STD Other FS / WTB / Buying guides WTB 603 injector hard lines
01-14-2013, 09:07 PM #1
Anyone got a set?
Anyone got a set?
JustPassinThru
W123 and W124
491
01-14-2013, 10:54 PM #2
Somewhere in that jungle known as my garage, I still have the set I offered you last year. But they're probably so jumbled-up in the box with hard lines from other engines now, that I would need detailed photographs to identify and separate them. How much of the bracketry+braces do you need?
This post was last modified: 01-14-2013, 10:55 PM by JustPassinThru.
JustPassinThru
JustPassinThru
W123 and W124
491
01-15-2013, 01:21 AM #3
I take that back, it was someone else who asked me about OM603 hard lines.
JustPassinThru
01-15-2013, 06:04 AM #4
(01-14-2013, 10:54 PM)JustPassinThru Somewhere in that jungle known as my garage, I still have the set I offered you last year. But they're probably so jumbled-up in the box with hard lines from other engines now, that I would need detailed photographs to identify and separate them. How much of the bracketry+braces do you need?
All never hurt. They are noticeably skinnier than the 61x lines..
01-15-2013, 11:47 AM #5
Any reason you can't use any line with the correct fittings? So long as the lines are equal length everything should be fine right?
JustPassinThru
W123 and W124
491
01-15-2013, 03:41 PM #6
Hang on, it's gonna be at least Saturday before I can look for 'em.
JustPassinThru
JustPassinThru
W123 and W124
491
01-19-2013, 11:24 PM #7
Welp, I found 'em in the box, though I'm not sure which brackets and braces in this box are the OM603's and which go to other engines.
However, I will know in a week. Next Friday I'm picking up a 1987 300TD in Portland. I'll pick all the parts from the box which match that car's equippage. PM me your mailing address.
JustPassinThru
 6 Guest(s)
 6 Guest(s)
