sticky piston?
sticky piston?
Hi all,
I have an OM617 out of a 79 300SD, and I am trying to start it to see if it is any good or not. Turned with a socket, and wasn't seized up.
Now when I have the starter attached and I try to start it, it turns and stops, turns and stops, turns and stops. Figured maybe I might not have enough juice going to it, as I don't actually have a Mercedes battery here...HOWEVER:
When I put the socket on it, I can turn it around but there is one spot that it seems to be sticky. Turns through it, just takes more effort.
Without taking off the head, is there a diagnosis that can be made here? And possibly some treatment for this condition?
Thanks,
Dunl
Take off the valve cover and inspect the chain, cam and valve springs.
(07-12-2009, 02:16 AM)ForcedInduction Take off the valve cover and inspect the chain, cam and valve springs.
How many Cold Cranking Amps does the battery have? The "stickiness" is good, that means your engine has compression.
(07-12-2009, 12:55 PM)GREASY_BEAST How many Cold Cranking Amps does the battery have? The "stickiness" is good, that means your engine has compression.
On 5th valve now, all very tight.....as ForcedInduction has probably already guessed.
Okay, finished now....the last three were right in spec.
Just waiting for the next piece of advice. Here's yesterday's thread at mercedesshop"
http://www.peachparts.com/shopforum/show...p?t=256497
I just broke the banjo bolt on the back of the engine. The airline fitting part is fine, but the bolt broke off...luckily I got the rest of it out with some vicegrips as it broke without much tightening effort whatsoever. Is there another one on this engine somewhere that isn't needed that I could borrow from.
BTW, that banjo and the one on the Alda were crystal clean.
(07-12-2009, 03:30 PM)dunl BTW, that banjo and the one on the Alda were crystal clean.
That cam looks good. Line up the mark on the first tower with the cam and see how far off it is from 0 degrees at the crank. GREASY_BEAST is right, it may just be good 'ol compression. Find some beefy jumper cables and get a boost from your dodge.
The batteries I use in my cars are rated 1000cca.
(07-12-2009, 04:33 PM)ForcedInduction That cam looks good. Line up the mark on the first tower with the cam and see how far off it is from 0 degrees at the crank.
Quote:GREASY_BEAST is right, it may just be good 'ol compression. Find some beefy jumper cables and get a boost from your dodge.
Quote:The batteries I use in my cars are rated 1000cca.
Quote:Without an EGR, the blowby oil doesn't have any soot to mix with and make sludge. The only other fittings I can think of off hand are on the ALDA and the IP oil supply.
(07-12-2009, 04:40 PM)dunl Huh? I hate to say it, but you need to treat me like a 2 year old.Is that good or bad? I try to keep my points simple and to the point, sometimes it just comes out that way.
Quote:How do I find 0 degrees at the crank? Is there a timing mark or something?Yes. There is a "0l0" and marks up to 40 degrees before and after TDC.
Quote:Hmmm....going to cause issues to run it today without that?I wouldn't worry about the ALDA fitting until you get the engine running and ready to drive. It doesn't affect anything on the engine at start or idle.
(07-12-2009, 04:51 PM)ForcedInduction Is that good or bad? I try to keep my points simple and to the point, sometimes it just comes out that way.
Quote:Yes. There is a "0l0" and marks up to 40 degrees before and after TDC.
Quote:I wouldn't worry about the ALDA fitting until you get the engine running and ready to drive. It doesn't affect anything on the engine at start or idle.
(07-12-2009, 04:55 PM)dunl What if it is off?
(07-12-2009, 04:59 PM)ForcedInduction(07-12-2009, 04:55 PM)dunl What if it is off?
It probably will be from wear. Anything between 0-10* ATDC is normal.
Okay, I'm being told that I can't run this without the counterweight attached on the end. So over at mercedesshop I posted this in reply (my inspiration for doing this in the first place):
http://www.youtube.com/watch?v=m00MBqnxa...43&index=0
(07-13-2009, 12:04 PM)dunl Okay, I'm being told that I can't run this without the counterweight attached on the end.
(07-13-2009, 05:01 PM)ForcedInduction(07-13-2009, 12:04 PM)dunl Okay, I'm being told that I can't run this without the counterweight attached on the end.
Which one? The balancer on the front or weight on the flywheel? It should run well enough to test-idle without either one.
