STD Tuning Engine Busted 2 thermostat housing bolts!
Franko
07-15-2013, 12:43 PM #1
Hey so taking my thermostat housing of my OM617 I busted 2 of the bolts. Confused And will need to drill the busted ones out. Can i just replace them with run of the mill bolts? Or are they some sort of special kind?
Franko
07-15-2013, 01:01 PM #2
You're lucky, up in Canadia you have metric stuff in every hardware store! Regular bolts will be fine, add some neversieze or grease to them. If you're loaded($$) use brass studs with mild steel nuts.
Franko
07-15-2013, 03:27 PM #3
Awesome thanks,now just gotta drill out the broken ones.
Thanks
Franko
Thanks
07-15-2013, 04:56 PM #4
I had broken off 1 or 2 of the original stock bolts, they came out pretty easy with a screw remover or something as I recall.
To be clear, the bolts I broke were the ones that hold the 2 halves of the housing together.
