STD Tuning Engine Electric Water Pump Time
09-16-2013, 08:52 PM #1
After about a year of tinkering with this concept and that design, I just realized that hacking the parts from the OEM set up will work. Here are some pictures of the last missing piece to installing an electric water pump. This gets rid of the water pump (mechanical) and this permits me to use this piece on my turbo engine which will be installed down the road. The NA engine gives a little more clearance with the crank and hub, but I am thinking I do not want to make another one of these. I have some more filling in to do, some more grinding, and then buffing. However, I am thinking maybe by the end of this weekend I can hook up my Davis-Craig electric water pump. Who would have thought that after wasting so much time, simply buzzing thru 2 to 3 water pump housings and I could wrap up this modification. LOL. I doubt when I am done I will have a total of 8 hours invested in this piece. However, I have made a bunch of plates, bent tubing, and you name it over the last year or so. None of it would ultimately clear the crank pulley on the turbo engine. Very tight spot in that neck of the woods.
bricktron
'77 240D
174
09-17-2013, 01:23 AM #2
fancy stuff, mark! i know you have been experimenting with manual steering - very curious about that - so your plan is to have a single serpentine belt running just the alt, AC, and possible supercharger?
bricktron
09-17-2013, 05:55 AM #3
(09-17-2013, 01:23 AM)bricktron fancy stuff, mark! i know you have been experimenting with manual steering - very curious about that - so your plan is to have a single serpentine belt running just the alt, AC, and possible supercharger?
Correct.
I installed manual steering about a year ago. And, I love it. IMO, the manual box is a great upgrade. Once you're rolling, the steering is actually better than power.
Actually, the plan is to have a "winter" sized belt and a "summer" sized belt. With a tensioner, I can easily swap out belts and get rid of one pump once the weather finally cools in sunny S.C.
I plan on installing the bits and pieces for the electric water pump over the next week or so, and then just do the conversion. I am thinking this will end up as one of those incredibly easy mod's ... just took forever. I already mod'd my 3" Be Cool radiator. Next, instalation of the magic box which controls the set up in the glove box and routing wires.
Correct.
bricktron
'77 240D
174
09-20-2013, 04:54 PM #4
the winter belt would be just to disintermediate the A/C compressor? shouldn't its clutch take care of that?
also, please say more about why you prefer the manual steering... i love the idea of the simplicity of it, but the one time that my PS belt broke and i drove home without it, i found the steering a bit difficult.
bricktron
09-20-2013, 09:00 PM #5
(09-20-2013, 04:54 PM)bricktron the winter belt would be just to disintermediate the A/C compressor? shouldn't its clutch take care of that?
With a proper manual box the steering has a better ratio, and you're not pushing the fluid through the pump via the wheel.
You can loop the PS system to simulate manual steering.
09-21-2013, 06:41 AM #6
Check out Logan's threads. He's got a bunch of them from the middle east. They are super rare. Just make sure you get the lower steering shaft. The shaft is a little longer than the power steering one. You can buy the rubber grommit boot new from the dealer and its OK in price. And, yes, it is totally different than the PS with the belt cut. Once you start moving, and once you hit around 20 mph, you cannot really tell the difference. Get around 30 or 40, and its better than PS. Much more responsive, better feel, et cet.
SurfRodder
Jackass Extraordinaire
611
09-21-2013, 06:39 PM #7
(09-21-2013, 06:41 AM)Greazzer Just make sure you get the lower steering shaft. The shaft is a little longer than the power steering one.
Do you have any pics of this, Mark? I may need to send a picture to the dude I'm talking to overseas (translation/communication is a little iffy) to make sure it conveys with the manual box Im looking into. I'm guessing you mean the lower section of the shaft that connects the wheel to the box, yeah? I suppose I could fabricate something if needs be, but if it is already to go with a factory part, I'd rather do that.
Also, I'm looking forward to your electric water pump conversion!
OBK# 62
SurfRodder
OBK# 62
lgreeley83
Mr. Rumbles
09-21-2013, 08:00 PM #8
Jb3 got one from me that shaft he just modified the original. Cut and lengthened. I'm out though of the boxes. Good looking mark hope install is smooth.
lgreeley83
09-22-2013, 07:13 AM #9
(09-21-2013, 06:39 PM)SurfRodder
There should be some pic's in my project thread. I dont think I have any pics of the 2 shafts side-by-side.
AND, correct, the lower shaft meaning the shaft that connects to the steering box thru the firewall to the steering colume. The FSM actually has a picture and its exact measurments.
w123love
Stockish
354
09-22-2013, 01:22 PM #10
Greazzer- have you looked into Drag racing water pumps? Meziere makes pumps for strip and street applications. Even water pumps that attach to the radiator directly.
The VEGEWGN
w123love
The VEGEWGN
 10 Guest(s)
 10 Guest(s)
