STD Maintenance General w123 300d om617.952 ??
erdem325
03-03-2013, 07:01 PM #1
hi all..
i am new in this forum..
my english is so bad Big Grin
now i have 3 autos, 73 mb 220d, 85 golf 1.8 16v gti and 89 golf 1.6 8v..
i am thinking about sell my 8v golf and buy 84 mb 300d turbo(om617.952)..
but i have questions :S
i want drifting with w123, is this car enough for drifting?
do i use which turbo?
which diesel pump and which nozzles?
how much horsepower can i have with stock internals on om617.952??
thanks..
erdem325
hi all..
thanks..
erdem325
03-04-2013, 05:43 PM #2
no one? Sad
erdem325
no one? Sad
03-04-2013, 06:03 PM #3
With a built injection pump and turbo maybe around 250hp reliably
erdem325
03-04-2013, 07:01 PM #4
(03-04-2013, 06:03 PM)willbhere4u With a built injection pump and turbo maybe around 250hp reliably
thanks..
but which turbo and which pump?
k27?
erdem325
thanks..
k27?
03-05-2013, 09:17 AM #5
Dieselmenken is popular on the forums here, for a turbo an HY30 seems to be decent?
I'm convinced that a custom manifold can make a difference, the stock log has a lot of sharp turns and virtually nonexistant runners.
03-05-2013, 12:32 PM #6
I'm sure a k27 could handle that power or a smallish Holset hy30 hx30 ! I would send the stock pump out to be built by Dieselmenken! I personally would add an intercooler also and a free flowing exhaust and intake
erdem325
03-05-2013, 02:55 PM #7
(03-05-2013, 12:32 PM)willbhere4u I'm sure a k27 could handle that power or a smallish Holset hy30 hx30 ! I would send the stock pump out to be built by Dieselmenken! I personally would add an intercooler also and a free flowing exhaust and intake
k27 turbo, stock pump, intercooler and free flow exhaust himmmm...
how much hp and torque can i have with this spec?
and do not do anything stock pump?
erdem325
03-05-2013, 03:00 PM #8
Stock injection pump, but send it to Dieselmenken and he will install and calibrate new larger elements. I don't know the exact cost but I've heard $1,000-$2,000 being tossed around. With the stock pump you max out at around 140hp/190tq
Another option for a power boost is spraying methanol-the only dyno chart I've seen gained 25ish HP.
erdem325
03-05-2013, 03:03 PM #9
(03-05-2013, 03:00 PM)Simpler=Better Stock injection pump, but send it to Dieselmenken and he will install and calibrate new larger elements. I don't know the exact cost but I've heard $1,000-$2,000 being tossed around. With the stock pump you max out at around 140hp/190tq
damn :S
ok thanks..
for 220-250 hp what can i do?
is it no easy with om617.952 ? Sad
140hp is so poor..
This post was last modified: 03-05-2013, 03:06 PM by erdem325.
erdem325
damn :S
ok thanks..
140hp is so poor..
03-05-2013, 05:39 PM #10
With a stock pump maxed out 140hp with all of the other mods!
the pump is what makes it powerful every thing else just helps supports it!
This post was last modified: 03-05-2013, 05:39 PM by willbhere4u.
03-05-2013, 07:38 PM #11
All turbo cars have an MW pump stock, you will need an M pump for it to be rebuilt with larger elements I believe
erdem325
03-09-2013, 03:48 PM #12
m pump?
what is it ? Big Grin
erdem325
m pump?
 7 Guest(s)
 7 Guest(s)
