STD Tuning Engine om602 power potential
jltcasper3
03-31-2013, 06:58 PM #1
Ok i have a spare wrecked 90 300d with an om602 and trans in it. I am planning a antique pickup truck project and am looking for the powertrain for it. What is the potential power I can safely get out of it? I am willing to spend the money on sending injection pump off for 7mm elements and come up with and intercooler for it also. I have read on here people are putting holset chargers on the 603's like the hx35, hy35, hx30?? The 602 is smaller would I be better off with the hx30?? I know it depends on hp level but I want a good reliable driver with not much lag, I don't want it for hot rodding and burning the tires off it. Is 200-250hp to much to ask for?? what about trans upgrades?? any input would help.
jltcasper3
EDH_Performance
03-31-2013, 08:46 PM #2
Holset hy35 with 7 blade compressor wheel is gold for that engineWink 9cm exhaust housingWink
EDH_Performance
03-31-2013, 10:00 PM #3
I think you're on the right track in terms of power goals.
jltcasper3
04-01-2013, 03:10 PM #4
Does anyone have a holset part number for the 7 blade compressor turbo?? Will it bolt up to exhaust flange without adapters?
jltcasper3
04-02-2013, 09:36 AM #5
I don't think any of the larger holsets will bolt up to a t25 manifold, they are usually t3.
EDH_Performance
04-02-2013, 09:58 AM #6
(04-02-2013, 09:36 AM)aaa I don't think any of the larger holsets will bolt up to a t25 manifold, they are usually t3.
But it is easy to weld a t3 flange to yout om602 turbo manifoldBig Grin
EDH_Performance
TurboWalt
04-02-2013, 11:57 AM #7
(03-31-2013, 08:46 PM)EDH_Performance Holset hy35 with 7 blade compressor wheel is gold for that engineWink 9cm exhaust housingWink
Where do I get one of these, part number, or stock application?
TurboWalt
HaavardPYA
04-03-2013, 09:41 AM #8
Dodge Ram 5,9 Cummins with 24v up to `02 i believe got that one.
HaavardPYA
EDH_Performance
04-03-2013, 05:46 PM #9
But you may rather go for a holset he221w if you are satisfied with max 300hp! These are rather cheap and the best turbo regards spool and performanceWink
It has an t25 flange!
I have one in my 4 pot 1665ccm bmw 8v diesel and with a big 7cm housing i have full pressure at 3000rpmBig Grin
This post was last modified: 04-03-2013, 05:47 PM by EDH_Performance.
EDH_Performance
jltcasper3
04-03-2013, 09:20 PM #10
(04-03-2013, 05:46 PM)EDH_Performance But you may rather go for a holset he221w if you are satisfied with max 300hp! These are rather cheap and the best turbo regards spool and performanceWink
so the om602 has a t25 flange??
jltcasper3
TurboWalt
04-04-2013, 12:09 AM #11
HY35 7 blade 9mm vs. HE221W. Which one spools faster? Is the HE221W the smaller one, limiting HP?
TurboWalt
yankneck696
395
04-04-2013, 07:50 AM #12
The HY 35 is used on 01 & 02 Dodge Ram automatics. I'll have one from my 01 for sale soon. Getting an HX 35 for my Cummins. PM me for details.
Ed
yankneck696
Ed
EDH_Performance
04-04-2013, 07:00 PM #13
(04-04-2013, 12:09 AM)TurboWalt HY35 7 blade 9mm vs. HE221W. Which one spools faster? Is the HE221W the smaller one, limiting HP?
The he221 has an 60mm compwheel, so it is much fasterWink have seen 320hp on vw 2.5tdi with this turbo and 6 cm housingSmile
(04-04-2013, 07:50 AM)yankneck696 The HY 35 is used on 01 & 02 Dodge Ram automatics. I'll have one from my 01 for sale soon. Getting an HX 35 for my Cummins. PM me for details.
Ed
You know that the hy35 and hx35 share the same compressor? Big Grin
This post was last modified: 04-04-2013, 07:12 PM by EDH_Performance.
EDH_Performance
Ed
jltcasper3
04-04-2013, 08:27 PM #14
so it sounds like the he221w would be a better match for 200-250hp, because of less lag, is that correct.
jltcasper3
EDH_Performance
04-07-2013, 06:42 PM #15
(04-04-2013, 08:27 PM)jltcasper3 so it sounds like the he221w would be a better match for 200-250hp, because of less lag, is that correct.
Yep, perfect turbo!
EDH_Performance
Yep, perfect turbo!
mikes02ls1
04-09-2013, 12:21 AM #16
Is the bottom end forged or cast?
mikes02ls1
04-11-2013, 09:46 PM #17
HX(Y?)25 is relatively easy to find over at 4btswaps and has a t25 flange. Not sure about 602 but I had a hard time fitting one on a 603 with an adapter.
 11 Guest(s)
 11 Guest(s)
