Safe Boost/EGTs for an OM617
I put an OM617 out of an 85 300sd into my 89 Jeep Wrangler. I just got done installing some new Monark nozzles and I also put in a very nice digital pyro gauge. I tapped the exhaust manifold right in the center in front of the turbo flange. The thing is pretty accurate, when I turn the key on, the pyro gauge almost perfectly reads the ambient outside air temp...
I drove it around and floored on the highway, it would hit upwards of 1100f before i backed off... My boost gauge hits 10psi before the wastegate opens.
So I bought a manual boost controller and mounted it in the cab with the hoses running into the engine bay and connecting to a safety blowoff valve and then back to the turbo and intake. I turned it up a bit and randomely got exactly what I wanted to try out, 14psi boost before the wastegate opens. EGTs are below 1100 too. The ALDA is also removed BTW.
So I was driving it around yesterday testing and I pull up to a traffic light. After sitting for a minute, I notice a lot of white smoke coming out the exhaust. It seemed to be idling fine. I got going again and when I would floor it, it would go, but it seemed like it lost some power... I went home, and parked in my driveway, no smoke, nothing, I couldnt get it to do it again...
What are the same boost limits and EGTs for this engine? And anyone have any clue what may have happened to get that white smoke at idle??
One other note is that after sitting overnight, I start the engine, it fires right up, but then it dies 5 seconds later and it is very very hard to get it started again, must pump the pedal for like 20 seconds cranking. But then once its going, it has no issues.
Your limit for EGT is 1250 unlimited, above that 30 seconds max. I'd say keep it under 1100F is a good way to have a little bit of a safety net. The digital gauges are cool, on hot summer days my exhaust would never cool below 180* in the parking lot at work
No ALDA boost requirement is estimated at 12-14psi, it depends on the car. You're fine at 14, at worst you're only wasting 2psi. Rumor has it that rods bend once you get up to 28psi. Remember, the static compresson on this beast is 22.5:1
No idea on the smoke.
For the hard starts you're getting air in the lines somehow. Install tygon(mcmastercarr.com) or lawnmower clear fuel lines up near the IP to help you find the air leak. Some people have had luck with the cheapo hardware store vinyl tubing, it's up to you what to use. At $1/foot Tygon isn't bad at all-plus that gives you an excuse to buy methanol nozzles from mcmaster
swing by balamer later this summer, I have a stash of parts I would love to sell you
(05-15-2013, 02:54 PM)Simpler=Better Your limit for EGT is 1250 unlimited, above that 30 seconds max. I'd say keep it under 1100F is a good way to have a little bit of a safety net. The digital gauges are cool, on hot summer days my exhaust would never cool below 180* in the parking lot at work
Re: white smoke and stalling, check lift pump pressure, verify fuel filters aren't clogged.
(05-15-2013, 09:21 PM)MFSuper90how do you regulate boost pressure?(05-15-2013, 02:54 PM)Simpler=Better Your limit for EGT is 1250 unlimited, above that 30 seconds max. I'd say keep it under 1100F is a good way to have a little bit of a safety net. The digital gauges are cool, on hot summer days my exhaust would never cool below 180* in the parking lot at work
I never bent a rod....
I let off at 1000F. Post turbo
but it'll only get that high if i limit boost to 12psi. EGT's slow wayy down at 15-17 psi.
at around over two BAR (~30psi) WITH FUELING TO MATCH the rods will let go. i have run over 30 on my engine briefly due to waste gate plumbing issues however with the stock mw pump you cant push enough fuel to use more than ~14 psi of boost. there is noticeably less power over 14 psi on my car with a maxed out stock pump. as for the egt limits the rule of thumb of 1250*F is actually based off of direct injected cummins engines. stock Mercedes recommends a continuous turbine inlet temp of less than 1450*F. that being said the cooler you can run the better it is for your engine.
Im wondering where this idea of boost over 2 bar is dangerous.
Im using a 7.5mm dieselmeken pump set at around 140cc and a borgwarner s200g that boosts 2.5 bar (~36 psi)
I dont have any egt gauge so no clue what the egt's are.
Just wanted to say that my rods are not bent (yet???) after more than 2 years of daily driving
We've heard that figure for years but I haven't seen anyone actually bend a rod from high boost.
Yes well I've learnt boost is a very "fluid" measurement, how efficient is the turbo, how efficient is the intercooler (if there is one), fuel/air ratio, EGTs, time spent at those conditions, etc all plays into it
i have seen at least two people who have blown engines with too much boost. mind you i wouldn't call it too much boost as much as too much power for the rods. 2 bar of boost from an efficient turbo at low rpm with all the fuel you can burn with it to match may cause failure. but so can over revving the engine. the pistons reach 25 meters per second peak velocity at 5000 rpm in a 617 with the stroke of 92.4mm and R/S ratio of 1.61. 25 mps is the rule of thumb for maximum rpm for longevity.
(04-28-2017, 02:35 PM)Keino About yesterday.....Time for studs! I'm studding mine now and will set my wastegate at 28psi.
Going uphill, overtaking another car accelerating from 70 mph to about 100-105 mph Boosting **More** than 36 psi ( gauge only measures 36)
Result?
Blown headgasket! Will be taking a closer look tomorrow. Pics will be posted.
Result?
Alright, so the head has been pulled.
After head was removed it was clear that cyl #3 was the one combusting water.
And the reason where/why the headgasket broke has been identified aswell.
So I got this bigass hole in my wastegate! Looks almost as it has melted.
Im not gonna say too much before I have started the engine with a new headgasket and run it.
But it looks like nothing has been damaged except the gasket itself.
So going uphill at 100-105 mph around 3500 rpm with 140-150cc fuel and no boost restriction. Without doubt I have been going 43psi + the rest is just to fantasise about.
Should this engine run like it did before this incident the cred goes to the engineers in Germany a long time ago.
Will update when I know more.
In the meantime I got some stuff to clean from all the radiator fluid that was spray all over the enginebay.
Going for a copper gasket or a stock one again?
Yanks love putting ARP studs in everything but still don't see why our engines need them
way i see it is for the price its cheap insurance. i am looking at new rods, modified pistons, copper HG, and studs for the head and mains. all this seems extreme however i now have a goal of over 500 hp at the crank and being able to rev over 6K all while maintaining some kind of reliability. theres a lot more i have planned to do including multiple redundant cooling systems and aero work on the body. while these engines are built amazingly tough they to fail sooner with much more power going through them and i want something that still can be daily driven without worrying about breaking it while being face meltingly fast.
I will be using a standard headgasket.
I am convinced I have a solid and safe setup. (However no boost restriction would kill every single engine out there )
New wastegate has been ordered. I still need to find out why this one broke however.
Hopefully I will be able to start the engine tomorrow.
Updates are to come.
Do you have an exhaust pressure gauge? They're easy to install
(04-30-2017, 03:40 PM)Keino I will be using a standard headgasket.
(05-02-2017, 06:18 PM)Austincarnut What are you using for a waste gate and how high are you setting it?
Would be nice to know a 617 can be reliable at that boost
(05-04-2017, 01:34 AM)NZScott Would be nice to know a 617 can be reliable at that boost
(05-04-2017, 09:30 AM)Keino(05-04-2017, 01:34 AM)NZScott Would be nice to know a 617 can be reliable at that boost
I totally understand you
But as I stated earlier I've been boosting 2.4-2.5 bar'ish for like 2 years without any problems.
The engine im using is 617.952 (Original turbodiesel) And has been renovated before usage, head been into shop, valves replaced, new cylinder linings/pistons.
However a broken wastegate changes things....
(05-04-2017, 03:43 PM)Petar @Keino You said you have new pistons ? How hard were they to get, and what was the price ? I've heard that they are quite expensive.
(05-05-2017, 12:03 AM)NZScott True, forgot that...you even said your NA conversion handled it too (just doesn't like getting hot)
