STD Other FS / WTB / Buying guides wtb na m pump linkage
lgreeley83
Mr. Rumbles
02-11-2013, 10:16 PM #1
Like the title says. But if greazzer needs it, he should get it first. I remember you needing it.
lgreeley83
zeeman
02-12-2013, 01:13 AM #2
(02-11-2013, 10:16 PM)lgreeley83 Like the title says. But if greazzer needs it, he should get it first. I remember you needing it.
I have a 79 300D with a NA cable linkage.
zeeman
lgreeley83
Mr. Rumbles
02-12-2013, 07:10 AM #3
I'm pretty sure it has to be euro m pump linkage to work. Unless someone tells me otherwise.
Going from mw pump to m pump.
lgreeley83
zeeman
02-12-2013, 09:48 AM #4
(02-12-2013, 07:10 AM)lgreeley83 I'm pretty sure it has to be euro m pump linkage to work. Unless someone tells me otherwise.
Have pics. if you need them.
zeeman
lgreeley83
Mr. Rumbles
02-12-2013, 11:55 AM #5
That wouldn't help. I don't really know what I'm looking for :-)
Any who have done it can you chime in?
lgreeley83
JustPassinThru
W123 and W124
491
02-12-2013, 07:31 PM #6
(02-12-2013, 09:48 AM)zeeman Have pics. if you need them.
Well *I'd* like to see them! Tongue
JustPassinThru
02-13-2013, 09:37 AM #7
Yes, if you have the "M" pump, then one would need the specific linkage for the M pump set up. DeliveryValve was kind enough to post a bunch of pictures of the different flavors to include the one I am looking for. Actually, the bracket that goes on the VC as well as the linkage is unique to the M pump set up for the 300D NA. That is what I have been looking for and no bites yet. Other applications will not work or at least not work correctly.
lgreeley83
Mr. Rumbles
02-13-2013, 10:08 AM #8
I bet there are a bunch out there on parts cars that people don't think to try and sell.
lgreeley83
zeeman
02-23-2013, 07:06 PM #9
(02-12-2013, 07:31 PM)JustPassinThru
Pictures:
zeeman
Pictures:
JustPassinThru
W123 and W124
491
02-23-2013, 11:08 PM #10
Wow...it appears so...shockingly straightforward...
That rod which extends down the starboard side of the valve cover...is that for transmission kickdown?
Is the linkage shown in the pics, available?
JustPassinThru
zeeman
02-24-2013, 01:54 AM #11
(02-23-2013, 11:08 PM)JustPassinThru Wow...it appears so...shockingly straightforward...
Rod is for the non turbo throttle body, yes it is available. I am parting out the whole car. It does also have a passenger side york A/C pump and bracket. Transmission down shift should be a electric switch under the throttle pedal.
zeeman
JustPassinThru
W123 and W124
491
02-25-2013, 03:04 PM #12
Hmm. OK, I've sent a PM asking how much.
I am of course curious to see what the real thing (European 300D-with-M-pump throttle linkage) looks like.
JustPassinThru
02-26-2013, 10:47 AM #13
What ... I have been trying to buy this stuff for a while ... LOL.
Need M pump set up linkage and bracket for VC and any other parts for the throttle linkage set up.
02-26-2013, 12:23 PM #14
That's an MW linkage.
[Image: attachment.php?aid=6201]
lgreeley83
Mr. Rumbles
02-26-2013, 01:52 PM #15
Yeah. SD. Hence my.quietness as well.
lgreeley83
JustPassinThru
W123 and W124
491
02-26-2013, 05:20 PM #16
(02-26-2013, 12:23 PM)DeliveryValve That's an MW linkage.
Might you be able to direct me, kind sir, to a pic of the Euro 300D M-pump linkage?
JustPassinThru
Druk
02-26-2013, 05:43 PM #17
This is a 606.910 n/a engine control.
[Image: 606_zps528ac69a.jpg]
Druk
JustPassinThru
W123 and W124
491
02-26-2013, 06:02 PM #18
(02-26-2013, 05:43 PM)Druk This is a 606.910 n/a engine control.
Yes, thanks, I already have that diagram. I'm actually doing both an OM617a build and an OM606 build.
JustPassinThru
02-26-2013, 07:19 PM #19
(02-26-2013, 05:20 PM)JustPassinThru
Here is a pic of my M-Pump linkage on an engine with a MW-pump it's missing a couple of bushings where the fork goes through. The setup is very simple for a Manual Trans.
I'd sell you all this, but then I wouldn't have one for my own M-pump.
Here is the linkage comparing the MW-Pump pivot linkage. Notice the M-Pump pivot linkage is forward a bit compared to the MW.
Here it is on a car with a Manual Trans, no emissions equipment and with idle control.
[Image: attachment.php?aid=1941]
This post was last modified: 02-26-2013, 07:21 PM by DeliveryValve.
lgreeley83
Mr. Rumbles
03-21-2013, 11:46 AM #20
The shaft that goes from the firewall, do i need the M pump specific or can I just cut the MW one that is in there to accommodate the closer linkage?
lgreeley83
lgreeley83
Mr. Rumbles
03-21-2013, 01:55 PM #21
Ah nevermind I ask to many specifics. I'll find some stuff and get the complete setup. or.. modify a possibility?
BUMP!
WTB M Pump injector hard lines and linkage.
ggrgreazzer too and austincarnut. the line is there people, looks for the euro stuff please.
This post was last modified: 03-21-2013, 01:59 PM by lgreeley83.
lgreeley83
BUMP!
Austincarnut
03-21-2013, 08:16 PM #22
I have an 81 240d with a linkage that would work. I just put a 616 back in it and started driving today. I think with a little doing, it wouldn't be hard to make the linkage work as I have compared it to the 617.920 linkage w/ manual trans.
(02-26-2013, 10:47 AM)Greazzer What ... I have been trying to buy this stuff for a while ... LOL.
I'm playing with a generic rig as I have a ton of linkage parts to play with, if I can make something quality work with my parts I'd be willing to give them up cheap!
(03-21-2013, 01:55 PM)lgreeley83 Ah nevermind I ask to many specifics. I'll find some stuff and get the complete setup. or.. modify a possibility?
BUMP!
This post was last modified: 03-21-2013, 08:22 PM by Austincarnut.
Austincarnut
BUMP!
lgreeley83
Mr. Rumbles
03-23-2013, 09:50 AM #23
Well I found this. I wish the guy had the shaft too but didn't. He also had 3 of 5 hardlines. I let him keep those and told him to yell at the guy who left only half the stuff. Who takes only 2 fuel lines what the heck.
lgreeley83
cho
03-27-2013, 04:17 AM #24
well, after 2 month search I have found one Smile
the guy is willing to sell only whole package
m pump + 5 hardlines + complete linkage
email me how much does it worth to you so I can see
is it worth the trouble Smile
mind the shipment from the Europe too
cheers
cho
cheers
lgreeley83
Mr. Rumbles
03-27-2013, 05:32 AM #25
Lol i have tw0 pumps coming in the mail already. I found some linkage too. Hoping to find more so i can share with forum members as well.
Whole package is good though. Someone will probably bite on this.
lgreeley83
 16 Guest(s)
 16 Guest(s)
