STD Tuning Brakes Will silicone based brake fluid hurt my car?
fha772
08-13-2011, 07:59 AM #1
Hi all,
I'm upgrading my 280E's brakes to 2nd Gen W126 brakes, braided hoses, and new copper pipes.
I'm thinking of refilling the system with either DOT 5, or 5.1 brake fluid.
My question is, 1 of these is silicone based, the other isn't, so is silicone based brake fluid safe to use in a non-ABS W123?
Cheers Frank.
fha772
Hi all,
Cheers Frank.
08-13-2011, 02:16 PM #2
Yes it is safe, BUT...... DOT 5 silicone based is not compatible with DOT 3, 4, or 5.1. So you need to thoroughly clean out every seal, nooks and crannies in the system to prevent a chemical reaction that will cause solids to precipitate and lead to brake system failure.
fha772
08-13-2011, 03:49 PM #3
Thanks, THB most of the brake system is going to be either new or reconditioned, so I shouldn't have any issues with contamination.
Cheers Frank.
fha772
Cheers Frank.
Hercules
08-13-2011, 06:53 PM #4
(08-13-2011, 07:59 AM)fha772 Hi all,
Cheers Frank.
HOPE you meant steel tubing, not copper,(too soft,too weak).
Hercules
Cheers Frank.
lpumb3
617 300sd
141
02-16-2013, 10:49 AM #5
(08-13-2011, 06:53 PM)Hercules
Cheers Frank.
you state that copper is too weak ?
i plan on changing all my lines over to copper , they sell it at my brake spot. stuff lasts forever.
have you experienced line flex with copper?
lpumb3
Cheers Frank.
charmalu
06-04-2013, 12:40 AM #6
There is "Cunifer" brake line that is a Copper Nickle Alloy, easy to bend and corrosion resistant.
http://store.fedhillusa.com/
Charlie
charmalu
Charlie
06-04-2013, 09:04 AM #7
Cunifer tubing is worth every penny. Much easier to work with than stainless and it doesn't corrode line regular cheapo steel lines.
When my next brake service comes I plan on running DOT5, you should be flushing the system anyway....
Mark_M
06-04-2013, 11:14 AM #8
Cheers Frank.
Copper brake pipe has been used in brake lines for decades without any problems at all, thats why they sell it. Cunifer is still better though although it is harder to flare but still easy enough.
Mark_M
Cheers Frank.
john
12-29-2013, 04:42 PM #9
Cooper is the only thing we have used in Sweden since Hitler made cars. ALOT of winter and alot of salt on roads makes the steelines disapere quick.
Easy to flare and bend. The only down thing to steel is that you shouldnt use the "cutting ring" type adapter. Its bound to leak, sooner or later.
I am alot more skeptical to silicon brakefluid :/ My friend did a complete overhaul on his b11 Citroen (sorry for cursing). One year later all the hoses was pluged up. They was dissolved from inside. Maybe it was bad hoses or something but i will never use it after his warning.
This post was last modified: 12-29-2013, 04:46 PM by john.
Holset power!
john
Holset power!
Tito
01-03-2014, 11:01 AM #10
I use copper lines every time. The law says the brake lines can't have any corrosion. So many car's here get copper linings with the annual check. Never had any problem. I've never used the "cutting ring" style adapter but have seen people using them on there own car's and never found them leaking with the annual check. But it could be that they cause issues over time because 2 different sorts of metal could cause extra corrosion and they can fill up with water.
Tito
