BOW
BOW
blow off valve?
Yeah, I think he means BOV.
They are necessary in gas engines to blow off boost after you let out on the throttle.
Diesels have no need to blow off boost.
Although some people do put them on diesels to keep their oversized chargers from surgeing when they let out on the throttle
An open-air wastegate would be just as fun to listen to though
It probably wouldn't do much performance wise.
But it would sound cool you would just need to find a throttle actuated vacuum switch. My old 1980 300sd had a vacuum switch that controlled vacuum to the transmission. IE full vacuum with no throttle and 0 vacuum at full throttle. On that car it was on top of the injection pump and hooked in to the linkage. It basically made vacuum act like it would on a gas engine with an open or closed throttle plate being that the diesel has a vacuum pump that is constant.
(04-18-2013, 09:44 AM)willbhere4u It probably wouldn't do much performance wise.
It still should not be nearly as bad as a gas car since there is no throttle plate getting slammed closed. unless the engine can loose all of its rpm very very quickly. It should just gently slow down as the rpm lowers as it looses back pressure from the exhaust.
I could see it being very useful if you where using compound turbos or supercharger turbo set up
(04-19-2013, 10:36 AM)willbhere4u It still should not be nearly as bad as a gas car since there is no throttle plate getting slammed closed. unless the engine can loose all of its rpm very very quickly. It should just gently slow down as the rpm lowers as it looses back pressure from the exhaust.
My buddies 5.9 cummins needs a BOV. His 66mm charger surges like CRAZY when he lets off the throttle. Slow or fast.
