Om617 overheating issues.
So this is a swap we did in my 95 land rover disco. Anyway around town it only heats up to around 180f. But the other day well sitting in traffic and then hitting the HWY and going up grade it started to get hot. Hit the top of the hill going 50mph and started down and it got to around 240f and then the motor just cut out and dropped all power wouldn't even idle.
Coasted to the side and let it cool down,after a few minutes it would would turn over but wouldn't idle or stay running. Finally after some time it started to idle and I was able to then drive it home with no issues .
So I'm scratching my head on this one,why would it heat up a point that then motor just dies?
Thanks for your help.
(06-29-2013, 10:19 AM)Franko So I'm scratching my head on this one,why would it heat up a point that then motor just dies?
Hmm interesting about the fuel boiling,never of that one before. Lower rad hose seems fine,but like you said would need to check it under load.
Think I need to flush out the coolant system I guess and triple check ever thing.
Wondering if I should install electric fans in front as well??
(07-11-2013, 08:56 AM)Franko How do you solve/find out if the fuel is boiling in the injectors??
If you look on the front of the engine there should be a goofy little metal pipe that goes from the head to the water pump, it can get plugged up and you'll have that problem
Oh tell us more.
(07-11-2013, 08:22 PM)Franko Can you explain a little more how you did this? Looks like you just rotated the thermostat some how?
