STD Tuning Engine RC nitro fuel
RC nitro fuel
RC nitro fuel
hooblah
07-30-2013, 01:09 PM #1
Hey guys this is a question thats been bugging me for a long time.
Seeing as rc nitro cars operate on the same principle as a diesel engine, what would be the outcome of pouring a bit of nitro fuel into my tank?
If this is uncharted territory, I may just have to try it out on my om602 Big Grin
hooblah
Turbo
07-30-2013, 03:23 PM #2
if you do not change anything and presume the pump take it, you get less power since the heating value is lower
(07-30-2013, 01:09 PM)hooblah Hey guys this is a question thats been bugging me for a long time.
Turbo
HaavardPYA
07-30-2013, 03:34 PM #3
But it gets supersticky after a while.. In the carbs and stuff.
But if it was possible maybe it would work allmost as E85 on petrolcars?
Think i'll stick to diesel;-)
HaavardPYA
Turbo
07-30-2013, 04:06 PM #4
modell fuel get sticky because the recine oil get left when nitromethane evaporate
Tetranitromethan in the diesel and it will blow you away Wink
Toluene and teranitromethane will burn at right mixture at 9000m/s
Many years ago in sweden the airplane "Draken" was started with Isopropyl nitrate, my friends father tuck some home to try out on his lawn mover stiga, it shortly after start ended up in parts all over the yard....
If you want your diesel to go crazy there is other thing to give it...
(07-30-2013, 03:34 PM)HaavardPYA But it gets supersticky after a while.. In the carbs and stuff.
Turbo
HaavardPYA
07-30-2013, 06:31 PM #5
As more air and dieselWink and at least make it burn it properlyWink
HaavardPYA
07-30-2013, 07:42 PM #6
Since RC fuel has stuff other than nitro, let's assume pure nitro. What would be the best way to introduce it into the engine? Through the injectors or in with the intake charge?
07-30-2013, 08:12 PM #7
I had this guy at a lumber yard tell me many times that my exhaust smelled like that rc nitro stuff he used to put in model planes Wink
07-30-2013, 09:28 PM #8
Since nitro burn throughout the whole stroke of the engine, I think shit would get f*cked up
hooblah
07-31-2013, 01:11 PM #9
(07-30-2013, 07:42 PM)raysorenson Since RC fuel has stuff other than nitro, let's assume pure nitro. What would be the best way to introduce it into the engine? Through the injectors or in with the intake charge?
I'd stick it straight in the fuel tank. But seeing as there is little info out there I guess it would have to be tested both ways.
(07-30-2013, 08:12 PM)larsalan I had this guy at a lumber yard tell me many times that my exhaust smelled like that rc nitro stuff he used to put in model planes Wink
oh really... please elaborate.
hooblah
ConnClark
08-02-2013, 01:37 PM #10
Actually RC nitro methanol engines don't work like a diesel. The glow plug in the top of the head on them is what serves as an ignition source. Its heated by the combustion each time and retains heat for the next cycle. In a diesel its the compression of the air that that raises the temp to ignite the fuel.
Also nitro methanol is corrosive to carbon steel. I wouldn't exactly want it to sit in my injector pump when I shut the engine off. So I would for go the idea of dumping it into the fuel tank.
ConnClark
Turbo
08-02-2013, 02:15 PM #11
even methanol is not that great and after it can as well be some formic acid.
this is why the contain of castor oil at least was so high, when I was doing this stuff years ago the blend was 20% castor oil and 80% methanol
(08-02-2013, 01:37 PM)ConnClark Actually RC nitro methanol engines don't work like a diesel. The glow plug in the top of the head on them is what serves as an ignition source. Its heated by the combustion each time and retains heat for the next cycle. In a diesel its the compression of the air that that raises the temp to ignite the fuel.
Turbo
 7 Guest(s)
 7 Guest(s)
