STD Tuning Engine White smoke problem OM603 7MM IP
Hearns
06-22-2013, 01:26 PM #1
Got a big problem with my OM603, it starts good and runs well but im getting white instead of black smoke, and it smells like barbeque/ burning lighterfluid (unburnt diesel?)
Have checked the ip timing 5-6 times and it is 14 degrees after, since the pump is 0,5 degrees late in the bench.
Just changed my headgasket but not sure if everything is ok since it puffs a bit from the crankvent. My injectors are cheked and recheked 120-135 bar openingpressure and just did an compression test around 24 bar on every cylinder! Open for any suggestions running out of ideas.. Just want to know if its worth fixing or if i should just get another enginge.
Thankful for any help//Reed from Sweden
Hearns
mantahead
06-22-2013, 01:49 PM #2
(06-22-2013, 01:26 PM)Hearns Got a big problem with my OM603, it starts good and runs well but im getting white instead of black smoke, and it smells like barbeque/ burning lighterfluid (unburnt diesel?)
check that engine is on tdc for number 1 cylinder and not 6
engine might need turned full revolution to suit pump.
mantahead
Hearns
06-22-2013, 02:20 PM #3
(06-22-2013, 01:49 PM)mantahead
it's at TDC for cyl1.
Forgot to mention that im running it N/A right now, And it runs like a turbo enginge, slow from the start and then increasing power and im not running ALDA right now for more fuel.
Hearns
06-22-2013, 02:53 PM #4
https://www.youtube.com/watch?v=PUcb5G9s0RY
That's your problem?
offroaddieselhu
Domino81
06-22-2013, 03:17 PM #5
if you are not missing air.. maybe inlet is too small? i had the same problem..rubber inlet elements would suck-in when much air was needed, the effect was the same - white smoke..
Domino81
Hearns
06-24-2013, 06:47 AM #6
(06-22-2013, 02:53 PM)offroaddieselhu https://www.youtube.com/watch?v=PUcb5G9s0RY
Yes pretty much, white/black smoke on idle, and then more and more smoke when i rev!
(06-22-2013, 03:17 PM)Domino81 if you are not missing air.. maybe inlet is too small? i had the same problem..rubber inlet elements would suck-in when much air was needed, the effect was the same - white smoke..
I have tried running it without intake also and right now im just using a turbo intake but its just sucking air not blowing.
Starting to suspect that the turbo is the issue.. The white smoke could be oil and the performance decrease could me the turbo not spooling and creating backpressure so that the exhaustgases cant escape?
This post was last modified: 06-24-2013, 06:52 AM by Hearns.
Hearns
Domino81
06-24-2013, 08:19 AM #7
That could be something to investigate..
Domino81
06-24-2013, 02:57 PM #8
Removed ALDA means = 100% fuel
The ALDA limits the fuel until there is boost pressure
This post was last modified: 06-24-2013, 02:58 PM by willbhere4u.
Hearns
06-24-2013, 03:06 PM #9
(06-24-2013, 02:57 PM)willbhere4u Removed ALDA means = 100% fuel
Yeah i know, bad choice of words! I meant that i removed it from the pump to get max fuel all the way! Otherwise i get full fuel at 0.7 bar.
Hearns
dieselmeken
06-24-2013, 11:27 PM #10
Turbo is kaputt!
dieselmeken
Turbo is kaputt!
06-25-2013, 09:38 AM #11
Try putting the ALDA back on until the turbo is pushing boost through the engine Evan the big pump guys need them to keep them from smoking at idle!!!
 13 Guest(s)
 13 Guest(s)
