Another car, chicago, uhhh 300d turbo w/4 speed manual
Start your search on Borg-Warner's (present owner of Schwitzer/KKK) website. Maybe look for a marine diesel supply house in Chicago. KKK in Seattle is serviced by a marine diesel distributor, Hatton Marine, in Ballard.
I think i want to add a bigger compressor wheel to it like captain did with his garret.....that is if i can. I havent read anywhere of people doing that with their kkk. Broken just means excuse to upgrade.
If you decide to go Garrett or Holset, I'd like your exhaust-side housing. Maybe the whole turbo.
No i am sure i will keep the turbo for the faster spooling people talk about. I just wonder if i can get more out of it. Someday maybe i will get rid of it for vnt but that is likely a few years away. Id like to get my egr less exhaust manufold and w115 intake before i deploy in july but expect more involved upgrades upon my return in sumner of 2013.
cleaned my fuel sending unit today. No pics sorry. That thing was super rusty. Looked like car sat for many many years with only a couple gallons in the tank. Fuel guage works now. Did the job on my step dads 240 after mine . Done in under 30 min.
Manifolds off ready for non egr exhaust and w115 intake. Wiring for egt andnturbo gauges done and finally got my dash lights working
EGT gauge is sweet, my favorite gauge to look at lol
Im sure it will tell me all the things ive been doing wrong with my right foot ;-) ive been hot rodding it a little lately after i got my tach working.
Ok updates, I dunno what ive written lately
-got the tach working mbelectronics upgrade for the tach amp
-turbo is not dead maybe need a rebuild someday but not yet
-w115 manifold installed
-non egr exhaust manifold installed
-isspro boost and pyrometer installed
-dash lights working
This pic is original w115 manifold no modifications. no grinding, smoothing anything out, just a stock manifold. The two holes I did play with. one hole in it take an m14 bolt, i used a oil pan bolt for some car. the other hole is like an m17 or something that i couldn't find anything for, I tapped the fitting that was there for oil blow by with the same tap I used for exhaust manifold pyrometer. 1/4 NPT. I found a brass fitting that would go into that and that goes to my boost gauge. Some people talk about over boost sensor, i dont know what that is so sorry.
The w115 got in the way of the oil feed line to the turbo. i must have missed that when I read everybody else's builds. I bent that bitch with my hands for over an hour to get it to fit. Can't believe it didn't break. If I were to do the project again I would have some steel braided hose and fitting ready for it. I will likely do that later.
The silicone hose I used was 2.25 to 2.25 with unmodified turbo compressor housing and unmodified w115 intake manifold. I have a kkk turbo but think the garret is the same size. don't quote me.
Dumb shit I wish i didn't do:
-Again that oil feed line. hand bending
-in a rush forgot to scrape old gasket off of oil return line....half of old gasket was left on there with the new one giving me a wonderful cut vein oil leak. I tightened it and tightened it more until I took the return tube off and realized my mistake.
Thanks for all the info you guys give me on here. Helping me grow with my merc...
looks good!
Hey all I have a want to buy out there for na m pump linkage for manual trans euro car. Also in reading I see that the oil or fuel or something has a different line. Something different from m mW pump.
I am getting ready to throw a Goran pump in my car and need to get the little things. Anybody got advice as I move forward? If I can find what I'm looking for can some be more clear as to the needed modifications?
The MW pump is fed oil via an external plastic line. The M pump doesn't use this line-so you block if off at the block.
Working on car soon :-)
Been looking at vacuum diagrams today but can't find one that leaves the engine bay and goes.to the locks, ignition, etc.
Maybe I don't need a pic for the answer to my question. My car is still ghetto and doesnt shut off with the key. I'm wondering if I can simplify and just have vacuum lines for brakes and engine shutoff? I don't care to diagnose for leaks on this.beater.
Egr gone, no cruise control, manual trans,
(04-19-2013, 08:22 AM)lgreeley83 Working on car soon :-)
(04-19-2013, 08:44 AM)JB3 Another way to do is identify exactly what you need for engine shutoff, and 86 all the other lines, connections, and valves, really cleans up the engine. Do you have the usual 300D climate control?
For the brakes, as long as the main vac line is good going to the booster with no leaks, then you have power brakes, so keeping that is really about not creating holes in it.
(04-21-2013, 06:00 PM)MFSuper90 You'll need more than a 60 trim turbo if Dieselmeken does your pumpI'm hoping you are wrong, I'm getting 6mm with his alda setup. Not going tooo wild yet. I'll try and tune it and report.
Ohh, I thought you were gonna go to like 7 or 7.5mm.
Should make that little garrett scream for mercy!
Well I did the vacuum simplify and sometimes its great other time vacuum must be going through the lock someway....car won't start or it will but barely moves. Vacuum will still get to pump even with key in on position. Lame.
Also I started some crappy body work. First time in over ten years, I did it in high school auto shop. Can't be that hard.
Run a line from the shutoff to the cabin, and put a 5cc syringe on the end. Easy way to shutdown and it will keep people guessing. Also, tons of fun at police checkpoints.
(05-29-2013, 09:41 AM)Simpler=Better Run a line from the shutoff to the cabin, and put a 5cc syringe on the end. Easy way to shutdown and it will keep people guessing. Also, tons of fun at police checkpoints.
60 trim turbo installed today. Woot. Sounds good.
I've neglected the basics and done much else in hopes to get my car less smokey. New injectors, rebuilt turbo, valve adjustment, still smokes like crazy.
I should check cam and IP timing. I know this I just suck and haven't yet.
Soo..playing with the car. I went crazy on the body. Pulled trim, bondo, primer. Lots to do with that still.... Going to keep a satin black, silver top, and paint the center caps silver. Before anybody says it looks bad, I know. I did it once 10 years ago, I am just playing with a car I know i will scrap the body of at some point. It looks really great from 30 feet away at night, when raining.
Also dug out the manual steering boxes. Drained them all and put fresh trans fluid in them. They all had a thick oil in them, didn't turn very easily. Now they move with ease. The online book I've seen says trans fluid so I'm cool with that. Might have been an egyptian thing or factory setup?
The ratios all seemed to be the same. The Boxes are all about the same just different part numbers.
Went with a new downpipe, original setup just at 3". The one on there (prior owner) was ghetto as sh!t. Held onto turbo with a muffler clamp, flex pipe connected it the the rear of the system. Ugly.
Lol. The moto has always been "all go no show" for me. Changing the paint has been the first time I've been excited about its looks. Definitely a dirty sort of demon car. I hesitate to drop my 6yo daughter at school out of fear that other parents will get all judgmental and pretentious potentially deterring a potential birthday party invite. My kids love it though.
Got the manual steering in with much fuss. Broke plenty o' stuff. Ended up replacing the centerlink and driver's tie rods at the same time. I much enjoy more engine bay space. If anybody needs a year old power steering belt let me know. My old gearbox garbage, lots of play.
A little tougher turning than I thought but overall I like it.
you need white front doors and big state trooper stars painted on it.
do you know if the manual steering might fit a 115 chassis? If you have any left I could be interested in one if so!
Lol my 3 of my last 4 cars were squad cars (before I went diesel).
I googled a little on 123 115 interchangeability and I don't know. Some say yes some say no. I think more say no. Pm ya.
Blah..decided to see if ac would work. Got belt on, blower fine through different modes, monovalve seems operational....compressor gets no power...testing...now fan no work. Fuse 8 quadruple checked. Fuuuu!!!
First off, my car was a lost cause from rust and everything being worn out except the engine and the seats.
For the heat I bypassed the monovalve, and had a switch straight to the blower. It was on at full blast or off. The vents were wired partially open to my taste. AC was removed because that was dead when I got the car.
For the off switch I had a climate control vac valve under the hood, and a pushbutton in the cabin to trigger it.
For the ignition I cut out the MB ignition, and added a $15 generic key plus a "start" button to confuse people. The glow timed was left stock and ran great. The MB key unlocked the doors. The trunk was drilled out when I got it, so you had to stick your finger in to open it up(this was fine for security no one knew how to open it)
I may end up doing something similar. Before I tear out the ac I want to see if it at least works.
I wonder.....what needs yo be in the circuit it safe? I figure wired in a series switch --> evap freezer switch --> low pressure switch --> compressor? Something to make the right vents open. I'm sure I'm missing something. Any AC masterminds?
Well found another climate control unit in a yard today. Swapped in and fan blows again. I took apart the other unit and it was pretty corroded inside...now just gotta figure out why this compressor gets no current.
I'm a jerk. Jeeze. Well I'll post a pic later but I've come to realize that I had the klima relay. That is before I cut the harness out. Lol. The engine bay sure is getting cleaner.
Sometimes people tell me I'm a bit wild and need to chill. I'm all like "AC works in my car and I be chillin'"
(06-26-2013, 04:39 PM)lgreeley83 Sometimes people tell me I'm a bit wild and need to chill. I'm all like "AC works in my car and I be chillin'"
http://www.superturbodiesel.com/std/thre...l#pid53197
Here is my destroyed differential. Fortunately had spare 2.88. Destroyed was the 3.07. I figure someday I will have another spare laying around and I will beat the crap out of it to see what it can take. This one i hadn't done any preventive maintenance on it so who knows how far gone it was. I like simple's idea of swapping in a whole different rear end. I broke this trying my first burnout...in the rain.
Lol, I can't believe you actually cooked a diff on one of these cars! Impressed.
So installed that manual steering box you sent me in my 123, I love it. Nice and tight and really not a bother in daily driving. Only thing is I completely botched clocking the steering wheel properly.
(07-07-2013, 08:23 AM)JB3 Lol, I can't believe you actually cooked a diff on one of these cars! Impressed.Yeah I don't remember reading about anybody else's destroyed dif.
Well my diff should be in soon....
On a side note, I think I'm about ready to throw my Dieselmeken pump in. I removed an IP from the junkyard recently but am wondering.... Can I do the removal without taking the oil filter housing off? Is it possible? I really don't want to mess with the oil cooler lines. And am lazy.
It is possible. You need to take that plastic VCV off the back of the pump. Then, as you pull the pump rearwards you also tilt the back of it upwards and you can get it out no problemo.
The bigger problem is dealing with the rearmost nut/bolt holding the pump to the block or whatever. That bugger is way up in there by the oil filter housing. I would recommend leaving that one off if it isn't already.
I remember that back bolt being the biggest pain. Can i take the two bolts for the bracket off of the block and remove bracket with pump?
When you install the pump I'd put the bracket in, although it's probably just there as part of the typical merc over engineering. I lost mine when I pulled the motor so I guess I'll find out :p
I think I'm only worried about the removal of the bracket. I read in more place than 1 that they left the bracket off upon reinstallation of MW pump but that same bracket doesn't fit the M pump does it?
Also anybody got a pic of the oil line I'm supposed to block off when I convert to M pump?
I'm going to make sure I get the cam good and timed before installing the M pump but any other tips? I bought the splinned socket so I can drip time the pump already.
(07-23-2013, 02:45 PM)lgreeley83 I think I'm only worried about the removal of the bracket. I read in more place than 1 that they left the bracket off upon reinstallation of MW pump but that same bracket doesn't fit the M pump does it?
Finally picking up car, swapped in a 2:88 vs my 3:07. Well see how it feels.
Not too different off the line. No speedometer or tach right now.
Knowing well the back bolt on the IP was going to be a bastard I began that today with mentality that soon the pump comes off. That bolt sucks. I broke it loose but will try a ratcheting wrench.
I've got
M fuel lines
M throttle linkage
IP gasket
Oil line block off bolt
IP wrench
Spined socket for dv removal
Drip tool
27mm for crankshaft turning
17mm crowfoot
I think I'm ready?
26 BTDC lobes up!
So before i attempt removal I am concerned with clearance. I don't have a standard turbo pump on my car right now. There is a bolt sticking out of the back cover. Can I remove that along with the shutoff valve? What is it? I think with it there I probably don't have clearance to remove pump with oil filter housing on.
Bolt?
