STD Tuning Engine What is this part on my om617
euroturbo
07-04-2013, 05:55 PM #1
[Image: image.jpg]
It is located next to the thermostat housing and is bolted in the head with three bolts as you can see in the pic the center one is larger than the other two. What exactly is this part and what does it do?
Most importantly does its gasket seal coolant or engine oil?
Thanks
euroturbo
[Image: image.jpg]
Thanks
07-04-2013, 08:24 PM #2
The chain tensioner. Oil I would guess, I have never had to change it.
Austincarnut
07-05-2013, 08:23 PM #3
(07-04-2013, 05:55 PM)euroturbo [Image: image.jpg]
Thanks
yes tensioner don't touch
Austincarnut
Thanks
poleshady
07-06-2013, 12:33 AM #4
when i removed my tensioner, the spring was pretty worn down,not only was it shorter and not as stiff as a new one, it had grind marks from rubbing on the inside of the tensioner, i replaced both unfortunately, could have done with just the spring it was only a few bucks
poleshady
07-06-2013, 07:41 PM #5
Yup, get a new spring and gasket-it's cheap insurance and is easy
