STD Tuning Engine question on NA vs turbo OM606
McAdam
08-22-2013, 02:09 PM #1
I have a project in mind, and it will be a high HP project. Would I be better off buying a 1995 NA OM606 because it already has a mechanical pump or should I buy a 1998/1999 turbo motor for the supposed stronger internals?
Although from what I have been able to glean from various internet sources, the NA engines are just as strong as the turbo engines.
McAdam
maxypriest
08-22-2013, 09:27 PM #2
Get a turbo engine and put a modified mechanical pump on it.The NA pump is a corker (RS203)
maxypriest
97e300
(its a 98 now)
109
08-23-2013, 12:34 AM #3
had to look it up:
corker
Irish
Meaning, essentailly, an odd, unique, peculiar, special, etc. person.
Simliar to "You're a trip"
Not necessarily bad, though not good either.
You're a corker <insert name here>.
97e300
had to look it up:
corker
Irish
maxypriest
08-23-2013, 03:38 PM #4
That's rather funny!!
over here such sayings are everyday. In the UK a 'corker' means its a 'great thing' or 'person'.
A 'cracker' would be a similar saying with similar meanings.
For instance " I went to see a w124 and it was a corker, so I bought it on the spot"
maxypriest
HaavardPYA
08-25-2013, 06:03 AM #5
N/A engine is weaker.. Weaker rods and pistons...
HaavardPYA
