253
(12-27-2012, 06:12 PM)MFSuper90
Oh come on you pansy!!! Tongue I learned on a belt driven lathe that was originally powered by a steam engine, lol. However, if you are not confident using the machine, you are right not to try it.
OM616
12-27-2012, 11:00 PM #254
The real problem is my smallest boring bar is like 3/4" Big Grin
Can't wait to get my crank puller in the mail and try some new chambers!
MTUPower
288
12-30-2012, 10:45 AM #255
I'd love to buy a set of altered/enlarged PC's for my wagon with the MYNA pump.... I'd make it worth someone's time!
MTUPower
OM616
10mm MW
572
12-30-2012, 01:12 PM #256
(12-30-2012, 10:45 AM)MTUPower I'd love to buy a set of altered/enlarged PC's for my wagon with the MYNA pump.... I'd make it worth someone's time!
They would definitely help with the smoking and you would notice the additional power. The thing is getting some good used PC for your engine. New ones are way to expensive.
Do you have the special tools to pull the PCs?
OM616
MTUPower
288
12-31-2012, 10:20 AM #257
(12-30-2012, 01:12 PM)OM616
- No but I can go get a whole head from the junkyard and have my indie loan me the tool if I have no other alternative. Interested if I get some PC's? Thanks!
edit: It might be easier to get the tool and pull them at the yard. Anyone want to loan/rent the tool to me?
This post was last modified: 12-31-2012, 10:22 AM by MTUPower.
MTUPower
12-31-2012, 12:22 PM #258
I got the crank puller today to make my own PC puller tool, Have to weld some stuff up then see if she works Big Grin
01-02-2013, 08:39 AM #259
(12-31-2012, 12:22 PM)MFSuper90 I got the crank puller today to make my own PC puller tool, Have to weld some stuff up then see if she works Big Grin
I have a cracked head with 1985 PCs in it riding around in the back seat of my car. Want to lend me that tool once you confirm it works?
01-02-2013, 12:48 PM #260
(01-02-2013, 08:39 AM)Simpler=Better
Well got the tool made, looks kinda jerry-rigged, but it works pretty good. Simpler=Better, I'll see what i can do.
Pulled my PC's and the big middle hole measures .132, the smaller outside ones measure .120, and the small ones on the backside of the PC measure .092
I am going to have a local shop open up the seat ID to 14mm and drop the seat 1mm, then ream them out myself.
Any ideas on how much bigger I should go? Big Grin
01-02-2013, 01:01 PM #261
I think that 0.136" was the biggest OM616 has gone so far. Can you try a homemade sandblast/extrude hone to radius the inner edge of the holes?
This post was last modified: 01-02-2013, 01:02 PM by Simpler=Better.
OM616
10mm MW
572
01-02-2013, 01:20 PM #262
(01-02-2013, 01:01 PM)Simpler=Better I think that 0.136" was the biggest OM616 has gone so far. Can you try a homemade sandblast/extrude hone to radius the inner edge of the holes?
It should be noted that am currently running .136" dia holes on my 616 PCs which have a smaller burn tube ID than the 617a PC.
When I go to install the new injectors, I am going to increase the holes to probably .145"
My goal is to have more hole area than the burn tube has so the pressure head is at the base of the burn tube, which should increase the filling velocity and chamber swirl.
The 617 pc has a larger burn tube ID, so it would require larger holes to match the area % differential I am currently running in my 616.
It is possible to add a hole between the two on the back side, this would allow for overall smaller holes while increasing total area, tapering the inlets sounds like a nice thing too.
If you add an additional hole, do not use a regular drill bit, I would recommend using a M.A. FORD, Hi-Rock drill, it is made for hardened steel and is very rigid, makes a nice clean hole. Or any other straight flute drill for hardened steel for that matter would be better than a helical flute drill.
OM616
01-02-2013, 02:30 PM #263
Om616,
Are you making all the holes the same size?
I was think of just taking the stock hole size for each one (except the small drain hole at the tip) and increasing them by say, maybe .01?
So it would be like one .142 hole, two .130, and two .100?
Om616,
OM616
10mm MW
572
01-02-2013, 04:30 PM #264
(01-02-2013, 02:30 PM)MFSuper90 Om616,
LOL.... I opened them all up the same, but do what you feel comfortable with, anything that helps the PC breath better will help. I did not taper or bevel the holes on mine, so I will add that next time.
A member posted that all he did was taper the holes and saw a benefit. Now that you have the tools to pull the PCs, you can always increase them later if you want.
OM616
01-02-2013, 04:38 PM #265
(01-02-2013, 04:30 PM)OM616
Hmmm. Decisions, Decisions Wink
I think I will leave them in the same size ratio (one big surround by two smaller) and open the back holes up some too. There has to be some reason why Mercedes didn't leave them all the same size.
And as you said, I can always go bigger Tongue
OM616
10mm MW
572
01-02-2013, 04:50 PM #266
(01-02-2013, 04:38 PM)MFSuper90 Hmmm. Decisions, Decisions Wink
I’m sure MB was worried about emissions, some complex post ignition swirl in the cylinder, or who knows what. If you look a swirl chamber head like a VW has, it only has one big hole. Who knows what MB was thinking.
MB changed the holes size a couple of times up and down, who knows what complex issues the engineers were creating so they could solve them.
OM616
ronnie
01-02-2013, 07:05 PM #267
I machined the 616 heads to fit the 617a pc's and opened them .010 all except the tiny one on the bottom. which is about .145 for the largest one. seems even bigger would be fine but have not tryed it.
ronnie
MTUPower
288
01-02-2013, 09:49 PM #268
Got a picture of your tool?
MTUPower
01-02-2013, 10:18 PM #269
(01-02-2013, 09:49 PM)MTUPower Got a picture of your tool?
where is this thread headed?
01-03-2013, 07:45 AM #270
(01-02-2013, 10:18 PM)larsalan
I little bit of everywhere Wink
I don't really have anyway to upload pics to my computer, or I don't know how Huh
01-03-2013, 03:48 PM #271
wutwut!?!?
wutwut!?!?
01-03-2013, 03:51 PM #272
(01-03-2013, 03:48 PM)Simpler=Better wutwut!?!?
well would you look at that Big Grin
lpumb3
617 300sd
141
01-23-2013, 05:42 PM #273
how would one determine if he has good or bad PCs? cracks , wHite metal ?
lpumb3
01-23-2013, 06:03 PM #274
(01-23-2013, 05:42 PM)lpumb3 how would one determine if he has good or bad PCs? cracks , wHite metal ?
Sure indications:
[Image: prechamber1.jpg]
[Image: prechamber2.jpg]
[Image: prechamber3.jpg]
As you can kind of see in #2, the atomizer is gone as well. Probably what made the whole in the bottom...
This post was last modified: 01-23-2013, 06:06 PM by winmutt.
Sure indications:
OM616
10mm MW
572
01-25-2013, 05:03 PM #275
The tools I made are not as pretty as yours...Wink
OM616
01-25-2013, 07:08 PM #276
(01-25-2013, 05:03 PM)OM616 The tools I made are not as pretty as yours...Wink
Now your just showing off Wink
01-26-2013, 06:04 PM #277
What reamers are you guys using to open up the holes? I am trying to decide what to buy...
ronnie
01-26-2013, 08:39 PM #278
solid carbide
ronnie
solid carbide
01-27-2013, 08:42 AM #279
(01-26-2013, 08:39 PM)ronnie solid carbide
But what size, or sizes?
01-27-2013, 11:24 AM #280
A solid carbide boring bar for the center, and some nice .140 (?) diam carbide reamers for the holes
OM616
10mm MW
572
01-28-2013, 12:51 PM #281
I just saw this link over on PP by gxsr. This is a tool to remove the lock ring to remove the PC.
http://www.ebay.com/itm/Mercedes-Benz-Pr...0735030382
OM616
ronnie
01-28-2013, 07:20 PM #282
Think I did .145 for the center hole and .135 for the ones on each side of that. the tiny one on the bottom I did nothing, and it seems .100 for the others. this is all inchs by the way, no metric here....
ronnie
OM616
10mm MW
572
01-29-2013, 06:42 PM #283
I am currently running .136 dia on all 5 holes in my 616 turbo.Tongue
OM616
01-30-2013, 01:50 PM #284
Help me out here, maybe I am just having a brain fart.
You use reamers to open up the holes, so do you get a set of them and just keep going up one size at a time? or get a drill bit, drill it, then clean it up with a reamer?
lpumb3
617 300sd
141
01-30-2013, 02:05 PM #285
(01-23-2013, 06:03 PM)winmutt
Sure indications:
thanks for the pics ,
question should i get these out of the head before i remove it ? will in be a pita if i pull the head off now and set it asside to deal with later when i have the $ for a tool ?
lpumb3
Sure indications:
ConnClark
02-01-2013, 02:48 PM #286
Has anybody done a dyno test on this yet or are we still in the realm of power increases using HHO ?
ConnClark
02-01-2013, 03:48 PM #287
(02-01-2013, 02:48 PM)ConnClark Has anybody done a dyno test on this yet or are we still in the realm of power increases using HHO ?
If anyone near Canton, NY and has a W123 and two sets of PCs/crush washers I can get a dyno run scheduled.
02-01-2013, 04:57 PM #288
AFAIK this is only a mod for when you are pushing too much fuel.
02-01-2013, 05:19 PM #289
(02-01-2013, 04:57 PM)winmutt AFAIK this is only a mod for when you are pushing too much fuel.
I'm not pushing to much fuel, I am just doing it for the fun of it Tongue
OM616
10mm MW
572
02-01-2013, 06:34 PM #290
And it is perfectly ok for you to keep thinking that! lol Big Grin
OM616
ronnie
02-01-2013, 10:17 PM #291
I have not dyno'd but did do some hill climb tests,and it did show a noticeable improvement. I am pushing a good bit of fuel, or at least as much as the stock pump can do. However even at less fueling this mod helped, so have to say I think it should be done as one of the basic things to do when starting to build for performance.
ronnie
02-03-2013, 09:12 PM #292
The only problem is that hardly anybody has the pullers needed to get the precups out
02-03-2013, 09:24 PM #293
(01-28-2013, 12:51 PM)OM616 I just saw this link over on PP by gxsr. This is a tool to remove the lock ring to remove the PC.
Go on and get one Wink
02-03-2013, 09:56 PM #294
Isn't there a slide hammer puller thing needed also to get the chamber out? Or do you just remove the collar nut holding it in and then it comes out?
02-03-2013, 10:20 PM #295
(12-07-2012, 05:00 AM)Captain America
(12-07-2012, 01:50 AM)sassparilla_kid I may have already asked this, or it might be somewhere earlier in the thread, but how difficult is it to pull pre-chambers?
Need special tools.
http://www.mercedessource.com/node/8479
And
http://www.mercedessource.com/node/8478
as seen in Post: #242
Need special tools.
And
02-04-2013, 06:37 AM #296
Or just ask. I rent the collar tool for a pack of beer,deposit and shipping.
poleshady
06-05-2013, 06:23 PM #297
i made something similar to this, 3 of the retaining rings came out, but two were already damaged and just got worse... so they arent coming out.. so i dont know what to do. get a huge easy out? can you buy replacement rings? i cant imagine it would be wise to go ahead and only do 3 of the 5 pre chambers..
poleshady
OM616
10mm MW
572
06-05-2013, 06:32 PM #298
(06-05-2013, 06:23 PM)poleshady i made something similar to this, 3 of the retaining rings came out, but two were already damaged and just got worse... so they arent coming out.. so i dont know what to do. get a huge easy out? can you buy replacement rings? i cant imagine it would be wise to go ahead and only do 3 of the 5 pre chambers..
Does your collar tool thread into the collar to secure it to the collar?
If you look at post 275, (I think), you will see a pic of the tools I made. The collar socket is held tight against the collar with a bolt that is inside the socket, this keeps the socket from popping off and rolling the edges of the collar.
OM616
poleshady
06-05-2013, 06:34 PM #299
(06-05-2013, 06:32 PM)OM616
yeah it threads into the pre chamber not the collar itself. it cut into and took out chunks of the ring, didnt slip out
im on the phoe with the dealership now to see if they can find the part...doesnt sound promising.
luckily they can order them, 8 bucks each, now i need to find an easy out big enough.
This post was last modified: 06-05-2013, 06:40 PM by poleshady.
poleshady
OM616
10mm MW
572
06-05-2013, 06:51 PM #300
(06-05-2013, 06:34 PM)poleshady yeah it threads into the pre chamber not the collar itself. it cut into and took out chunks of the ring, didnt slip out
If the socket is threaded into the PC it will not allow the ring to unscrew. The socket must use the threads in the ring that the injector uses, they are very coarse and the PC threads are very fine. The Fine PC threads are used to pull the PC once the ring is removed.
The Rings are available for not much money so don't worry about that. You need to make a better tool that threads into the collar, not the PC.
OM616
 43 Guest(s)
 43 Guest(s)
