STD Tuning Suspension W107 steering column
oel_brenner
04-23-2013, 11:07 AM #1
does anyone know if the steering column is a single piece from here:
steering wheel connection:
http://cl.ly/image/211x3b1w3X24
to the coupler at the steering box:
http://cl.ly/image/2u3U3K2p1T1n
I still have a bit of play in the system and have replaced EVERYTHING downstream of the coupler.
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
cars
trucks
boats
04-23-2013, 11:36 AM #2
Have you adjusted the searing box?
I know the stearing box adjust reverse of the way most cars do. I.E. you have to turn the adjusting screw out or CCW I believe. then lock down the lock nut. At least that's how it was on my W123
I turned it out till in stopped then back in a 1/4 turn. and locked it down. worked like a charm
oel_brenner
04-23-2013, 06:50 PM #3
I have not adjusted the box, only has about 50K miles on it from brand new, but looks like I will have to do that next. I understand the adjustment procedure is pretty tricky, and less is more with respect to adjustment and future box wear.
(04-23-2013, 11:36 AM)willbhere4u Have you adjusted the searing box?
cars
trucks
boats
oel_brenner
cars
trucks
boats
