STD Tuning Engine BOW
BOW
BOW
ravenxm
04-17-2013, 11:01 AM #1
hi people
i"m came from petrol world of tuning and its hard 4 me not to hear bow on my om605 engine
any ideas how can it work similar as in petrol engines>???
ravenxm
hi people
Mark_M
04-17-2013, 11:19 AM #2
dumb question time but what's BOW
Mark_M
04-17-2013, 02:08 PM #3
blow off valve?
blow off valve?
Mark_M
04-17-2013, 02:30 PM #4
I had thought of that right enough, best to check though.
Mark_M
04-17-2013, 04:42 PM #5
Yeah, I think he means BOV.
They are necessary in gas engines to blow off boost after you let out on the throttle.
Diesels have no need to blow off boost.
mantahead
04-18-2013, 05:38 AM #6
(04-17-2013, 04:42 PM)MFSuper90 Yeah, I think he means BOV.
yep, no butterfly on these diesels.
mantahead
04-18-2013, 07:29 AM #7
Although some people do put them on diesels to keep their oversized chargers from surgeing when they let out on the throttle
04-18-2013, 08:15 AM #8
An open-air wastegate would be just as fun to listen to though Smile
04-18-2013, 09:44 AM #9
It probably wouldn't do much performance wise.
But it would sound cool you would just need to find a throttle actuated vacuum switch. My old 1980 300sd had a vacuum switch that controlled vacuum to the transmission. IE full vacuum with no throttle and 0 vacuum at full throttle. On that car it was on top of the injection pump and hooked in to the linkage. It basically made vacuum act like it would on a gas engine with an open or closed throttle plate being that the diesel has a vacuum pump that is constant.
This post was last modified: 04-18-2013, 09:49 AM by willbhere4u.
04-19-2013, 09:13 AM #10
(04-18-2013, 09:44 AM)willbhere4u It probably wouldn't do much performance wise.
Wouldn't do anything performance wise besides save your turbo if your having severe bark or surge issues when you let out on the throttle.
They do sound cool though Big Grin
04-19-2013, 10:36 AM #11
It still should not be nearly as bad as a gas car since there is no throttle plate getting slammed closed. unless the engine can loose all of its rpm very very quickly. It should just gently slow down as the rpm lowers as it looses back pressure from the exhaust.
I could see it being very useful if you where using compound turbos or supercharger turbo set up
ravenxm
04-20-2013, 12:01 PM #12
(04-19-2013, 10:36 AM)willbhere4u It still should not be nearly as bad as a gas car since there is no throttle plate getting slammed closed. unless the engine can loose all of its rpm very very quickly. It should just gently slow down as the rpm lowers as it looses back pressure from the exhaust.
IT'S USELESS cause youre loosing boost but the point to build it
on/off
cause i love the sound of BOV )))
ravenxm
on/off
04-21-2013, 08:53 AM #13
My buddies 5.9 cummins needs a BOV. His 66mm charger surges like CRAZY when he lets off the throttle. Slow or fast.
 11 Guest(s)
 11 Guest(s)
