blacksmokeracing new car, pump element seized.
Yeah I saw
Running too small of injectors will sieze pump elements up all day long.
I just can't get over the supercharger sound. It is like scraping nails on a chalkboard to me!
(04-21-2013, 05:52 PM)MFSuper90 Running too small of injectors will sieze pump elements up all day long.
I always thought it sounds like a bad ford power steering pump
It's pretty obvious to me that the problem is the chassis. If it was still in a W123 it would be going strong :p
I'm guessing that with small injectors and large elements, you're trying to push more fuel than the injectors can flow, causing high pressures in the elements/lines, essentially locking them in place and causing a jam.
(04-22-2013, 01:27 PM)Simpler=Better I'm guessing that with small injectors and large elements, you're trying to push more fuel than the injectors can flow, causing high pressures in the elements/lines, essentially locking them in place and causing a jam.
Ended up they kept finding aluminum bits in the fuel system, which seized two pumps. They added a couple more filters and new lines in the past week. Apparently things are going smoothly now.
Me too! But i imagine the w203 is a better car for drifting in his class.. even though there where not much of a 123 car left on that car.
